[PATCH 29/47] bsp/tms570: Add errata SSWF021#45 handling
Thu Dec 21 14:38:02 UTC 2023
 .../include/bsp/ti_herc/errata_SSWF021_45.h   |  56 +++
 bsps/arm/tms570/include/bsp/ti_herc/reg_dcc.h |   6 +
 bsps/arm/tms570/start/bspstarthooks-hwinit.c  |   9 +
 bsps/arm/tms570/start/errata_SSWF021_45.c     | 366 ++++++++++++++++++
 spec/build/bsps/arm/tms570/objhwinit.yml      |   6 +-
 5 files changed, 442 insertions(+), 1 deletion(-)
 create mode 100755 bsps/arm/tms570/include/bsp/ti_herc/errata_SSWF021_45.h
 create mode 100755 bsps/arm/tms570/start/errata_SSWF021_45.c
diff --git a/bsps/arm/tms570/include/bsp/ti_herc/errata_SSWF021_45.h b/bsps/arm/tms570/include/bsp/ti_herc/errata_SSWF021_45.h
new file mode 100755
index 0000000000..e1821f8e6e
--- /dev/null
+++ b/bsps/arm/tms570/include/bsp/ti_herc/errata_SSWF021_45.h
@@ -0,0 +1,56 @@
+/* SPDX-License-Identifier: BSD-3-Clause */
+ * @file
+ * @ingroup RTEMSBSPsARMTMS570
+ * @brief This header file provides errata SSWF021#45 interfaces.
+ * Pulled in from Halcogen v4.7.1.  This is a rare but high-severity errata
+ * that should always be checked for at system start.
+* Copyright (C) 2009-2018 Texas Instruments Incorporated - www.ti.com
+*  Redistribution and use in source and binary forms, with or without
+*  modification, are permitted provided that the following conditions
+*  are met:
+*    Redistributions of source code must retain the above copyright
+*    notice, this list of conditions and the following disclaimer.
+*    Redistributions in binary form must reproduce the above copyright
+*    notice, this list of conditions and the following disclaimer in the
+*    documentation and/or other materials provided with the
+*    distribution.
+*    Neither the name of Texas Instruments Incorporated nor the names of
+*    its contributors may be used to endorse or promote products derived
+*    from this software without specific prior written permission.
+*  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+*  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+*  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
+*  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
+*  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+*  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
+*  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
+*  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
+*  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
+*  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
+*  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+#ifndef INCLUDE_ERRATA_SSWF021_45_H_
+#define INCLUDE_ERRATA_SSWF021_45_H_
+#include <stdint.h>
+uint32_t _errata_SSWF021_45_both_plls(uint32_t count);
+uint32_t _errata_SSWF021_45_pll1(uint32_t count);
+uint32_t _errata_SSWF021_45_pll2(uint32_t count);
+#endif /* INCLUDE_HL_ERRATA_SSWF021_45_H_ */
diff --git a/bsps/arm/tms570/include/bsp/ti_herc/reg_dcc.h b/bsps/arm/tms570/include/bsp/ti_herc/reg_dcc.h
index f5d35719fa..12edca3eb1 100644
--- a/bsps/arm/tms570/include/bsp/ti_herc/reg_dcc.h
+++ b/bsps/arm/tms570/include/bsp/ti_herc/reg_dcc.h
@@ -51,6 +51,12 @@
 #include <bsp/utility.h>
+enum tms570_dcc1_cnt0_clksrc {
+    DCC1_CNT0_HF_LPO    = 0x5U,    /**< Alias for DCC1 CNT 0 CLOCK SOURCE 0*/
+    DCC1_CNT0_TCK       = 0xAU,    /**< Alias for DCC1 CNT 0 CLOCK SOURCE 1*/
+    DCC1_CNT0_OSCIN     = 0xFU,    /**< Alias for DCC1 CNT 0 CLOCK SOURCE 2*/
 typedef struct{
   uint32_t GCTRL;             /*DCC Global Control Register*/
   uint32_t REV;               /*DCC Revision Id Register*/
diff --git a/bsps/arm/tms570/start/bspstarthooks-hwinit.c b/bsps/arm/tms570/start/bspstarthooks-hwinit.c
index 561e6a18e6..8ac53a3d44 100644
--- a/bsps/arm/tms570/start/bspstarthooks-hwinit.c
+++ b/bsps/arm/tms570/start/bspstarthooks-hwinit.c
@@ -46,6 +46,7 @@
 #include <bsp/tms570_selftest.h>
 #include <bsp/tms570_selftest_parity.h>
 #include <bsp/tms570_hwinit.h>
+#include <bsp/ti_herc/errata_SSWF021_45.h>
 #define PBIST_March13N_SP        0x00000008U  /**< March13 N Algo for 1 Port mem */
@@ -65,6 +66,14 @@ BSP_START_TEXT_SECTION void bsp_start_hook_0( void )
 #endif
+#if TMS570_VARIANT == 4357
+  uint32_t pll_result;
+  do {
+    pll_result = _errata_SSWF021_45_both_plls(10);
+  } while (pll_result != 0 && pll_result != 4);
+#endif
   /* Enable CPU Event Export */
   /* This allows the CPU to signal any single-bit or double-bit errors detected
    * by its ECC logic for accesses to program flash or data RAM.
