[PATCH 43/47] bsp/tms570: Board-specific tms570_pll_init()
Thu Dec 21 14:38:16 UTC 2023
 bsps/arm/tms570/include/bsp/tms570_hwinit.h   |  14 +-
 bsps/arm/tms570/start/hwinit-lc4357-hdk.c     | 139 ++++++++++++++++++
 bsps/arm/tms570/start/hwinit-ls3137-hdk.c     | 102 +++++++++++++
 bsps/arm/tms570/start/init_system.c           |  56 -------
 spec/build/bsps/arm/tms570/objhwinit.yml      |   9 +-
 .../bsps/arm/tms570/objhwinitlc4357hdk.yml    |  14 ++
 .../bsps/arm/tms570/objhwinitls3137hdk.yml    |  14 ++
 7 files changed, 287 insertions(+), 61 deletions(-)
 create mode 100644 bsps/arm/tms570/start/hwinit-lc4357-hdk.c
 create mode 100644 bsps/arm/tms570/start/hwinit-ls3137-hdk.c
 create mode 100644 spec/build/bsps/arm/tms570/objhwinitlc4357hdk.yml
 create mode 100644 spec/build/bsps/arm/tms570/objhwinitls3137hdk.yml
diff --git a/bsps/arm/tms570/include/bsp/tms570_hwinit.h b/bsps/arm/tms570/include/bsp/tms570_hwinit.h
index f23584f9b1..2a178ceb05 100644
--- a/bsps/arm/tms570/include/bsp/tms570_hwinit.h
+++ b/bsps/arm/tms570/include/bsp/tms570_hwinit.h
@@ -10,6 +10,7 @@
+ * Copyright (C) 2022 Airbus U.S. Space & Defense, Inc
  * Copyright (C) 2014 Premysl Houdek <kom541000 at gmail.com>
  * Google Summer of Code 2014 at
@@ -70,9 +71,7 @@ void _mpuInit_( void );
 void tms570_emif_sdram_init( void );
 void tms570_memory_init( uint32_t ram );
-void tms570_system_hw_init( void );
 void tms570_pinmux_init( void );
-void tms570_pll_init( void );
 void tms570_trim_lpo_init( void );
 void tms570_flash_init( void );
 void tms570_periph_init( void );
@@ -80,4 +79,15 @@ void tms570_map_clock_init( void );
 void tms570_esm_init( void );
+ * The following functions that must be implemented on a per-board basis for
+ * any BSP variant with hardware initialization.  These configure MCU
+ * peripherals that are specific to a particular board.
+ * @brief Initialize PLLs source divider/multipliers.
+void tms570_pll_init(void);
 #endif /* LIBBSP_ARM_TMS570_HWINIT_H */
diff --git a/bsps/arm/tms570/start/hwinit-lc4357-hdk.c b/bsps/arm/tms570/start/hwinit-lc4357-hdk.c
new file mode 100644
index 0000000000..6a8a2f1a86
--- /dev/null
+++ b/bsps/arm/tms570/start/hwinit-lc4357-hdk.c
@@ -0,0 +1,139 @@
+/* SPDX-License-Identifier: BSD-3-Clause */
+ * @file
+ * @ingroup RTEMSBSPsARMTMS570
+ * @brief This source file contains parts of the system initialization.
+ * Copyright (C) 2009-2015 Texas Instruments Incorporated - www.ti.com
+ *  Redistribution and use in source and binary forms, with or without
+ *  modification, are permitted provided that the following conditions
+ *  are met:
+ *    Redistributions of source code must retain the above copyright
+ *    Redistributions in binary form must reproduce the above copyright
+ *    documentation and/or other materials provided with the
+ *    distribution.
+ *    Neither the name of Texas Instruments Incorporated nor the names of
+ *    its contributors may be used to endorse or promote products derived
+ *    from this software without specific prior written permission.
