[PATCH] spec: Add QEMU test annotations
Fri Jul 7 17:04:17 UTC 2023
On Thu, Jul 6, 2023 at 12:48 PM Kinsey Moore <kinsey.moore at oarcorp.com> wrote:
> QEMU is known to fail certain tests intermittently due to clock tick
> delivery issues. This defines those tests as intermittent for BSPs
> intended to run on QEMU alone.
> Updates #4922
> Updates #4072
>  spec/build/bsps/aarch64/a53/tsta53.yml        | 33 +--------
>  spec/build/bsps/aarch64/a72/tsta72.yml        | 33 +--------
>  .../bsps/aarch64/xilinx-versal/tstqemu.yml    |  4 +-
>  .../bsps/aarch64/xilinx-zynqmp/tstqemu.yml    | 33 +--------
>  .../arm/realview-pbx-a9/bsprealviewpbxa9.yml  |  2 +
>  spec/build/bsps/arm/xilinx-zynq/bspqemu.yml   |  2 +
>  spec/build/bsps/tstqemu.yml                   | 72 +++++++++++++++++++
>  7 files changed, 88 insertions(+), 91 deletions(-)
>  create mode 100644 spec/build/bsps/tstqemu.yml
> diff --git a/spec/build/bsps/aarch64/a53/tsta53.yml b/spec/build/bsps/aarch64/a53/tsta53.yml
> index a3d8c9810d..adf6d85ae1 100644
> --- a/spec/build/bsps/aarch64/a53/tsta53.yml
> +++ b/spec/build/bsps/aarch64/a53/tsta53.yml
> @@ -6,40 +6,13 @@ actions:
>      state: exclude
>      tests:
>      - minimum
> -- set-test-state:
> -    reason: |
> -      Tests that are passing intermittently.
> -    state: indeterminate
> -    tests:
> -    - psx12
> -    - psxtimes01
> -    - rtmonuse
> -    - rtmonusxtimes01
> -    - sp04
> -    - sp20
> -    - sp68
> -    - sp69
> -    - spcpucounter01
> -    - spedfsched02
> -    - spedfsched04
> -    - sprmsched01
> -    - sptimecounter02
> -    - sptimecounter04
> -    - ttest02
> -- set-test-state:
> -    reason: |
> -      Tests that pass nominally, but fail under Qemu when the host is under
> -      heavy load.
> -    tests:
> -    - spintrcritical03
> -    - spintrcritical04
> -    - spintrcritical05
>  build-type: option
>  copyrights:
>  - Copyright (C) 2020 On-Line Applications Research (OAR)
>  default: []
>  description: ''
>  enabled-by: true
> -links: []
> +links:
> +- role: build-dependency
> +  uid: ../../tstqemu
>  type: build
> diff --git a/spec/build/bsps/aarch64/a72/tsta72.yml b/spec/build/bsps/aarch64/a72/tsta72.yml
> --- a/spec/build/bsps/aarch64/a72/tsta72.yml
> +++ b/spec/build/bsps/aarch64/a72/tsta72.yml
>      state: exclude
>      tests:
>      - minimum
> -- set-test-state:
> -    reason: |
> -    tests:
> -    - psx12
> -    - psxtimes01
> -    - rtmonuse
> -    - rtmonusxtimes01
> -    - sp04
> -    - sp20
> -    - sp68
> -    - sp69
> -    - spcpucounter01
> -    - spedfsched02
> -    - spedfsched04
> -    - sprmsched01
> -    - sptimecounter02
> -    - sptimecounter04
> -    - ttest02
> -- set-test-state:
> -    reason: |
> -      heavy load.
> -    tests:
>  build-type: option
>  copyrights:
>  default: []
>  description: ''
>  enabled-by: true
> -links: []
> +links:
>  type: build
> diff --git a/spec/build/bsps/aarch64/xilinx-versal/tstqemu.yml b/spec/build/bsps/aarch64/xilinx-versal/tstqemu.yml
> index 0a0ab619af..69b85cadbd 100644
> --- a/spec/build/bsps/aarch64/xilinx-versal/tstqemu.yml
> +++ b/spec/build/bsps/aarch64/xilinx-versal/tstqemu.yml
> @@ -12,5 +12,7 @@ copyrights:
>  default: []
>  description: ''
>  enabled-by: true
> -links: []
> +links:
>  type: build
> diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml
> --- a/spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml
> +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml
>      state: exclude
>      tests:
>      - minimum
> -- set-test-state:
> -    reason: |
> -    tests:
> -    - psx12
> -    - psxtimes01
> -    - rtmonuse
> -    - rtmonusxtimes01
> -    - sp04
> -    - sp20
> -    - sp68
> -    - sp69
> -    - spcpucounter01
> -    - spedfsched02
> -    - spedfsched04
> -    - sprmsched01
> -    - sptimecounter02
> -    - sptimecounter04
> -    - ttest02
> -- set-test-state:
> -    reason: |
> -      heavy load.
