[PATCH] spec: Add QEMU test annotations
Kinsey Moore kinsey.moore at oarcorp.com
Thu Jul 6 18:48:32 UTC 2023
QEMU is known to fail certain tests intermittently due to clock tick
delivery issues. This defines those tests as intermittent for BSPs
intended to run on QEMU alone.
Updates #4922
Updates #4072
 spec/build/bsps/aarch64/a53/tsta53.yml        | 33 +--------
 spec/build/bsps/aarch64/a72/tsta72.yml        | 33 +--------
 .../bsps/aarch64/xilinx-versal/tstqemu.yml    |  4 +-
 .../bsps/aarch64/xilinx-zynqmp/tstqemu.yml    | 33 +--------
 .../arm/realview-pbx-a9/bsprealviewpbxa9.yml  |  2 +
 spec/build/bsps/arm/xilinx-zynq/bspqemu.yml   |  2 +
 spec/build/bsps/tstqemu.yml                   | 72 +++++++++++++++++++
 7 files changed, 88 insertions(+), 91 deletions(-)
 create mode 100644 spec/build/bsps/tstqemu.yml
diff --git a/spec/build/bsps/aarch64/a53/tsta53.yml b/spec/build/bsps/aarch64/a53/tsta53.yml
index a3d8c9810d..adf6d85ae1 100644
--- a/spec/build/bsps/aarch64/a53/tsta53.yml
+++ b/spec/build/bsps/aarch64/a53/tsta53.yml
@@ -6,40 +6,13 @@ actions:
     state: exclude
     tests:
     - minimum
-- set-test-state:
-    reason: |
-      Tests that are passing intermittently.
-    state: indeterminate
-    tests:
-    - psx12
-    - psxtimes01
-    - rtmonuse
-    - rtmonusxtimes01
-    - sp04
-    - sp20
-    - sp68
-    - sp69
-    - spcpucounter01
-    - spedfsched02
-    - spedfsched04
-    - sprmsched01
-    - sptimecounter02
-    - sptimecounter04
-    - ttest02
-- set-test-state:
-    reason: |
-      Tests that pass nominally, but fail under Qemu when the host is under
-      heavy load.
-    tests:
-    - spintrcritical03
-    - spintrcritical04
-    - spintrcritical05
 build-type: option
 copyrights:
 - Copyright (C) 2020 On-Line Applications Research (OAR)
 default: []
 description: ''
 enabled-by: true
-links: []
+links:
+- role: build-dependency
+  uid: ../../tstqemu
 type: build
diff --git a/spec/build/bsps/aarch64/a72/tsta72.yml b/spec/build/bsps/aarch64/a72/tsta72.yml
--- a/spec/build/bsps/aarch64/a72/tsta72.yml
+++ b/spec/build/bsps/aarch64/a72/tsta72.yml
     state: exclude
     tests:
     - minimum
-- set-test-state:
-    reason: |
-    tests:
-    - psx12
-    - psxtimes01
-    - rtmonuse
-    - rtmonusxtimes01
-    - sp04
-    - sp20
-    - sp68
-    - sp69
-    - spcpucounter01
-    - spedfsched02
-    - spedfsched04
-    - sprmsched01
-    - sptimecounter02
-    - sptimecounter04
-    - ttest02
-- set-test-state:
-    reason: |
-      heavy load.
-    tests:
 build-type: option
 copyrights:
 default: []
 description: ''
 enabled-by: true
-links: []
+links:
 type: build
diff --git a/spec/build/bsps/aarch64/xilinx-versal/tstqemu.yml b/spec/build/bsps/aarch64/xilinx-versal/tstqemu.yml
index 0a0ab619af..69b85cadbd 100644
--- a/spec/build/bsps/aarch64/xilinx-versal/tstqemu.yml
+++ b/spec/build/bsps/aarch64/xilinx-versal/tstqemu.yml
@@ -12,5 +12,7 @@ copyrights:
 default: []
 description: ''
 enabled-by: true
-links: []
+links:
 type: build
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml
--- a/spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml
     state: exclude
     tests:
     - minimum
-- set-test-state:
-    reason: |
-    tests:
-    - psx12
-    - psxtimes01
-    - rtmonuse
-    - rtmonusxtimes01
-    - sp04
-    - sp20
-    - sp68
-    - sp69
-    - spcpucounter01
-    - spedfsched02
-    - spedfsched04
-    - sprmsched01
-    - sptimecounter02
-    - sptimecounter04
-    - ttest02
-- set-test-state:
-    reason: |
-      heavy load.