+ *  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+ *  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+ *  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
+ *  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
+ *  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+ *  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
+ *  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
+ *  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
+ *  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
+ *  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
+ *  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+#include <bsp/tms570.h>
+#include <bsp/tms570_hwinit.h>
+typedef enum Tms570ClockDisableSources {
+    TMS570_CLKDIS_SRC_OSC  = 0x01, ///< External high-speed oscillator as clock source
+    TMS570_CLKDIS_SRC_PLL1 = 0x02,
+    TMS570_CLKDIS_SRC_RESERVED = 0x04, ///< reserved. not tied to actual clock source
+    TMS570_CLKDIS_SRC_EXT_CLK1 = 0x08,
+    TMS570_CLKDIS_SRC_LOW_FREQ_LPO = 0x10,
+    TMS570_CLKDIS_SRC_HIGH_FREQ_LPO = 0x20,
+    TMS570_CLKDIS_SRC_PLL2 = 0x40,
+    TMS570_CLKDIS_SRC_EXT_CLK2 = 0x80,
+} Tms570ClockDisableSources;
+// Source selection for G, H, and V clocks SYS1.GHVSRC reg
+typedef enum Tms570GhvClockSources {
+  TMS570_SYS_CLK_SRC_OSC = 0U,          /**< Alias for oscillator clock Source                */
+  TMS570_SYS_CLK_SRC_PLL1 = 1U,         /**< Alias for Pll1 clock Source                      */
+  TMS570_SYS_CLK_SRC_EXTERNAL1 = 3U,    /**< Alias for external clock Source                  */
+  TMS570_SYS_CLK_SRC_LPO_LOW = 4U,      /**< Alias for low power oscillator low clock Source  */
+  TMS570_SYS_CLK_SRC_LPO_HIGH = 5U,     /**< Alias for low power oscillator high clock Source */
+  TMS570_SYS_CLK_SRC_PLL2 = 6U,         /**< Alias for Pll2 clock Source                      */
+  TMS570_SYS_CLK_SRC_EXTERNAL2 = 7U,    /**< Alias for external 2 clock Source                */
+  TMS570_SYS_CLK_SRC_VCLK = 9U          /**< Alias for synchronous VCLK1 clock Source         */
+} Tms570GhvClockSources;
+ * @brief Setup all system PLLs (HCG:setupPLL)
+void tms570_pll_init( void )
+    //based on HalCoGen setupPLL method
+    uint32_t pll12_dis = TMS570_CLKDIS_SRC_PLL1 | TMS570_CLKDIS_SRC_PLL2;
+    /* Disable PLL1 and PLL2 */
+    TMS570_SYS1.CSDISSET = pll12_dis;
+    /*SAFETYMCUSW 28 D MR:NA <APPROVED> "Hardware status bit read check" */
+    while ( ( TMS570_SYS1.CSDIS & pll12_dis ) != pll12_dis ) {
+        /* Wait */
+    /* Clear Global Status Register */
+    TMS570_SYS1.GLBSTAT = 0x301U;
+    // Configure PLL control registers
+    /**   - Setup pll control register 1:
+     *     - Disable reset on oscillator slip (ROS)
+     *     - Enable bypass on pll slip
+     *        TODO: desired: switches to OSC when PLL slip detected
+     *     - setup Pll output clock divider to max before Lock
+     *     - Disable reset on oscillator fail
+     *     - Setup reference clock divider
+     *     - Setup Pll multiplier
+     *     - PLL1: 16MHz OSC in -> 300MHz PLL1 out
+    TMS570_SYS1.PLLCTL1 =  (TMS570_SYS1_PLLCTL1_ROS * 0)
+                        |  (uint32_t)0x40000000U
+                        |  TMS570_SYS1_PLLCTL1_PLLDIV(0x1F)
+                        |  (TMS570_SYS1_PLLCTL1_ROF * 0)
+                        |  TMS570_SYS1_PLLCTL1_REFCLKDIV(4U - 1U)
+                        |  TMS570_SYS1_PLLCTL1_PLLMUL((75U - 1U) << 8);
+    /**   - Setup pll control register 2
+     *     - Setup spreading rate
+     *     - Setup bandwidth adjustment
+     *     - Setup internal Pll output divider
+     *     - Setup spreading amount
+    TMS570_SYS1.PLLCTL2 =  ((uint32_t)255U << 22U)
+                        |  ((uint32_t)7U << 12U)
+                        |  ((uint32_t)(1U - 1U) << 9U)
+                        |  61U;
+    // Initialize Pll2
+    /**   - Setup pll2 control register :
+    TMS570_SYS2.PLLCTL3 = TMS570_SYS2_PLLCTL3_ODPLL2(1U - 1U)
+                        | TMS570_SYS2_PLLCTL3_PLLDIV2(0x1FU)
+                        | TMS570_SYS2_PLLCTL3_REFCLKDIV2(8U - 1U)
+                        | TMS570_SYS2_PLLCTL3_PLLMUL2(( 150U - 1U) << 8 );
+    // Enable PLL(s) to start up or Lock
+    // Enable all clock sources except the following
+    TMS570_SYS1.CSDIS = (TMS570_CLKDIS_SRC_EXT_CLK2 | TMS570_CLKDIS_SRC_EXT_CLK1 | TMS570_CLKDIS_SRC_RESERVED);
diff --git a/bsps/arm/tms570/start/hwinit-ls3137-hdk.c b/bsps/arm/tms570/start/hwinit-ls3137-hdk.c
index 0000000000..772352470f
--- /dev/null
+++ b/bsps/arm/tms570/start/hwinit-ls3137-hdk.c
@@ -0,0 +1,102 @@
+ * @file
+ *  are met:
+ *    distribution.
