[PATCH rtems-source-builder] bare/config: add renode rsb installation config
Wed Jul 12 13:42:23 UTC 2023
On Tue, Jul 11, 2023 at 1:01 PM Gedare Bloom <gedare at rtems.org> wrote:
> This probably requires some documentation, as it requires several
> packages that are not going to be typically installed already by RTEMS
> users/developers. Chris, is there any place to document required
> dependencies/packages for a build set?
The Users Guide obviously does the base set required commonly
but a section on Requirements for Renode.io would probably be the
right way to go.
Also sb-check checks for program executables being present. I don't know
if we have any way to say program X is used by Y. For example, the newer
qemu versions use some other build program that I didn't have installed and
can't remember right now.
--joel
> The patch has a whitespace problem
> +# Renode source
>  It might be a non-ASCII character, as it gets eaten by email but is
> in the patch file.
> Gedare
> On Mon, Jul 10, 2023 at 5:13 AM Muhammad Sulthan Mazaya
> <msulthanmazaya at gmail.com> wrote:
> > An implementation of renode rsb installation config. It uses renode's
> > github release as source and build the package using their build script.
> >  bare/config/devel/renode-git-1.cfg | 47 ++++++++++++++++++++++++++++++
> >  bare/config/devel/renode.bset      |  9 ++++++
> >  2 files changed, 56 insertions(+)
> >  create mode 100644 bare/config/devel/renode-git-1.cfg
> >  create mode 100644 bare/config/devel/renode.bset
> > diff --git a/bare/config/devel/renode-git-1.cfg
> b/bare/config/devel/renode-git-1.cfg
> > new file mode 100644
> > index 0000000..df424a6
> > --- /dev/null
> > +++ b/bare/config/devel/renode-git-1.cfg
> > @@ -0,0 +1,47 @@
> > +# Renode from github
> > +%if %{release} == %{nil}
> > + %define release 1
> > +%endif
> > +%define renode_version 1.13.3
> > +Name:      renode-%{renode_version}-%{_host}-%{release}
> > +Summary:   Renode v%{renode_version}
> > +Version:   %{renode_version}
> > +Release:   %{release}
> > +URL:      http://www.renode.io
> > +# Renode source
> > +%source set renode
> https://github.com/renode/renode/releases/download/v%{renode_version}/renode_%{renode_version}_source.tar.xz
> > +# Prepare the source code.
> > +%prep
> > +  build_top=$(pwd)
> > +  source_dir_renode="renode_%{renode_version}_source"
> > +  %source setup renode -q -n renode_%{renode_version}_source
> > +  cd ${build_top}
> > +%build
> > +  build_top=$(pwd)
> > +  cd ${source_dir_renode}
> > +  ./build.sh
> > +  cd ${build_top}
> > +%install
> > +  build_top=$(pwd)
> > +  mkdir -p %{_bindir}
> > +  cp -r ./${source_dir_renode}/* %{_bindir}
> > +  cd ${build_top}
> > diff --git a/bare/config/devel/renode.bset
> b/bare/config/devel/renode.bset
> > index 0000000..d64a2a2
> > --- /dev/null
> > +++ b/bare/config/devel/renode.bset
> > @@ -0,0 +1,9 @@
> > +# Build set for Renode
> > +    %define release 1
> > +%endif
> > +devel/renode-git-1
> > 2.34.1
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230712/f41bf01e/attachment.htm>
