[PATCH] build: Export BSP base and family via pkg-config
Tue Jul 25 16:01:05 UTC 2023
On Tue, Jul 25, 2023 at 5:13 AM Sebastian Huber
> This allows application and library build systems to derive option
> values from the BSP base and family names.
>  spec/build/bsps/pkgconfig.yml | 2 ++
>  1 file changed, 2 insertions(+)
> diff --git a/spec/build/bsps/pkgconfig.yml b/spec/build/bsps/pkgconfig.yml
> index e08c83fe27..afaffbbf0f 100644
> --- a/spec/build/bsps/pkgconfig.yml
> +++ b/spec/build/bsps/pkgconfig.yml
> @@ -15,6 +15,8 @@ content: |
>    ABI_FLAGS=${ABI_FLAGS}
>    RTEMS_ARCH=${ARCH}
>    RTEMS_BSP=${BSP_NAME}
> +  RTEMS_BSP_BASE=${BSP_BASE}
> +  RTEMS_BSP_FAMILY=${BSP_FAMILY}
These expose a little bit of the internal working of the build system.
I think it's fine, since these two fields should not change over time.
But, it commits us to maintain this mapping and these variables.
>    RTEMS_MAJOR=${__RTEMS_MAJOR__}
>    RTEMS_MINOR=${__RTEMS_MINOR__}
>    RTEMS_REVISION=${__RTEMS_REVISION__}
> 2.35.3
> devel mailing list
> devel at rtems.org
