[rtems-docs] user/bsp-build: Fix typo in BSP set builder command
Zainab Olalekan ztolalekan at outlook.com
Tue Jul 18 20:25:26 UTC 2023
changed bsp to arch/bsp
 user/start/bsp-build.rst | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/user/start/bsp-build.rst b/user/start/bsp-build.rst
index c62b6ba..962cd43 100644
--- a/user/start/bsp-build.rst
+++ b/user/start/bsp-build.rst
@@ -45,7 +45,7 @@ To build the BSP with all the tests run this command:
     cd $HOME/quick-start/src/rsb/rtems
     ../source-builder/sb-set-builder --prefix=$HOME/quick-start/rtems/5 \
-        --target=sparc-rtems at rtems-ver-major@ --with-rtems-bsp=erc32 --with-rtems-tests=yes @rtems-ver-major@/rtems-kernel
+        --target=sparc-rtems at rtems-ver-major@ --with-rtems-bsp=sparc/erc32 --with-rtems-tests=yes @rtems-ver-major@/rtems-kernel
 This command should output something like:
2.39.3