diff --git a/bsps/arm/tms570/start/errata_SSWF021_45.c b/bsps/arm/tms570/start/errata_SSWF021_45.c
index 0000000000..1591e64798
--- /dev/null
+++ b/bsps/arm/tms570/start/errata_SSWF021_45.c
@@ -0,0 +1,366 @@
+ * @file
+ * @brief This source file contains errata SSWF021#45 workaround
+ *   implementation.
+ * Copyright (C) 2009-2018 Texas Instruments Incorporated - www.ti.com
+ *  Redistribution and use in source and binary forms, with or without
+ *  modification, are permitted provided that the following conditions
+ *  are met:
+ *    Redistributions of source code must retain the above copyright
+ *    Redistributions in binary form must reproduce the above copyright
+ *    documentation and/or other materials provided with the
+ *    distribution.
+ *    Neither the name of Texas Instruments Incorporated nor the names of
+ *    its contributors may be used to endorse or promote products derived
+ *    from this software without specific prior written permission.
+ *  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+ *  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+ *  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
+ *  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
+ *  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+ *  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
+ *  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
+ *  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
+ *  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
+ *  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
+ *  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+#include <bsp/tms570.h>
+#define SYS_CLKSRC_PLL1 0x00000002U
+#define SYS_CLKSRC_PLL2 0x00000040U
+#define SYS_CLKCNTRL_PENA 0x00000100U
+#define ESM_SR1_PLL1SLIP 0x400U
+#define ESM_SR4_PLL2SLIP 0x400U
+#define PLL1 0x08
+#define PLL2 0x80
+#define dcc1CNT1_CLKSRC_PLL1 0x0000A000U
+#define dcc1CNT1_CLKSRC_PLL2 0x0000A001U
+static uint32_t check_frequency(uint32_t cnt1_clksrc);
+static uint32_t disable_plls(uint32_t plls);
+/** @fn uint32_t _errata_SSWF021_45_both_plls(uint32_t count)
+ *   @brief This handles the errata for PLL1 and PLL2. This function is called
+ *      in device startup
+ *   @param[in] count : Number of retries until both PLLs are locked
+ *      successfully Minimum value recommended is 5
+ *   @return 0 = Success (the PLL or both PLLs have successfully locked and then
+ *               been disabled)
+ *           1 = PLL1 failed to successfully lock in "count" tries
+ *           2 = PLL2 failed to successfully lock in "count" tries
+ *           3 = Neither PLL1 nor PLL2 successfully locked in "count" tries
+ *           4 = The workaround function was not able to disable at least one of
+ *               the PLLs. The most likely reason is that a PLL is already being
+ *               used as a clock source. This can be caused by the workaround
+ *               function being called from the wrong place in the code.
