[PATCH rtems-source-builder v3] bare/config: add renode rsb installation config
Fri Jul 21 00:48:05 UTC 2023
OK to push.
On 21/7/2023 8:05 am, Muhammad Sulthan Mazaya wrote:
> Change file name based on Chris's review here
> https://lists.rtems.org/pipermail/devel/2023-July/075802.html
> Plus, fix `cp` so that it also include dotfiles. Because without the
> the `.renode-root` file the command won't work.
>  bare/config/devel/renode-1.13.3-1.cfg     | 11 ++++++
>  bare/config/devel/renode.bset             |  7 ++++
>  source-builder/config/renode-1.cfg        |  6 +++
>  source-builder/config/renode-common-1.cfg | 45 +++++++++++++++++++++++
>  4 files changed, 69 insertions(+)
>  create mode 100644 bare/config/devel/renode-1.13.3-1.cfg
>  create mode 100644 bare/config/devel/renode.bset
>  create mode 100644 source-builder/config/renode-1.cfg
>  create mode 100644 source-builder/config/renode-common-1.cfg
> diff --git a/bare/config/devel/renode-1.13.3-1.cfg b/bare/config/devel/renode-1.13.3-1.cfg
> new file mode 100644
> index 0000000..3b0b65f
> --- /dev/null
> +++ b/bare/config/devel/renode-1.13.3-1.cfg
> @@ -0,0 +1,11 @@
> +# Renode from Github release
> +%if %{release} == %{nil}
> + %define release 1
> +%endif
> +%define renode_version 1.13.3
> +%include %{_configdir}/renode-1.cfg
> diff --git a/bare/config/devel/renode.bset b/bare/config/devel/renode.bset
> index 0000000..f89168d
> --- /dev/null
> +++ b/bare/config/devel/renode.bset
> @@ -0,0 +1,7 @@
> +# Build set for Renode
> +%define release 1
> +devel/renode-1.13.3-1
> diff --git a/source-builder/config/renode-1.cfg b/source-builder/config/renode-1.cfg
> index 0000000..b203797
> --- /dev/null
> +++ b/source-builder/config/renode-1.cfg
> @@ -0,0 +1,6 @@
> +# This configuration file configure's, make's and install's Renode.
> +%include %{_configdir}/renode-common-1.cfg
> diff --git a/source-builder/config/renode-common-1.cfg b/source-builder/config/renode-common-1.cfg
> index 0000000..5c50298
> --- /dev/null
> +++ b/source-builder/config/renode-common-1.cfg
> @@ -0,0 +1,45 @@
> + %define release 1
> +%endif
> +Name:      renode-%{renode_version}-%{_host}-%{release}
> +Summary:   Renode v%{renode_version}
> +Version:   %{renode_version}
> +Release:   %{release}
> +URL: 	   http://www.renode.io
> +# Renode source
> +%source set renode https://github.com/renode/renode/releases/download/v%{renode_version}/renode_%{renode_version}_source.tar.xz
> +# Prepare the source code.
> +%prep
> +  build_top=$(pwd)
> +  source_dir_renode="renode_%{renode_version}_source"
> +  %source setup renode -q -n renode_%{renode_version}_source
> +  cd ${build_top}
> +%build
> +  build_top=$(pwd)
> +  cd ${source_dir_renode}
> +  ./build.sh
> +  cd ${build_top}
> +%install
> +  build_top=$(pwd)
> +  mkdir -p %{_bindir}
> +  cp -r ./${source_dir_renode}/. %{_bindir}
> +  cd ${build_top}
