[PATCH] 6: Use GDB 13.2
Mon Jul 24 11:53:07 UTC 2023
Hello Karel,
On 24.07.23 13:15, Karel Gardas wrote:
> this together with also libexpat patch builds fine on:
> - macOS 13.4.1
> - FreeBSD 13.2
> - Ubuntu 20.04
thanks for the testing.
> btw, recently Joel remarked that gdb from 7/ makes troubles building on
> fbsd 12.x. I verified the same on fbsd 13.x and Hesham noted on discord
> that he has the same issues on macOS. GBD from 7/rtems-* complains about
> missing libmpfr.
> checking for the correct version of gmp.h... yes
> checking for the correct version of mpfr.h... no
> configure: error: Building GDB requires GMP 4.2+, and MPFR 3.1.0+.
> Try the --with-gmp and/or --with-mpfr options to specify
> their locations.  If you obtained GMP and/or MPFR from a vendor
> distribution package, make sure that you have installed both the libraries
> and the header files.  They may be located in separate packages.
> shell cmd failed: /bin/sh -ex
> /usr/home/karel/git/rtems-source-builder/rtems/build/aarch64-rtems7-gdb-22e69d8-x86_64-freebsd13.2-1/do-build
> error: building aarch64-rtems7-gdb-22e69d8-x86_64-freebsd13.2-1
> Obviusly gdb from 6/ does not hence there is probably some bit missing
> in 7/ which is already fixed in 6/
Actually I don't know how this should be handled. Some libraries are
added to rtems/config/6/rtems-default.bset others seem to be specific
tool files. The 7/ tools should a minimum set of patches. Things should
be directly fixed in the upstream projects.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
