[PATCH] score: Move formatted I/O functions
Tue Jul 25 11:39:37 UTC 2023
These functions do not belong to an super core service.
 cpukit/{score/src => dev}/iobase64.c          |   4 +-
 cpukit/{score/src => dev}/ioprintf.c          |   4 +-
 cpukit/{score/src => dev}/iovprintf.c         |   4 +-
 cpukit/include/rtems/dev/io.h                 | 119 ++++++++++++++-
 cpukit/include/rtems/score/gcov.h             |   2 +-
 cpukit/include/rtems/score/io.h               | 142 ------------------
 cpukit/libcsupport/src/vprintk.c              |   2 +-
 cpukit/libtest/t-test-hash-sha256.c           |   2 +-
 cpukit/libtest/t-test.c                       |   2 +-
 cpukit/libtrace/record/record-dump-base64.c   |   2 +-
 cpukit/libtrace/record/record-dump-zbase64.c  |   2 +-
 .../aarch64/aarch64-exception-frame-print.c   |   2 +-
 cpukit/score/src/hash.c                       |   2 +-
 spec/build/cpukit/librtemscpu.yml             |   7 +-
 testsuites/sptests/spprintk/init.c            |   2 +-
 testsuites/validation/tc-task-delete.c        |   2 +-
 testsuites/validation/tc-terminate.c          |   2 +-
 17 files changed, 138 insertions(+), 164 deletions(-)
 rename cpukit/{score/src => dev}/iobase64.c (98%)
 rename cpukit/{score/src => dev}/ioprintf.c (97%)
 rename cpukit/{score/src => dev}/iovprintf.c (99%)
 delete mode 100644 cpukit/include/rtems/score/io.h
diff --git a/cpukit/score/src/iobase64.c b/cpukit/dev/iobase64.c
similarity index 98%
rename from cpukit/score/src/iobase64.c
rename to cpukit/dev/iobase64.c
index 27b977c8a0..0ac70d3ddb 100644
--- a/cpukit/score/src/iobase64.c
+++ b/cpukit/dev/iobase64.c
@@ -3,7 +3,7 @@
  * @file
- * @ingroup RTEMSScoreIO
+ * @ingroup RTEMSDeviceIO
  * @brief This source file contains the implementation of
  *   _IO_Base64() and _IO_Base64url().
@@ -27,7 +27,7 @@
  * PERFORMANCE OF THIS SOFTWARE.
-#include <rtems/score/io.h>
+#include <rtems/dev/io.h>
 static void
 _IO_Put(int c, void *arg, IO_Put_char put_char)
diff --git a/cpukit/score/src/ioprintf.c b/cpukit/dev/ioprintf.c
similarity index 97%
rename from cpukit/score/src/ioprintf.c
rename to cpukit/dev/ioprintf.c
index 8ae4213ab1..1f16389b47 100644
--- a/cpukit/score/src/ioprintf.c
+++ b/cpukit/dev/ioprintf.c
@@ -3,7 +3,7 @@
  * @file
  *   _IO_Printf().
@@ -38,7 +38,7 @@
 #include "config.h"
 #endif
 int _IO_Printf( IO_Put_char put_char, void *arg, char const  *fmt, ... )
diff --git a/cpukit/score/src/iovprintf.c b/cpukit/dev/iovprintf.c
similarity index 99%
rename from cpukit/score/src/iovprintf.c
rename to cpukit/dev/iovprintf.c
index 0e8eb0b47b..99b11b691d 100644
--- a/cpukit/score/src/iovprintf.c
+++ b/cpukit/dev/iovprintf.c
@@ -1,7 +1,7 @@
  * @file
  *   _IO_Vprintf().