+uint32_t _errata_SSWF021_45_both_plls(uint32_t count) {
+    uint32_t failCode, retries, clkCntlSav;
+    /* save CLKCNTL */
+    clkCntlSav = TMS570_SYS1.CLKCNTL;
+    /* First set VCLK2 = HCLK */
+    TMS570_SYS1.CLKCNTL = clkCntlSav & 0x000F0100U;
+    /* Now set VCLK = HCLK and enable peripherals */
+    TMS570_SYS1.CLKCNTL = SYS_CLKCNTRL_PENA;
+    failCode = 0U;
+    for (retries = 0U; (retries < count); retries++) {
+        failCode = 0U;
+        /* Disable PLL1 and PLL2 */
+        failCode = disable_plls(SYS_CLKSRC_PLL1 | SYS_CLKSRC_PLL2);
+        if (failCode != 0U) {
+            break;
+        /* Clear Global Status Register */
+        TMS570_SYS1.GLBSTAT = 0x00000301U;
+        /* Clear the ESM PLL slip flags */
+        TMS570_ESM.SR[0U] = ESM_SR1_PLL1SLIP;
+        TMS570_ESM.SR4 = ESM_SR4_PLL2SLIP;
+        /* set both PLLs to OSCIN/1*27/(2*1) */
+        TMS570_SYS1.PLLCTL1 = 0x20001A00U;
+        TMS570_SYS1.PLLCTL2 = 0x3FC0723DU;
+        TMS570_SYS2.PLLCTL3 = 0x20001A00U;
+        TMS570_SYS1.CSDISCLR = SYS_CLKSRC_PLL1 | SYS_CLKSRC_PLL2;
+        /* Check for (PLL1 valid or PLL1 slip) and (PLL2 valid or PLL2 slip) */
+        while ((((TMS570_SYS1.CSVSTAT & SYS_CLKSRC_PLL1) == 0U) &&
+                ((TMS570_ESM.SR[0U] & ESM_SR1_PLL1SLIP) == 0U)) ||
+               (((TMS570_SYS1.CSVSTAT & SYS_CLKSRC_PLL2) == 0U) &&
+                ((TMS570_ESM.SR4 & ESM_SR4_PLL2SLIP) == 0U))) {
+            /* Wait */
+        /* If PLL1 valid, check the frequency */
+        if (((TMS570_ESM.SR[0U] & ESM_SR1_PLL1SLIP) != 0U) ||
+            ((TMS570_SYS1.GLBSTAT & 0x00000300U) != 0U)) {
+            failCode |= 1U;
+        } else {
+            failCode |= check_frequency(dcc1CNT1_CLKSRC_PLL1);
+        /* If PLL2 valid, check the frequency */
+        if (((TMS570_ESM.SR4 & ESM_SR4_PLL2SLIP) != 0U) ||
+            failCode |= 2U;
+        } else {
+            failCode |= (check_frequency(dcc1CNT1_CLKSRC_PLL2) << 1U);
+        if (failCode == 0U) {
+            break;
+    /* To avoid MISRA violation 382S
+       (void)missing for discarded return value */
+    /* restore CLKCNTL, VCLKR and PENA first */
+    TMS570_SYS1.CLKCNTL = (clkCntlSav & 0x000F0100U);
+    /* restore CLKCNTL, VCLK2R */
+    TMS570_SYS1.CLKCNTL = clkCntlSav;
+    return failCode;
+/** @fn uint32_t _errata_SSWF021_45_pll1(uint32_t count)
+ *   @brief This handles the errata for PLL1. This function is called in device
+ *       startup
+ *   @param[in] count : Number of retries until both PLL1 is locked successfully
+ *                      Minimum value recommended is 5
+ *               been disabled)
+uint32_t _errata_SSWF021_45_pll1(uint32_t count) {
+    failCode = 0U;
+        failCode = 0U;
+        /* Disable PLL1 */
+        failCode = disable_plls(SYS_CLKSRC_PLL1);
+            break;
+        /* set  PLL1 to OSCIN/1*27/(2*1) */
+        TMS570_SYS1.CSDISCLR = SYS_CLKSRC_PLL1;
+        /* Check for PLL1 valid or PLL1 slip*/
+        while (((TMS570_SYS1.CSVSTAT & SYS_CLKSRC_PLL1) == 0U) &&
+               ((TMS570_ESM.SR[0U] & ESM_SR1_PLL1SLIP) == 0U)) {
+            /* Wait */
+            failCode |= 1U;
+        } else {
+            break;
+    return failCode;
+/** @fn uint32_t _errata_SSWF021_45_pll2(uint32_t count)
+ *   @brief This handles the errata for PLL2. This function is called in device
+ *           startup
+ *   @param[in] count : Number of retries until PLL2 is locked successfully
+ *       been disabled)
+uint32_t _errata_SSWF021_45_pll2(uint32_t count) {
+    failCode = 0U;
+        failCode = 0U;
+        /* Disable PLL2 */
+        failCode = disable_plls(SYS_CLKSRC_PLL2);
+            break;
+        /* set PLL2 to OSCIN/1*27/(2*1) */
+        TMS570_SYS1.CSDISCLR = SYS_CLKSRC_PLL2;
+        /* Check for PLL2 valid or PLL2 slip */
+        while (((TMS570_SYS1.CSVSTAT & SYS_CLKSRC_PLL2) == 0U) &&
+               ((TMS570_ESM.SR4 & ESM_SR4_PLL2SLIP) == 0U)) {
+            /* Wait */
+            failCode |= 2U;
+        } else {
+            break;
+    return failCode;
+/** @fn uint32_t check_frequency(uint32_t cnt1_clksrc)
+ *   @brief This function checks for the PLL frequency.