-    tests:
 build-type: option
 copyrights:
 default: []
 description: ''
 enabled-by: true
-links: []
+links:
 type: build
diff --git a/spec/build/bsps/arm/realview-pbx-a9/bsprealviewpbxa9.yml b/spec/build/bsps/arm/realview-pbx-a9/bsprealviewpbxa9.yml
index a6e4d5b1a9..4111830ce9 100644
--- a/spec/build/bsps/arm/realview-pbx-a9/bsprealviewpbxa9.yml
+++ b/spec/build/bsps/arm/realview-pbx-a9/bsprealviewpbxa9.yml
@@ -53,6 +53,8 @@ links:
   uid: ../../objmem
   uid: ../../opto0
   uid: ../../bspopts
 source:
diff --git a/spec/build/bsps/arm/xilinx-zynq/bspqemu.yml b/spec/build/bsps/arm/xilinx-zynq/bspqemu.yml
index 4780a9d64b..8068284d82 100644
--- a/spec/build/bsps/arm/xilinx-zynq/bspqemu.yml
+++ b/spec/build/bsps/arm/xilinx-zynq/bspqemu.yml
@@ -13,6 +13,8 @@ install: []
 links:
   uid: ../../opto2
   uid: grp
 source: []
diff --git a/spec/build/bsps/tstqemu.yml b/spec/build/bsps/tstqemu.yml
new file mode 100644
index 0000000000..3956cc4828
--- /dev/null
+++ b/spec/build/bsps/tstqemu.yml
@@ -0,0 +1,72 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+actions:
+- set-test-state:
+    reason: |
+      Tests that are passing intermittently due to #4922
+    state: indeterminate
+    tests:
+    - psx12
+    - psxclock
+    - psxtimes01
+    - psxualarm
+    - rtmonuse
+    - rtmonusxtimes01
+    - smpclock01
+    - smpfatal01
+    - smpfatal03
+    - smpmrsp01
+    - smpmutex01
+    - smppsxmutex01
+    - smpschedaffinity01
+    - smpschedaffinity02
+    - smpschededf01
+    - smpschededf03
+    - smpscheduler04
+    - smpthreadpin01
+    - sp04
+    - sp20
+    - sp68
+    - sp69
+    - sp71
+    - spcpucounter01
+    - spedfsched02
+    - spedfsched04
+    - spintrcritical01
+    - spintrcritical02
+    - spintrcritical03
+    - spintrcritical04
+    - spintrcritical05
+    - spintrcritical06
+    - spintrcritical07
+    - spintrcritical08
+    - spintrcritical09
+    - spintrcritical10
+    - spintrcritical11
+    - spintrcritical12
+    - spintrcritical13
+    - spintrcritical14
+    - spintrcritical15
+    - spintrcritical16
+    - spintrcritical17
+    - spintrcritical18
+    - spintrcritical19
+    - spintrcritical20
+    - spintrcritical21
+    - spintrcritical22
+    - spintrcritical23
+    - spintrcritical24
+    - sprmsched01
+    - sptimecounter01
+    - sptimecounter02
+    - sptimecounter04
+    - ttest02
+    - validation-0
+    - validation-smp-only-0
+build-type: option
+copyrights:
+- Copyright (C) 2023 On-Line Applications Research (OAR)
+default: []
+description: ''
+enabled-by: true
+links: []
+type: build
2.30.2
