grlib changes Fwd: New Defects reported by Coverity Scan for RTEMS
Mon Jul 17 19:11:52 UTC 2023
On Mon, Jul 17, 2023 at 1:15 PM Gedare Bloom <gedare at rtems.org> wrote:
> Sebastian fixed it now. The local variable was shadowed. Another good
> reason to keep local variables at the start of a function ;)
+1
The first time I saw GCC spit this warning out was for some particularly
horrible code. It had shadowed global variables and parameters.
And we should get a Coverity email which says it is fixed. :)
--joel
> On Sat, Jul 15, 2023 at 9:38 AM Joel Sherrill <joel at rtems.org> wrote:
> > The recent grlib changes introduced a Coverity issues.
> > ---------- Forwarded message ---------
> > From: <scan-admin at coverity.com>
> > Date: Sat, Jul 15, 2023 at 12:22 AM
> > Subject: New Defects reported by Coverity Scan for RTEMS
> > To: <build at rtems.org>
> > Hi,
> > Please find the latest report on new defect(s) introduced to RTEMS found
> with Coverity Scan.
> > 1 new defect(s) introduced to RTEMS found with Coverity Scan.
> > New defect(s) Reported-by: Coverity Scan
> > Showing 1 of 1 defect(s)
> > ** CID 1538314:  Uninitialized variables  (UNINIT)
> > /bsps/shared/grlib/uart/apbuart_cons.c: 448 in first_open()
> ________________________________________________________________________________________________________
> > *** CID 1538314:  Uninitialized variables  (UNINIT)
> > 442                             return false;
> > 443                     }
> > 444
> > 445                     uart->sending = 0;
> > 446
> > 447                     /* Turn on RX interrupts */
> > >>>     Using uninitialized value "ctrl".
> > 448                     ctrl |= APBUART_CTRL_RI;
> > 449                     if (uart->cap & CAP_DI) {
> > 450                             /* Use RX FIFO interrupt only if delayed
> interrupt available. */
> > 451                             ctrl |= (APBUART_CTRL_DI |
> APBUART_CTRL_RF);
> > 452                     }
> > 453             }
> > To view the defects in Coverity Scan visit,
> https://u15810271.ct.sendgrid.net/ls/click?upn=HRESupC-2F2Czv4BOaCWWCy7my0P0qcxCbhZ31OYv50ypUUzi-2FdSNmuyRB7BEFT8xQ4-2B8hpujh0hTgQljRGId4Dg-3D-3DHAM__EU3W9teASMK00lBXX9WT4lsogDrkCcNZLvg-2FVxwAXMo-2BfWe9y-2FQVPI3NBuKOOB9pEF0PWPhWQO6FUVOcAwwdagvzNKH7AA8SymQIigXNwofEBIHyLL-2FrZJgQDgEg0O4g4HS-2FjBhvvcGAhWWb-2FxsDZrRDyXAMAUd-2BRwY7jJKszizp8zBz7IR2apEMP0z49hqJcf-2F9hLs1Dn-2B7C8NzR5v-2Bdg-3D-3D
> > build mailing list
> > build at rtems.org
> > http://lists.rtems.org/mailman/listinfo/build
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230717/040112fe/attachment.htm>
