[PATCH 42/47] bsp/tms570: Initialize MPU
Thu Dec 21 14:38:15 UTC 2023
 bsps/arm/tms570/start/bspstarthooks-hwinit.c |   3 +
 bsps/arm/tms570/start/tms570_sys_core.S      | 202 +++++++++++++++++++
 2 files changed, 205 insertions(+)
diff --git a/bsps/arm/tms570/start/bspstarthooks-hwinit.c b/bsps/arm/tms570/start/bspstarthooks-hwinit.c
index 67c3768a36..6407cc4a45 100644
--- a/bsps/arm/tms570/start/bspstarthooks-hwinit.c
+++ b/bsps/arm/tms570/start/bspstarthooks-hwinit.c
@@ -337,6 +337,9 @@ static RTEMS_USED void tms570_start_hook_0( void )
   tms570_emif_sdram_init();
+  /* Configures and enables the ARM-core Memory Protection Unit (MPU) */
+  _mpuInit_();
 #if 1
    * Do not depend on link register to be restored to
diff --git a/bsps/arm/tms570/start/tms570_sys_core.S b/bsps/arm/tms570/start/tms570_sys_core.S
index c3004e019f..83dee26ec8 100644
--- a/bsps/arm/tms570/start/tms570_sys_core.S
+++ b/bsps/arm/tms570/start/tms570_sys_core.S
@@ -582,4 +582,206 @@ _errata_CORTEXR4_66_:
         mcr p15, #0, r0, c1, c0, #1 @ Write Auxiliary Control register
         pop {r0}
         bx lr
+@ Initialize Mpu: pulled from LC4357 R5f Halcogen generation
+    .weak _mpuInit_
+    .type _mpuInit_, %function
+_mpuInit_:
+        @ Disable mpu
+        mrc   p15, #0, r0, c1, c0, #0
+        bic   r0,  r0, #1
+        dsb
+        mcr   p15, #0, r0, c1, c0, #0
+        isb
+        @ Disable background region
+        bic   r0,  r0, #0x20000
+        @ Setup region 1
+        mov   r0,  #0
+        mcr   p15, #0,    r0, c6, c2, #0
+        ldr   r0,  r1Base
+        mcr   p15, #0,    r0, c6, c1, #0
+        mov   r0,  #0x0008
+        orr   r0,  r0,    #0x1000
+        mcr   p15, #0,    r0, c6, c1, #4
+        movw  r0,  #((1 << 15) + (1 << 14) + (1 << 13) + (1 << 12) + (1 << 11) + (1 << 10) + (1 <<  9) + (1 <<  8) + (0x1F << 1) + (1))
+        mcr   p15, #0,    r0, c6, c1, #2
+        @ Setup region 2
+        mov   r0,  #1
+        ldr   r0,  r2Base
+        mov   r0,  #0x0002
+        orr   r0,  r0,    #0x0600
+        movw  r0,  #((0 << 15) + (0 << 14) + (0 << 13) + (0 << 12) + (0 << 11) + (0 << 10) + (0 <<  9) + (0 <<  8) + (0x15 << 1) + (1))
+        @ Setup region 3 - Internal RAM
+        mov   r0,  #2
+        ldr   r0,  r3Base
+        mov   r0,  #0x000B
+        orr   r0,  r0,    #0x0300
+        movw  r0,  #((0 << 15) + (0 << 14) + (0 << 13) + (0 << 12) + (0 << 11) + (0 << 10) + (0 <<  9) + (0 <<  8) + (0x12 << 1) + (1))
+        @ Setup region 4
+        mov   r0,  #3
+        ldr   r0,  r4Base
+        mov   r0,  #0x0010
+        orr   r0,  r0,    #0x1300
+        movw  r0,  #((0 << 15) + (0 << 14) + (0 << 13) + (0 << 12) + (0 << 11) + (1 << 10) + (1 <<  9) + (1 <<  8) + (0x1A << 1) + (1))
+        @ Setup region 5
+        mov   r0,  #4
+        ldr   r0,  r5Base
+        mov   r0,  #0x0000
+        movw  r0,  #((1 << 15) + (1 << 14) + (0 << 13) + (0 << 12) + (0 << 11) + (0 << 10) + (0 <<  9) + (0 <<  8) + (0x1B << 1) + (1))
+        @ Setup region 6 - EMIF CS0 == External SDRAM
+        mov   r0,  #5
+        ldr   r0,  r6Base
+        mov   r0,  #0x0002
+        movw  r0,  #((0 << 15) + (0 << 14) + (0 << 13) + (0 << 12) + (0 << 11) + (0 << 10) + (0 <<  9) + (0 <<  8) + (0x1A << 1) + (1))
+        @ Setup region 7
+        mov   r0,  #6
+        ldr   r0,  r7Base
+        mov   r0,  #0x0008
+        orr   r0,  r0,    #0x1200
+        movw  r0,  #((0 << 15) + (0 << 14) + (0 << 13) + (0 << 12) + (0 << 11) + (0 << 10) + (0 <<  9) + (0 <<  8) + (0x16 << 1) + (1))
+        @ Setup region 8
+        mov   r0,  #7
+        ldr   r0,  r8Base
+        mov   r0,  #0x0010
+        movw  r0,  #((0 << 15) + (0 << 14) + (0 << 13) + (0 << 12) + (0 << 11) + (0 << 10) + (0 <<  9) + (0 <<  8) + (0x04 << 1) + (0))
+        @ Setup region 9
+        mov   r0,  #8
+        ldr   r0,  r9Base
+        mov   r0,  #0x0006
+        @ Setup region 10
+        mov   r0,  #9
+        ldr   r0,  r10Base
+        mov   r0,  #0x000C
+        @ Setup region 11
+        mov   r0,  #10
+        ldr   r0,  r11Base
+        mov   r0,  #0x0006
+        @ Setup region 12
+        mov   r0,  #11
+        ldr   r0,  r12Base
+        mov   r0,  #0x0006
+        orr   r0,  r0,    #0x1600
+        @ Setup region 13
+        mov   r0,  #12
+        ldr   r0,  r13Base
+        mov   r0,  #0x0006
+        @ Setup region 14
+        mov   r0,  #13
+        ldr   r0,  r14Base
+        mov   r0,  #0x0006
+        @ Setup region 15
+        mov   r0,  #14
+        ldr   r0,  r15Base
+        mov   r0,  #0x0006
+        @ Setup region 16
+        mov   r0,  #15
+        ldr   r0,  r16Base
+        mov   r0,  #0x0010
+        @ Enable mpu
+        orr   r0,  r0, #1
+        dsb
+        isb
+        bx    lr
+r1Base:  .word 0x00000000
+r2Base:  .word 0x00000000
+r3Base:  .word 0x08000000
+r4Base:  .word 0xF8000000
+r5Base:  .word 0x60000000
+r6Base:  .word 0x80000000
+r7Base:  .word 0xF0000000
+r8Base:  .word 0x00000000
+r9Base:  .word 0x00000000
+r10Base:  .word 0x00000000
+r11Base:  .word 0x00000000
+r12Base:  .word 0x00000000
+r13Base:  .word 0x00000000
+r14Base:  .word 0x00000000
+r15Base:  .word 0x00000000
+r16Base:  .word 0xFFF80000
2.35.3
