[PATCH 28/47] bsp/tms570: Conditionalize TMS570LS3137 errata
Thu Dec 21 14:38:01 UTC 2023
 bsps/arm/tms570/start/bspstarthooks-hwinit.c | 4 ++++
 1 file changed, 4 insertions(+)
diff --git a/bsps/arm/tms570/start/bspstarthooks-hwinit.c b/bsps/arm/tms570/start/bspstarthooks-hwinit.c
index 41f585cad0..561e6a18e6 100644
--- a/bsps/arm/tms570/start/bspstarthooks-hwinit.c
+++ b/bsps/arm/tms570/start/bspstarthooks-hwinit.c
@@ -51,6 +51,7 @@
 BSP_START_TEXT_SECTION void bsp_start_hook_0( void )
+#if TMS570_VARIANT == 3137
    * Work Around for Errata DEVICE#140: ( Only on Rev A silicon)
@@ -62,6 +63,7 @@ BSP_START_TEXT_SECTION void bsp_start_hook_0( void )
   if ( TMS570_SYS1.DEVID == 0x802AAD05U ) {
     _esmCcmErrorsClear_();
+#endif
   /* Enable CPU Event Export */
   /* This allows the CPU to signal any single-bit or double-bit errors detected
@@ -69,11 +71,13 @@ BSP_START_TEXT_SECTION void bsp_start_hook_0( void )
   _coreEnableEventBusExport_();
   /* Workaround for Errata CORTEXR4 66 */
   _errata_CORTEXR4_66_();
   /* Workaround for Errata CORTEXR4 57 */
   _errata_CORTEXR4_57_();
+#endif
   /* check for power-on reset condition */
   /*SAFETYMCUSW 139 S MR:13.7 <APPROVED> "Hardware status bit read check" */
2.35.3