+  uint32_t pll12_dis = 0x42;
+    /* Wait */
+  TMS570_SYS1.GLBSTAT = TMS570_SYS1_GLBSTAT_FBSLIP |
+                        TMS570_SYS1_GLBSTAT_RFSLIP |
+                        TMS570_SYS1_GLBSTAT_OSCFAIL;
+  /** - Configure PLL control registers */
+  /** @b Initialize @b Pll1: */
+  /* Setup pll control register 1 */
+  TMS570_SYS1.PLLCTL1 = TMS570_SYS1_PLLCTL1_ROS * 0 |
+                        TMS570_SYS1_PLLCTL1_MASK_SLIP( 1 ) |
+                        TMS570_SYS1_PLLCTL1_PLLDIV( 0x1f ) | /* max value */
+                        TMS570_SYS1_PLLCTL1_ROF * 0 |
+                        TMS570_SYS1_PLLCTL1_REFCLKDIV( 6 - 1 ) |
+                        TMS570_SYS1_PLLCTL1_PLLMUL( ( 120 - 1 ) << 8 );
+  /* Setup pll control register 2 */
+  TMS570_SYS1.PLLCTL2 = TMS570_SYS1_PLLCTL2_FMENA * 0 |
+                        TMS570_SYS1_PLLCTL2_SPREADINGRATE( 255 ) |
+                        TMS570_SYS1_PLLCTL2_MULMOD( 7 ) |
+                        TMS570_SYS1_PLLCTL2_ODPLL( 2 - 1 ) |
+                        TMS570_SYS1_PLLCTL2_SPR_AMOUNT( 61 );
+  /** @b Initialize @b Pll2: */
+  /* Setup pll2 control register */
+  TMS570_SYS2.PLLCTL3 = TMS570_SYS2_PLLCTL3_ODPLL2( 2 - 1 ) |
+                        TMS570_SYS2_PLLCTL3_PLLDIV2( 0x1F ) | /* max value */
+                        TMS570_SYS2_PLLCTL3_REFCLKDIV2( 6 - 1 ) |
+                        TMS570_SYS2_PLLCTL3_PLLMUL2( ( 120 - 1 ) << 8 );
+  /** - Enable PLL(s) to start up or Lock */
+  TMS570_SYS1.CSDIS = 0x00000000 | /* CLKSR0 on */
+                      0x00000000 | /* CLKSR1 on */
+                      0x00000008 | /* CLKSR3 off */
+                      0x00000000 | /* CLKSR4 on */
+                      0x00000000 | /* CLKSR5 on */
+                      0x00000000 | /* CLKSR6 on */
+                      0x00000080;  /* CLKSR7 off */
diff --git a/bsps/arm/tms570/start/init_system.c b/bsps/arm/tms570/start/init_system.c
index a384959d4a..b5387bfbc2 100644
--- a/bsps/arm/tms570/start/init_system.c
+++ b/bsps/arm/tms570/start/init_system.c
@@ -50,62 +50,6 @@
 #include <bsp/tms570_selftest.h>
- * @brief Setup all system PLLs (HCG:setupPLL)
-  uint32_t pll12_dis = 0x42;
-  /* Disable PLL1 and PLL2 */
-  TMS570_SYS1.CSDISSET = pll12_dis;
-  /*SAFETYMCUSW 28 D MR:NA <APPROVED> "Hardware status bit read check" */
-  while ( ( TMS570_SYS1.CSDIS & pll12_dis ) != pll12_dis ) {
-    /* Wait */
-  /* Clear Global Status Register */
-  TMS570_SYS1.GLBSTAT = TMS570_SYS1_GLBSTAT_FBSLIP |
-                        TMS570_SYS1_GLBSTAT_RFSLIP |
-                        TMS570_SYS1_GLBSTAT_OSCFAIL;
-  /** - Configure PLL control registers */
-  /** @b Initialize @b Pll1: */
-  /* Setup pll control register 1 */
-  TMS570_SYS1.PLLCTL1 = TMS570_SYS1_PLLCTL1_ROS * 0 |
-                        TMS570_SYS1_PLLCTL1_MASK_SLIP( 1 ) |
-                        TMS570_SYS1_PLLCTL1_PLLDIV( 0x1f ) | /* max value */
-                        TMS570_SYS1_PLLCTL1_ROF * 0 |
-                        TMS570_SYS1_PLLCTL1_REFCLKDIV( 6 - 1 ) |
