[PATCH rtems-source-builder] bare/config: add renode rsb installation config
Muhammad Sulthan Mazaya msulthanmazaya at gmail.com
Tue Jul 11 19:18:58 UTC 2023
> Probably want to put most of this file into
> ./source-builder/config/renode-common-1.cfg
> and set parameters for it (version) from a new file
> ./bare/config/devel/renode-1.13.3-1.cfg
okay, I will revise this, thanks for the suggestion
 > > +  ./build.sh
> This looks brittle. Does their script handle host detection, etc?
The script does handle host detection, etc:
https://github.com/renode/renode/blob/master/build.sh#L212
 > > +++ b/bare/config/devel/renode.bset
> Add the version to the build set name and pass that through to the
> build instructions.
 > > +devel/renode-git-1
> the "-git" name is usually used to build the git head or a specific commit.
> SInce you build a release version, you should prefer to use the
> version numbering to identify what gets built.
On Wed, Jul 12, 2023 at 4:17 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Tue, Jul 11, 2023 at 12:01 PM Gedare Bloom <gedare at rtems.org> wrote:
> > This probably requires some documentation, as it requires several
> > packages that are not going to be typically installed already by RTEMS
> > users/developers. Chris, is there any place to document required
> > dependencies/packages for a build set?
> > The patch has a whitespace problem
> > +# Renode source
> >  It might be a non-ASCII character, as it gets eaten by email but is
> > in the patch file.
> > Gedare
> > On Mon, Jul 10, 2023 at 5:13 AM Muhammad Sulthan Mazaya
> > <msulthanmazaya at gmail.com> wrote:
> > > An implementation of renode rsb installation config. It uses renode's
> > > github release as source and build the package using their build
> script.
> > >  bare/config/devel/renode-git-1.cfg | 47 ++++++++++++++++++++++++++++++
> > >  bare/config/devel/renode.bset      |  9 ++++++
> > >  2 files changed, 56 insertions(+)
> > >  create mode 100644 bare/config/devel/renode-git-1.cfg
> > >  create mode 100644 bare/config/devel/renode.bset
> > > diff --git a/bare/config/devel/renode-git-1.cfg
> b/bare/config/devel/renode-git-1.cfg
> > > new file mode 100644
> > > index 0000000..df424a6
> > > --- /dev/null
> > > +++ b/bare/config/devel/renode-git-1.cfg
> I would recommend that you follow the design for how qemu gets built.
> > > @@ -0,0 +1,47 @@
> > > +# Renode from github
> > > +%if %{release} == %{nil}
> > > + %define release 1
> > > +%endif
> > > +%define renode_version 1.13.3
> > > +Name:      renode-%{renode_version}-%{_host}-%{release}
> > > +Summary:   Renode v%{renode_version}
> > > +Version:   %{renode_version}
> > > +Release:   %{release}
> > > +URL:      http://www.renode.io
> > > +# Renode source
> > > +%source set renode
> https://github.com/renode/renode/releases/download/v%{renode_version}/renode_%{renode_version}_source.tar.xz
> > > +# Prepare the source code.
> > > +%prep
> > > +  build_top=$(pwd)
> > > +  source_dir_renode="renode_%{renode_version}_source"
> > > +  %source setup renode -q -n renode_%{renode_version}_source
> > > +  cd ${build_top}
> > > +%build
> > > +  build_top=$(pwd)
> > > +  cd ${source_dir_renode}
> > > +  ./build.sh
> > > +  cd ${build_top}
> > > +%install
> > > +  build_top=$(pwd)
> > > +  mkdir -p %{_bindir}
> > > +  cp -r ./${source_dir_renode}/* %{_bindir}
> > > +  cd ${build_top}
> > > diff --git a/bare/config/devel/renode.bset
> > > index 0000000..d64a2a2
> > > --- /dev/null
> build instructions.
> > > @@ -0,0 +1,9 @@
> > > +# Build set for Renode
> > > +    %define release 1
> > > +%endif
> > > +devel/renode-git-1
> > > 2.34.1
> > > _______________________________________________
> > > devel mailing list
> > > devel at rtems.org
> > > http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230712/9a37e7ef/attachment-0001.htm>