+ *   @param[in] cnt1_clksrc : Clock source for Counter1
+ *                            0U - PLL1      (clock source 0)
+ *                            1U - PLL2      (clock source 1)
+ *   @return   DCC Error status
+ *             0 - DCC error has not occurred
+ *             1 - DCC error has occurred
+static uint32_t check_frequency(uint32_t cnt1_clksrc) {
+    /* Setup DCC1 */
+    /** DCC1 Global Control register configuration */
+    TMS570_DCC1.GCTRL =
+        (uint32_t)0x5U |                   /** Disable  DCC1 */
+        (uint32_t)((uint32_t)0x5U << 4U) | /** No Error Interrupt */
+        (uint32_t)((uint32_t)0xAU << 8U) | /** Single Shot mode */
+        (uint32_t)((uint32_t)0x5U << 12U); /** No Done Interrupt */
+    /* Clear ERR and DONE bits */
+    TMS570_DCC1.STAT = 3U;
+    /** DCC1 Clock0 Counter Seed value configuration */
+    TMS570_DCC1.CNT0SEED = 68U;
+    /** DCC1 Clock0 Valid Counter Seed value configuration */
+    TMS570_DCC1.VALID0SEED = 4U;
+    /** DCC1 Clock1 Counter Seed value configuration */
+    TMS570_DCC1.CNT1SEED = 972U;
+    /** DCC1 Clock1 Source 1 Select */
+    TMS570_DCC1.CNT1CLKSRC =
+        (uint32_t)((uint32_t)10U << 12U) | /** DCC Enable / Disable Key */
+        (uint32_t)cnt1_clksrc;             /** DCC1 Clock Source 1 */
+    TMS570_DCC1.CNT0CLKSRC =
+        (uint32_t)DCC1_CNT0_OSCIN; /** DCC1 Clock Source 0 */
+        (uint32_t)0xAU |                   /** Enable  DCC1 */
+    while (TMS570_DCC1.STAT == 0U) {
+        /* Wait */
+    return (TMS570_DCC1.STAT & 0x01U);
+/** @fn uint32_t disable_plls(uint32_t plls)
+ *   @brief This function disables plls and clears the respective ESM flags.
+ *   @param[in] plls : Clock source for Counter1
+ *                            2U - PLL1
+ *                            40U - PLL2
+ *   @return   failCode
+ *      0 = Success (the PLL or both PLLs have successfully locked and
+ *          then been disabled)
+ *          of the PLLs. The most likely reason is that a PLL is already being
+static uint32_t disable_plls(uint32_t plls) {
+    uint32_t timeout, failCode;
+    TMS570_SYS1.CSDISSET = plls;
+    failCode = 0U;
+    timeout = 0x10U;
+    timeout--;
+    while (((TMS570_SYS1.CSVSTAT & (plls)) != 0U) && (timeout != 0U)) {
+        /* Clear ESM and GLBSTAT PLL slip flags */
+        TMS570_SYS1.GLBSTAT = 0x00000300U;
+        if ((plls & SYS_CLKSRC_PLL1) == SYS_CLKSRC_PLL1) {
+        if ((plls & SYS_CLKSRC_PLL2) == SYS_CLKSRC_PLL2) {
+        timeout--;
+        /* Wait */
+    if (timeout == 0U) {
+        failCode = 4U;
+    } else {
+        failCode = 0U;
+    return failCode;
diff --git a/spec/build/bsps/arm/tms570/objhwinit.yml b/spec/build/bsps/arm/tms570/objhwinit.yml
index afa12e28d9..436b3e3b53 100644
--- a/spec/build/bsps/arm/tms570/objhwinit.yml
+++ b/spec/build/bsps/arm/tms570/objhwinit.yml
@@ -8,10 +8,14 @@ cxxflags: []
 enabled-by:
 - TMS570_USE_HWINIT_STARTUP
 includes: []
-install: []
+install:
+- destination: ${BSP_INCLUDEDIR}/bsp/ti_herc
+  source:
+  - bsps/arm/tms570/include/bsp/ti_herc/errata_SSWF021_45.h
 links: []
 source:
 - bsps/arm/tms570/start/bspstarthooks-hwinit.c
+- bsps/arm/tms570/start/errata_SSWF021_45.c
 - bsps/arm/tms570/start/fail_notification.c
 - bsps/arm/tms570/start/init_emif_sdram.c
 - bsps/arm/tms570/start/init_esm.c
2.35.3
