[PATCH] doxgen: Document build system provided files
Thu Jul 20 13:20:04 UTC 2023
Update #3707.
 cpukit/doxygen/build.h | 82 ++++++++++++++++++++++++++++++++++++++++++
 1 file changed, 82 insertions(+)
 create mode 100644 cpukit/doxygen/build.h
diff --git a/cpukit/doxygen/build.h b/cpukit/doxygen/build.h
new file mode 100644
index 0000000000..e76c173eb8
--- /dev/null
+++ b/cpukit/doxygen/build.h
@@ -0,0 +1,82 @@
+ * @file
+ * @ingroup RTEMSImplDoxygen
+ * @brief This header file defines build system related Doxygen items.
+ * Copyright (C) 2023 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * @defgroup RTEMSImplBuild Build Options
+ * @brief This group contains files provided by the build system.
+ * @ingroup RTEMSImplBuild
+ * @file bsps/include/bspopts.h
+ * @brief This header file provides the BSP options definitions.
+ * @file cpukit/include/version-vc-key.h
+ * @brief This header file provides the version control key definitions.
+ * @file cpukit/include/config.h
+ * @brief This header file provides system configuration definitions.
+ * @file cpukit/include/rtems/testopts.h
+ * @brief This header file provides test program definitions.
+ * @file cpukit/include/rtems/score/cpuopts.h
+ * @brief This header file provides the CPU options definitions.
2.35.3
