[PATCH rtems 6/6] bsps/imxrt: Add imxrt1166_cm7_saltshaker BSP
Christian MAUDERER christian.mauderer at embedded-brains.de
Fri Jul 14 06:36:10 UTC 2023
Hello Jacob,
On 2023-07-13 18:59, Jacob Killelea wrote:
> Hi Christian,
> This looks awesome! Do you have any interest in adding support for the
> i.MXRT1062 based Teensy 4.0 and Teensy 4.1?
> - Jacob
the Teensy look like interesting boards. Maybe a bit low on memory. That
would make it difficult to run libbsd on them. The boards don't have
network, so it's not a problem for the network part. But on the i.MXRT,
I also use the MMC/SD stack from libbsd so the SD card would be a problem.
On the Teensy 4.1, the two memories (optional Flash and optional PSRAM)
on the FlexSPI maybe can be a bit tricky.
These boards would be pure hobby time. I don't think that I will find
enough time to fully support the boards at the moment. But I would
expect that the basics should work with the i.MXRT1052 BSP already. The
1050 and 1060 family is quite similar. If you want, I can give you some
guidance what would be necessary to support the boards.
Best regards
Christian
embedded brains GmbH & Co. KG
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
email:  christian.mauderer at embedded-brains.de
phone:  +49-89-18 94 741 - 18
mobile: +49-176-152 206 08
Registernummer: HRA 117265
