[PATCH] 6: Use GDB 13.2
Tue Jul 25 01:43:59 UTC 2023
On 24/7/2023 9:53 pm, Sebastian Huber wrote:
> Hello Karel,
> On 24.07.23 13:15, Karel Gardas wrote:
>> this together with also libexpat patch builds fine on:
>> - macOS 13.4.1
>> - FreeBSD 13.2
>> - Ubuntu 20.04
> thanks for the testing.
>> btw, recently Joel remarked that gdb from 7/ makes troubles building on fbsd
>> 12.x. I verified the same on fbsd 13.x and Hesham noted on discord that he has
>> the same issues on macOS. GBD from 7/rtems-* complains about missing libmpfr.
>> checking for the correct version of gmp.h... yes
>> checking for the correct version of mpfr.h... no
>> configure: error: Building GDB requires GMP 4.2+, and MPFR 3.1.0+.
>> Try the --with-gmp and/or --with-mpfr options to specify
>> their locations.  If you obtained GMP and/or MPFR from a vendor
>> distribution package, make sure that you have installed both the libraries
>> and the header files.  They may be located in separate packages.
>> shell cmd failed: /bin/sh -ex
>> /usr/home/karel/git/rtems-source-builder/rtems/build/aarch64-rtems7-gdb-22e69d8-x86_64-freebsd13.2-1/do-build
>> error: building aarch64-rtems7-gdb-22e69d8-x86_64-freebsd13.2-1
>> Obviusly gdb from 6/ does not hence there is probably some bit missing in 7/
>> which is already fixed in 6/
> Actually I don't know how this should be handled. Some libraries are added to
> rtems/config/6/rtems-default.bset others seem to be specific tool files. The 7/
> tools should a minimum set of patches. Things should be directly fixed in the
> upstream projects.
We have been moving to build support libraries, such as GMP, separately and not
by links into the source tree of gcc. MacOS M silicon requires a specific option
for GMP to work and this has resulted in us building these libraries before
building the packages that depend on them because the upstream provide no means
to inject specific options. GDB added GMP and it seems more are being added so
we need to add support to build them before GDB and remove the symlink'ing into
the GCC source tree. The GMP change should provide a suitable template for doing
this.