@@ -45,7 +45,7 @@
  *	@(#)subr_prf.c	8.3 (Berkeley) 1/21/94
 #include <sys/cdefs.h>
 __FBSDID("$FreeBSD: head/sys/kern/subr_prf.c 336417 2018-07-17 14:56:54Z markj $");
diff --git a/cpukit/include/rtems/dev/io.h b/cpukit/include/rtems/dev/io.h
index 4d041bcafc..93f384a551 100644
--- a/cpukit/include/rtems/dev/io.h
+++ b/cpukit/include/rtems/dev/io.h
@@ -10,7 +10,7 @@
- * Copyright (C) 2021 embedded brains GmbH & Co. KG
+ * Copyright (C) 2017, 2023 embedded brains GmbH & Co. KG
  * modification, are permitted provided that the following conditions
@@ -37,6 +37,10 @@
 #ifndef _RTEMS_DEV_IO_H
 #define _RTEMS_DEV_IO_H
+#include <rtems/score/basedefs.h>
+#include <stdarg.h>
 #ifdef __cplusplus
 extern "C" {
 #endif /* __cplusplus */
@@ -51,6 +55,119 @@ extern "C" {
+ * @brief This type defines the put character handler.
+ * @param c is the character to put.
+ * @param arg is the user-provided argument.
+typedef void ( *IO_Put_char )( int c, void *arg );
+ * @brief Prints characters using the put character handler according to the
+ *   format string.
+ * @param put_char is the put character handler.
+ * @param arg is the user-provided argument for the put character handler.
+ * @param fmt is the printf()-style format string.
+ * @param ... is the list of parameters required by the format string.
+ * @return Returns the count of put characters.
+int _IO_Printf(
+  IO_Put_char  put_char,
+  void        *arg,
+  char const  *fmt,
+) RTEMS_PRINTFLIKE( 3, 4 );
+ *   format string.
+ * @param ap is the argument list required by the format string.
+int _IO_Vprintf(
+  void        *arg,
+  char const  *fmt,
+  va_list      ap
+ * @brief Outputs the source buffer in base64 encoding.
+ * After word length of output characters produced by the encoding a word break
+ * is produced.
+ * @param put_char is the put character function used to output the encoded
+ *   source buffer.
+ * @param arg is the argument passed to the put character function.
+ * @param src is the pointer to the source buffer begin.
+ * @param srclen is the length of the source buffer in bytes.
+ * @param wordbreak is the word break string.
+ * @param wordlen is the word length in bytes.  If the word length is less than
+ *   four, then a word length of four will be used.
+ * @return Returns the count of output characters.
+int _IO_Base64(
+  void        *arg,
+  const void  *src,
+  size_t       len,
+  const char  *wordbreak,
+  int          wordlen
+ * @brief Outputs the source buffer in base64url encoding.
+ * is produced.
+ *   source buffer.
+int _IO_Base64url(
+  void        *arg,
+  const void  *src,
+  size_t       len,
+  int          wordlen
  * @brief Issues a couple of no-operation instructions.
diff --git a/cpukit/include/rtems/score/gcov.h b/cpukit/include/rtems/score/gcov.h
index 35e0480f6b..ff8ad62a15 100644
--- a/cpukit/include/rtems/score/gcov.h
+++ b/cpukit/include/rtems/score/gcov.h
@@ -40,7 +40,7 @@
 #include <gcov.h>
 #include <rtems/linkersets.h>
 #ifdef __cplusplus
 extern "C" {
diff --git a/cpukit/include/rtems/score/io.h b/cpukit/include/rtems/score/io.h
deleted file mode 100644
index 7fe69841e8..0000000000
--- a/cpukit/include/rtems/score/io.h
+++ /dev/null
@@ -1,142 +0,0 @@
-/* SPDX-License-Identifier: BSD-2-Clause */
- * @file
- * @brief This header file provides the interfaces of the
- *   @ref RTEMSScoreIO.
- * Copyright (c) 2017 embedded brains GmbH & Co. KG
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions
- * are met:
- * 1. Redistributions of source code must retain the above copyright
- *    notice, this list of conditions and the following disclaimer.
