[PATCH] build: Export BSP base and family via pkg-config
Tue Jul 25 11:13:46 UTC 2023
This allows application and library build systems to derive option
values from the BSP base and family names.
 spec/build/bsps/pkgconfig.yml | 2 ++
 1 file changed, 2 insertions(+)
diff --git a/spec/build/bsps/pkgconfig.yml b/spec/build/bsps/pkgconfig.yml
index e08c83fe27..afaffbbf0f 100644
--- a/spec/build/bsps/pkgconfig.yml
+++ b/spec/build/bsps/pkgconfig.yml
@@ -15,6 +15,8 @@ content: |
   ABI_FLAGS=${ABI_FLAGS}
   RTEMS_ARCH=${ARCH}
   RTEMS_BSP=${BSP_NAME}
+  RTEMS_BSP_BASE=${BSP_BASE}
+  RTEMS_BSP_FAMILY=${BSP_FAMILY}
   RTEMS_MAJOR=${__RTEMS_MAJOR__}
   RTEMS_MINOR=${__RTEMS_MINOR__}
   RTEMS_REVISION=${__RTEMS_REVISION__}
2.35.3
