RTEMS_SYSINIT_ITEM not working sometimes?
Mon Jul 3 07:13:28 UTC 2023
Hello Karel,
On 01.07.23 00:41, Karel Gardas wrote:
>    Hello,
> while working on STM32H7 I've noticed that rng is not working well.
> Tracked that down to stm32h7_rng_enable function not being properly
> called as it should be. The function call should be enforced by:
> RTEMS_SYSINIT_ITEM(
>    stm32h7_rng_enable,
>    RTEMS_SYSINIT_DEVICE_DRIVERS,
>    RTEMS_SYSINIT_ORDER_LAST_BUT_5
> but it is not. The problematic code is here:
> https://git.rtems.org/rtems/tree/bsps/arm/stm32h7/start/getentropy-rng.c
> So far it looks like linker is GCing whole file.
The linker garbage collection doesn't work on a file granularity. It
operates with linker input section. This is why we use the
-ffunction-sections and -fdata-sections GCC options.
> The only workaround for
> the issue which I've found so far is to add some "hook" function in the
> file and call that hook from BSP starting code. This way linker is
> enforced to link the file in and then RTEMS_SYSININT_ITEM is correctly
> doing its business.
Do you use a custom linker command file? It is important that the KEEP()
directive is used for the linker set:
KEEP (*(SORT(.rtemsroset.*)))
You can look at the linker map file to get more information about what
is going on.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