- * 2. Redistributions in binary form must reproduce the above copyright
- *    notice, this list of conditions and the following disclaimer in the
- *    documentation and/or other materials provided with the distribution.
- * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
- * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
- * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
- * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
- * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
- * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
- * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
- * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
- * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
- * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
- * POSSIBILITY OF SUCH DAMAGE.
-#ifndef _RTEMS_SCORE_IO_H
-#define _RTEMS_SCORE_IO_H
-#include <rtems/score/basedefs.h>
-#include <stdarg.h>
-#ifdef __cplusplus
-extern "C" {
-#endif /* __cplusplus */
- * @defgroup RTEMSScoreIO IO Handler
- * @brief This group contains the IO Handler implementation.
-typedef void ( *IO_Put_char )( int c, void *arg );
-int _IO_Printf(
-  IO_Put_char  put_char,
-  void        *arg,
-  char const  *fmt,
-) RTEMS_PRINTFLIKE( 3, 4 );
-int _IO_Vprintf(
-  void        *arg,
-  char const  *fmt,
-  va_list      ap
- * @brief Outputs the source buffer in base64 encoding.
- * After word length of output characters produced by the encoding a word break
- * is produced.
- * @param put_char is the put character function used to output the encoded
- *   source buffer.
- * @param arg is the argument passed to the put character function.
- * @param src is the pointer to the source buffer begin.
- * @param srclen is the length of the source buffer in bytes.
- * @param wordbreak is the word break string.
- * @param wordlen is the word length in bytes.  If the word length is less than
- *   four, then a word length of four will be used.
- * @return Returns the count of output characters.
-int _IO_Base64(
-  void        *arg,
-  const void  *src,
-  size_t       len,
-  const char  *wordbreak,
-  int          wordlen
- * @brief Outputs the source buffer in base64url encoding.
- * is produced.
- *   source buffer.
-int _IO_Base64url(
-  void        *arg,
-  const void  *src,
-  size_t       len,
-  int          wordlen
-#ifdef __cplusplus
-#endif /* _RTEMS_SCORE_IO_H */
diff --git a/cpukit/libcsupport/src/vprintk.c b/cpukit/libcsupport/src/vprintk.c
index e46cdad60f..f4ac81c5fc 100644
--- a/cpukit/libcsupport/src/vprintk.c
+++ b/cpukit/libcsupport/src/vprintk.c
@@ -38,7 +38,7 @@
 #endif
 #include <rtems/bspIo.h>
 int vprintk( const char *fmt, va_list ap )
diff --git a/cpukit/libtest/t-test-hash-sha256.c b/cpukit/libtest/t-test-hash-sha256.c
index a9aa4df023..caefb0210e 100644
--- a/cpukit/libtest/t-test-hash-sha256.c
+++ b/cpukit/libtest/t-test-hash-sha256.c
@@ -26,7 +26,7 @@
 #include <rtems/test.h>
 #include <limits.h>
diff --git a/cpukit/libtest/t-test.c b/cpukit/libtest/t-test.c
index 4f3bf56142..a8527fafe8 100644
--- a/cpukit/libtest/t-test.c
+++ b/cpukit/libtest/t-test.c
@@ -37,7 +37,7 @@
 #include <stdatomic.h>
 #ifdef __rtems__
