[PATCH] build: Add optional RTEMS_VERSION_VC_KEY
Tue Jul 25 15:12:16 UTC 2023
Allow the user to set the version control key.
 spec/build/cpukit/grp.yml             |  2 ++
 spec/build/cpukit/optversionvckey.yml | 20 ++++++++++++++
 wscript                               | 38 ++++++++++++++++-----------
 3 files changed, 44 insertions(+), 16 deletions(-)
 create mode 100644 spec/build/cpukit/optversionvckey.yml
diff --git a/spec/build/cpukit/grp.yml b/spec/build/cpukit/grp.yml
index e07e975d7d..fbeab45b5c 100644
--- a/spec/build/cpukit/grp.yml
+++ b/spec/build/cpukit/grp.yml
@@ -18,6 +18,8 @@ links:
   uid: cpuopts
 - role: build-dependency
   uid: cfghdr
+- role: build-dependency
+  uid: optversionvckey
   uid: libdebugger
diff --git a/spec/build/cpukit/optversionvckey.yml b/spec/build/cpukit/optversionvckey.yml
new file mode 100644
index 0000000000..7197381342
--- /dev/null
+++ b/spec/build/cpukit/optversionvckey.yml
@@ -0,0 +1,20 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+actions:
+- get-string: null
+- env-assign: null
+build-type: option
+copyrights:
+- Copyright (C) 2022, 2023 embedded brains GmbH & Co. KG
+default:
+- enabled-by: true
+  value: ''
+description: |
+  If defined to a non-empty value, then the value will be used for the version
+  control key returned by rtems_version() and rtems_version_control_key(),
+  otherwise the value will be determined by the Git repository containing the
+  waf top directory.
+enabled-by: true
+format: '{}'
+links: []
+name: RTEMS_VERSION_VC_KEY
+type: build
diff --git a/wscript b/wscript
index 862000513d..2026d55070 100755
--- a/wscript
+++ b/wscript
@@ -58,38 +58,44 @@ def no_unicode(value):
 class VersionControlKeyHeader:
-    _content = None
+    _git_commit = None
     @staticmethod
     def write(bld, filename):
-        if VersionControlKeyHeader._content is None:
-            from waflib.Build import Context
-            from waflib.Errors import WafError
-            content = """/*
+        content = """/*
  * Automatically generated. Do not edit.
 #if !defined(_RTEMS_VERSION_VC_KEY_H_)
 #define _RTEMS_VERSION_VC_KEY_H_
-            try:
-                rev = bld.cmd_and_log("git rev-parse HEAD",
-                                      quiet=Context.STDOUT).strip()
-                content += """#define RTEMS_VERSION_VC_KEY "{}"
+        rev = bld.env.RTEMS_VERSION_VC_KEY
+        if not rev:
+            rev = VersionControlKeyHeader._git_commit
+            if rev is None:
+                from waflib.Build import Context
+                from waflib.Errors import WafError
+                try:
+                    rev = bld.cmd_and_log("git rev-parse HEAD",
+                                          quiet=Context.STDOUT).strip()
+                except WafError:
+                    rev = ""
+                VersionControlKeyHeader._git_commit = rev
+        if rev:
+            content += """#define RTEMS_VERSION_VC_KEY "{}"
 """.format(rev)
-            except WafError:
-                content += """/* No version control key found; release? */
+        else:
+            content += """/* No version control key found; release? */
-            content += """#endif
+        content += """#endif
-            VersionControlKeyHeader._content = content
         f = bld.bldnode.make_node(filename)
         f.parent.mkdir()
         try:
             if content != f.read():
-                f.write(VersionControlKeyHeader._content)
+                f.write(content)
         except:
+            f.write(content)
 class EnvWrapper(object):
2.35.3
