[PATCH v1 2/2] bsps/stm32h7: Configure UART clocks when enabled
Kinsey Moore kinsey.moore at oarcorp.com
Tue Jul 25 13:39:09 UTC 2023
Unfortunately, this board is not publicly advertised or available and so a
dedicated BSP in RTEMS is not really appropriate. It seems that the current
"stm32h7" BSP should be renamed to stm32h743i-eval for clarity, but I'm
sure that would affect existing users. I'll just have to keep the BSP
changes private and upstream what I can.
Thanks,
Kinsey
On Tue, Jul 25, 2023 at 8:27 AM Karel Gardas <karel at functional.vision>
wrote:
> On 7/24/23 23:17, Kinsey Moore wrote:
> >     There is no other UART1 connector provided on the board. So I do not
> >     see
> >     reason why you add all other UARTs into #ifdefs for this particular
> >     board/bsp variant? And hence my question about your motivation and
> >     where
> >     you are heading...
> > Given that, I now understand the confusion. I have a board in hand that
> > will never see an upstream BSP and I was hoping to be able to configure
> > the base STM32H7 BSP for it, but what I interpreted as the "base"
> > STM32H7 BSP is not actually a generic base BSP. I was also contemplating
> > moving more of the peripheral configuration into shared files since the
> > enable/disable configuration items are already there and it would be
> > convenient for the various BSPs to exist as some custom code and then a
> > selection of presets for those configuration items. I'll have to think
> > about the best way forward for the project I'm working with.
> I guess the philosophy in stm32h7 is to avoid cpp directives even in
> case of a bit more code duplication.
> So if I may ask, just copy board directory structure, name it after your
> board and tweak the copied files there. No need to #ifdefing in
> different board which would not use that.
> And btw, I'm using the same for Precidata SL-3011 (board on market, but
> BSP and firmware not ready for RTEMS 6, will be submitted for RTEMS 7
> probably) and for Arduino Portenta H7 (ditto but even less mature
> codewise).
> Thanks!
> Karel
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230725/64cd3142/attachment-0001.htm>
