[PATCH] c-user: Add glossary terms for SPARC targets
Thu Jul 20 17:14:20 UTC 2023
ok
On Thu, Jul 20, 2023 at 6:48 AM Sebastian Huber
>  c-user/glossary.rst | 30 ++++++++++++++++++++++++++++++
>  1 file changed, 30 insertions(+)
> diff --git a/c-user/glossary.rst b/c-user/glossary.rst
> index 6102d88..df3b9a3 100644
> --- a/c-user/glossary.rst
> +++ b/c-user/glossary.rst
> @@ -382,6 +382,18 @@ Glossary
>      GNU
>          This term is an acronym for `GNU's Not Unix <https://www.gnu.org/>`_.
> +    GR712RC
> +        The
> +        `GR712RC <https://www.gaisler.com/index.php/products/components/gr712rc>`_
> +        is a :term:`system-on-chip` containing two processors of the :term:`SPARC`
> +        :term:`target architecture`.
> +    GR740
> +        The
> +        `GR740 <https://www.gaisler.com/index.php/products/components/gr740>`_
> +        is a :term:`system-on-chip` containing four processors of the :term:`SPARC`
>      handler
>          The equivalent of a manager, except that it is internal to RTEMS and
>          forms part of the core.  A handler is a collection of routines which
> @@ -905,6 +917,10 @@ Glossary
>          A thirty-two bit entity which is used to represent a task's collection of
>          pending signals and the signals sent to a task.
> +    SIS
> +        This term is an acronym for Simple Instruction Simulator.  The SIS is a
> +        :term:`SPARC` V7/V8 and RISC-V RV32IMACFD :term:`target architecture` simulator.
>      SMCB
>          This term is an acronym for :term:`Semaphore Control Block`.
> @@ -982,6 +998,11 @@ Glossary
>          software as it is originally written (i.e., typed into a computer) by a
>          human in plain text (i.e., human readable alphanumeric characters)."
> +    SPARC
> +        `Scalable Processor ARChitecture <https://en.wikipedia.org/wiki/SPARC>`_.
> +        See also :term:`target architecture`.
>      sporadic task
>          A task which executes at irregular intervals and must comply with a hard
>          deadline.  A minimum period of time between successive iterations of the
> @@ -1019,6 +1040,15 @@ Glossary
>      system call
>          In this document, this is used as an alternate term for directive.
> +    system-on-chip
> +        This project uses the `system on a chip definition of Wikipedia
> +        <https://en.wikipedia.org/wiki/System_on_a_chip>`_: "A system on a chip or
> +        system-on-chip is an integrated circuit that integrates most or all
> +        components of a computer or other electronic system."
> +        Systems on a chip are :term:`target` systems for applications using
> +        :term:`RTEMS`.
>      target
>          The system on which the application will ultimately execute.
> 2.35.3
> devel mailing list
> devel at rtems.org