-                        TMS570_SYS1_PLLCTL1_PLLMUL( ( 120 - 1 ) << 8 );
-  /* Setup pll control register 2 */
-  TMS570_SYS1.PLLCTL2 = TMS570_SYS1_PLLCTL2_FMENA * 0 |
-                        TMS570_SYS1_PLLCTL2_SPREADINGRATE( 255 ) |
-                        TMS570_SYS1_PLLCTL2_MULMOD( 7 ) |
-                        TMS570_SYS1_PLLCTL2_ODPLL( 2 - 1 ) |
-                        TMS570_SYS1_PLLCTL2_SPR_AMOUNT( 61 );
-  /** @b Initialize @b Pll2: */
-  /* Setup pll2 control register */
-  TMS570_SYS2.PLLCTL3 = TMS570_SYS2_PLLCTL3_ODPLL2( 2 - 1 ) |
-                        TMS570_SYS2_PLLCTL3_PLLDIV2( 0x1F ) | /* max value */
-                        TMS570_SYS2_PLLCTL3_REFCLKDIV2( 6 - 1 ) |
-                        TMS570_SYS2_PLLCTL3_PLLMUL2( ( 120 - 1 ) << 8 );
-  /** - Enable PLL(s) to start up or Lock */
-  TMS570_SYS1.CSDIS = 0x00000000 | /* CLKSR0 on */
-                      0x00000000 | /* CLKSR1 on */
-                      0x00000008 | /* CLKSR3 off */
-                      0x00000000 | /* CLKSR4 on */
-                      0x00000000 | /* CLKSR5 on */
-                      0x00000000 | /* CLKSR6 on */
-                      0x00000080;  /* CLKSR7 off */
  * @brief Adjust Low-Frequency (LPO) oscilator (HCG:trimLPO)
diff --git a/spec/build/bsps/arm/tms570/objhwinit.yml b/spec/build/bsps/arm/tms570/objhwinit.yml
index 8cd5d0d393..f6c02ec1d9 100644
--- a/spec/build/bsps/arm/tms570/objhwinit.yml
+++ b/spec/build/bsps/arm/tms570/objhwinit.yml
@@ -5,14 +5,17 @@ copyrights:
 - Copyright (C) 2020 embedded brains GmbH & Co. KG
 cppflags: []
 cxxflags: []
-enabled-by:
-- TMS570_USE_HWINIT_STARTUP
+enabled-by: TMS570_USE_HWINIT_STARTUP
 includes: []
 install:
 - destination: ${BSP_INCLUDEDIR}/bsp/ti_herc
   source:
   - bsps/arm/tms570/include/bsp/ti_herc/errata_SSWF021_45.h
-links: []
+links:
+- role: build-dependency
+  uid: objhwinitls3137hdk
+  uid: objhwinitlc4357hdk
 source:
 - bsps/arm/tms570/start/bspstarthooks.c
 - bsps/arm/tms570/start/bspstarthooks-hwinit.c
diff --git a/spec/build/bsps/arm/tms570/objhwinitlc4357hdk.yml b/spec/build/bsps/arm/tms570/objhwinitlc4357hdk.yml
index 0000000000..1b91475804
--- /dev/null
+++ b/spec/build/bsps/arm/tms570/objhwinitlc4357hdk.yml
@@ -0,0 +1,14 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: objects
+cflags: []
+copyrights:
+- Copyright (C) 2023 embedded brains GmbH & Co. KG
+cppflags: []
+cxxflags: []
+enabled-by: arm/tms570lc4357_hdk
+includes: []
+install: []
+links: []
+source:
+- bsps/arm/tms570/start/hwinit-lc4357-hdk.c
+type: build
diff --git a/spec/build/bsps/arm/tms570/objhwinitls3137hdk.yml b/spec/build/bsps/arm/tms570/objhwinitls3137hdk.yml
index 0000000000..9971a0a86f
--- /dev/null
+++ b/spec/build/bsps/arm/tms570/objhwinitls3137hdk.yml
@@ -0,0 +1,14 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: arm/tms570ls3137_hdk
+includes: []
+install: []
+links: []
+source:
+- bsps/arm/tms570/start/hwinit-ls3137-hdk.c
+type: build
2.35.3