> -    tests:
>  build-type: option
>  copyrights:
>  default: []
>  description: ''
>  enabled-by: true
> -links: []
> +links:
>  type: build
> diff --git a/spec/build/bsps/arm/realview-pbx-a9/bsprealviewpbxa9.yml b/spec/build/bsps/arm/realview-pbx-a9/bsprealviewpbxa9.yml
> index a6e4d5b1a9..4111830ce9 100644
> --- a/spec/build/bsps/arm/realview-pbx-a9/bsprealviewpbxa9.yml
> +++ b/spec/build/bsps/arm/realview-pbx-a9/bsprealviewpbxa9.yml
> @@ -53,6 +53,8 @@ links:
>    uid: ../../objmem
>    uid: ../../opto0
>    uid: ../../bspopts
>  source:
> diff --git a/spec/build/bsps/arm/xilinx-zynq/bspqemu.yml b/spec/build/bsps/arm/xilinx-zynq/bspqemu.yml
> index 4780a9d64b..8068284d82 100644
> --- a/spec/build/bsps/arm/xilinx-zynq/bspqemu.yml
> +++ b/spec/build/bsps/arm/xilinx-zynq/bspqemu.yml
> @@ -13,6 +13,8 @@ install: []
>  links:
>    uid: ../../opto2
>    uid: grp
>  source: []
> diff --git a/spec/build/bsps/tstqemu.yml b/spec/build/bsps/tstqemu.yml
> new file mode 100644
> index 0000000000..3956cc4828
> --- /dev/null
> +++ b/spec/build/bsps/tstqemu.yml
> @@ -0,0 +1,72 @@
> +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> +actions:
> +- set-test-state:
> +    reason: |
> +      Tests that are passing intermittently due to #4922
> +    state: indeterminate
> +    tests:
> +    - psx12
> +    - psxclock
> +    - psxtimes01
> +    - psxualarm
> +    - rtmonuse
> +    - rtmonusxtimes01
> +    - smpclock01
> +    - smpfatal01
> +    - smpfatal03
> +    - smpmrsp01
> +    - smpmutex01
> +    - smppsxmutex01
> +    - smpschedaffinity01
> +    - smpschedaffinity02
> +    - smpschededf01
> +    - smpschededf03
> +    - smpscheduler04
> +    - smpthreadpin01
> +    - sp04
> +    - sp20
> +    - sp68
> +    - sp69
> +    - sp71
> +    - spcpucounter01
> +    - spedfsched02
> +    - spedfsched04
> +    - spintrcritical01
> +    - spintrcritical02
> +    - spintrcritical03
> +    - spintrcritical04
> +    - spintrcritical05
> +    - spintrcritical06
> +    - spintrcritical07
> +    - spintrcritical08
> +    - spintrcritical09
> +    - spintrcritical10
> +    - spintrcritical11
> +    - spintrcritical12
> +    - spintrcritical13
> +    - spintrcritical14
> +    - spintrcritical15
> +    - spintrcritical16
> +    - spintrcritical17
> +    - spintrcritical18
> +    - spintrcritical19
> +    - spintrcritical20
> +    - spintrcritical21
> +    - spintrcritical22
> +    - spintrcritical23
> +    - spintrcritical24
> +    - sprmsched01
> +    - sptimecounter01
> +    - sptimecounter02
> +    - sptimecounter04
> +    - ttest02
> +    - validation-0
> +    - validation-smp-only-0
This looks OK to me, but it looks like you've added a lot more tests
than just the union of the existing ones in the individual BSPs. I
take it that you have found more variance in these tests also?
> +build-type: option
> +copyrights:
> +- Copyright (C) 2023 On-Line Applications Research (OAR)
> +default: []
> +description: ''
> +enabled-by: true
> +links: []
> +type: build
> 2.30.2
> devel mailing list
> devel at rtems.org
