[PATCH] doxgen: Document build system provided files
Thu Jul 20 17:13:16 UTC 2023
On Thu, Jul 20, 2023 at 7:20 AM Sebastian Huber
> Update #3707.
>  cpukit/doxygen/build.h | 82 ++++++++++++++++++++++++++++++++++++++++++
>  1 file changed, 82 insertions(+)
>  create mode 100644 cpukit/doxygen/build.h
> diff --git a/cpukit/doxygen/build.h b/cpukit/doxygen/build.h
> new file mode 100644
> index 0000000000..e76c173eb8
> --- /dev/null
> +++ b/cpukit/doxygen/build.h
> @@ -0,0 +1,82 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
> + * @file
> + * @ingroup RTEMSImplDoxygen
> + * @brief This header file defines build system related Doxygen items.
> + * Copyright (C) 2023 embedded brains GmbH (http://www.embedded-brains.de)
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> + * @defgroup RTEMSImplBuild Build Options
> + * @brief This group contains files provided by the build system.
May be better:
provided -> generated
> + * @ingroup RTEMSImplBuild
> + * @file bsps/include/bspopts.h
> + * @brief This header file provides the BSP options definitions.
> + * @file cpukit/include/version-vc-key.h
> + * @brief This header file provides the version control key definitions.
> + * @file cpukit/include/config.h
> + * @brief This header file provides system configuration definitions.
> + * @file cpukit/include/rtems/testopts.h
> + * @brief This header file provides test program definitions.
> + * @file cpukit/include/rtems/score/cpuopts.h
> + * @brief This header file provides the CPU options definitions.
> 2.35.3
> devel mailing list
> devel at rtems.org
