[PATCH rtems 6/6] bsps/imxrt: Add imxrt1166_cm7_saltshaker BSP
Christian MAUDERER christian.mauderer at embedded-brains.de
Fri Jul 14 07:08:56 UTC 2023
Hello Jacob,
On 2023-07-14 08:36, Christian MAUDERER wrote:
> Hello Jacob,
> On 2023-07-13 18:59, Jacob Killelea wrote:
>> Hi Christian,
>> This looks awesome! Do you have any interest in adding support for the
>> i.MXRT1062 based Teensy 4.0 and Teensy 4.1?
>> - Jacob
> the Teensy look like interesting boards. Maybe a bit low on memory. That
> would make it difficult to run libbsd on them. The boards don't have
> network, so it's not a problem for the network part. But on the i.MXRT,
> I also use the MMC/SD stack from libbsd so the SD card would be a problem.
Just noted: The Teensy 4.1 has an optional Ethernet. So some network
library would be good. But like I said: The target has too few memory
for libbsd. lwIP would be a candidate. But I haven't tried that on the
i.MXRT yet.
Best regards
Christian
> On the Teensy 4.1, the two memories (optional Flash and optional PSRAM)
> on the FlexSPI maybe can be a bit tricky.
> These boards would be pure hobby time. I don't think that I will find
> enough time to fully support the boards at the moment. But I would
> expect that the basics should work with the i.MXRT1052 BSP already. The
> 1050 and 1060 family is quite similar. If you want, I can give you some
> guidance what would be necessary to support the boards.
> Best regards
> Christian
embedded brains GmbH & Co. KG
Herr Christian MAUDERER
Dornierstr. 4
82178 Puchheim
Germany
email:  christian.mauderer at embedded-brains.de
phone:  +49-89-18 94 741 - 18
mobile: +49-176-152 206 08
Registernummer: HRA 117265
