[PATCH v1 1/2] bsps/stm32h7: Make UART7 pins configurable
Karel Gardas karel at functional.vision
Mon Jul 24 20:05:59 UTC 2023
Hello Kinsey,
I think the patch looks good, although I've not verified precise
PIN/REGs assignment value. I trust you test this somehow otherwise you
would not submit it. And this steers my curiosity. The only board (from
ST Micro) I know which provides connection to UART7 is stm32h735g-dk
which is not supported by RTEMS due to missing MCU support in old HAL
code. I submitted new HAL patches last week but they are not in yet. So
if this is not company secrete let me ask, what board you are using with
UART7 connection?
Thanks,
Karel
On 7/24/23 20:28, Kinsey Moore wrote:
> This change allows for the pins assigned to UART7 to be reconfigured via
> config.ini.
>   bsps/arm/stm32h7/console/console-uart7-cfg.c    |  4 ++--
>   spec/build/bsps/arm/stm32h7/grp.yml             |  4 ++++
>   .../build/bsps/arm/stm32h7/optuart7gpiopins.yml | 17 +++++++++++++++++
>   .../build/bsps/arm/stm32h7/optuart7gpioregs.yml | 17 +++++++++++++++++
>   4 files changed, 40 insertions(+), 2 deletions(-)
>   create mode 100644 spec/build/bsps/arm/stm32h7/optuart7gpiopins.yml
>   create mode 100644 spec/build/bsps/arm/stm32h7/optuart7gpioregs.yml
> diff --git a/bsps/arm/stm32h7/console/console-uart7-cfg.c b/bsps/arm/stm32h7/console/console-uart7-cfg.c
> index dca19e652d..2ced4cf9c2 100644
> --- a/bsps/arm/stm32h7/console/console-uart7-cfg.c
> +++ b/bsps/arm/stm32h7/console/console-uart7-cfg.c
> @@ -33,9 +33,9 @@
>   const stm32h7_uart_config stm32h7_uart7_config = {
>     .gpio = {
> -    .regs = GPIOB,
> +    .regs = STM32H7_UART7_GPIO_REGS,
>       .config = {
> -      .Pin = GPIO_PIN_3 | GPIO_PIN_4,
> +      .Pin = STM32H7_UART7_GPIO_PINS,
>         .Mode = GPIO_MODE_AF_PP,
>         .Pull = GPIO_NOPULL,
>         .Speed = GPIO_SPEED_FREQ_LOW,
> diff --git a/spec/build/bsps/arm/stm32h7/grp.yml b/spec/build/bsps/arm/stm32h7/grp.yml
> index 595762c665..239df9b898 100644
> --- a/spec/build/bsps/arm/stm32h7/grp.yml
> +++ b/spec/build/bsps/arm/stm32h7/grp.yml
> @@ -106,6 +106,10 @@ links:
>     uid: optusart3gpiopins
>   - role: build-dependency
>     uid: optusart3gpioregs
> +- role: build-dependency
> +  uid: optuart7gpiopins
> +  uid: optuart7gpioregs
>     uid: optvariant
> diff --git a/spec/build/bsps/arm/stm32h7/optuart7gpiopins.yml b/spec/build/bsps/arm/stm32h7/optuart7gpiopins.yml
> new file mode 100644
> index 0000000000..0252bdab7c
> --- /dev/null
> +++ b/spec/build/bsps/arm/stm32h7/optuart7gpiopins.yml
> @@ -0,0 +1,17 @@
> +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> +actions:
> +- get-string: null
> +- define-unquoted: null
> +build-type: option
> +copyrights:
> +- Copyright (C) 2023 On-Line Applications Research (OAR)
> +default:
> +- enabled-by: true
> +  value: ( GPIO_PIN_3 | GPIO_PIN_4 )
> +description: |
> +  GPIO pins used for the UART7 pin configuration.
> +enabled-by: true
> +format: '{}'
> +links: []
> +name: STM32H7_UART7_GPIO_PINS
> +type: build
> diff --git a/spec/build/bsps/arm/stm32h7/optuart7gpioregs.yml b/spec/build/bsps/arm/stm32h7/optuart7gpioregs.yml
> index 0000000000..16ce3bf526
> --- /dev/null
> +++ b/spec/build/bsps/arm/stm32h7/optuart7gpioregs.yml
> @@ -0,0 +1,17 @@
> +actions:
> +- get-string: null
> +build-type: option
> +copyrights:
> +default:
> +- enabled-by: true
> +  value: GPIOB
> +description: |
> +  GPIO registers used for the UART7 pin configuration.
> +enabled-by: true
> +format: '{}'
> +links: []
> +name: STM32H7_UART7_GPIO_REGS
> +type: build