 #include <rtems/score/smp.h>
diff --git a/cpukit/libtrace/record/record-dump-base64.c b/cpukit/libtrace/record/record-dump-base64.c
index a021c7016c..8d403e9c27 100644
--- a/cpukit/libtrace/record/record-dump-base64.c
+++ b/cpukit/libtrace/record/record-dump-base64.c
@@ -30,7 +30,7 @@
 #endif
 #include <rtems/recorddump.h>
 #include <limits.h>
diff --git a/cpukit/libtrace/record/record-dump-zbase64.c b/cpukit/libtrace/record/record-dump-zbase64.c
index 9359429d0b..0979e36a47 100644
--- a/cpukit/libtrace/record/record-dump-zbase64.c
+++ b/cpukit/libtrace/record/record-dump-zbase64.c
@@ -30,7 +30,7 @@
 #endif
 #include <limits.h>
diff --git a/cpukit/score/cpu/aarch64/aarch64-exception-frame-print.c b/cpukit/score/cpu/aarch64/aarch64-exception-frame-print.c
index c5b477c72f..04a3dfdc0d 100644
--- a/cpukit/score/cpu/aarch64/aarch64-exception-frame-print.c
+++ b/cpukit/score/cpu/aarch64/aarch64-exception-frame-print.c
@@ -45,7 +45,7 @@
 #include <inttypes.h>
 #include <rtems/score/cpu.h>
 typedef struct {
diff --git a/cpukit/score/src/hash.c b/cpukit/score/src/hash.c
index dc9143f4c0..888a618751 100644
--- a/cpukit/score/src/hash.c
+++ b/cpukit/score/src/hash.c
@@ -39,7 +39,7 @@
 #include <rtems/score/hash.h>
 #include <limits.h>
diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
index d556c95bc8..6bc700e2cd 100644
--- a/spec/build/cpukit/librtemscpu.yml
+++ b/spec/build/cpukit/librtemscpu.yml
@@ -356,7 +356,6 @@ install:
   - cpukit/include/rtems/score/heapimpl.h
   - cpukit/include/rtems/score/heapinfo.h
   - cpukit/include/rtems/score/interr.h
-  - cpukit/include/rtems/score/io.h
   - cpukit/include/rtems/score/isr.h
   - cpukit/include/rtems/score/isrlevel.h
   - cpukit/include/rtems/score/isrlock.h
@@ -541,7 +540,10 @@ source:
 - cpukit/dev/i2c/ti-lm25066a.c
 - cpukit/dev/i2c/ti-tmp112.c
 - cpukit/dev/i2c/xilinx-axi-i2c.c
+- cpukit/dev/iobase64.c
+- cpukit/dev/ioprintf.c
 - cpukit/dev/iorelax.c
+- cpukit/dev/iovprintf.c
 - cpukit/dev/serial/sc16is752-spi.c
 - cpukit/dev/serial/sc16is752.c
 - cpukit/dev/spi/spi-bus.c
@@ -1433,9 +1435,6 @@ source:
 - cpukit/score/src/heapsizeofuserarea.c
 - cpukit/score/src/heapwalk.c
 - cpukit/score/src/interr.c
-- cpukit/score/src/iobase64.c
-- cpukit/score/src/ioprintf.c
-- cpukit/score/src/iovprintf.c
 - cpukit/score/src/isr.c
 - cpukit/score/src/isrisinprogress.c
 - cpukit/score/src/isrvectortable.c
diff --git a/testsuites/sptests/spprintk/init.c b/testsuites/sptests/spprintk/init.c
index f8fe224086..b69edc095e 100644
--- a/testsuites/sptests/spprintk/init.c
+++ b/testsuites/sptests/spprintk/init.c
@@ -32,7 +32,7 @@
 #include "config.h"
 #endif
  * Undefined the RTEMS_PRINTFLIKE and make it nothing. The test code
diff --git a/testsuites/validation/tc-task-delete.c b/testsuites/validation/tc-task-delete.c
index 3172604eff..0e7d3b312a 100644
--- a/testsuites/validation/tc-task-delete.c
+++ b/testsuites/validation/tc-task-delete.c
@@ -57,7 +57,7 @@
 #include <setjmp.h>
 #include <rtems/test-scheduler.h>
diff --git a/testsuites/validation/tc-terminate.c b/testsuites/validation/tc-terminate.c
index 3ea314efc3..f8f6f1d1ce 100644
--- a/testsuites/validation/tc-terminate.c
+++ b/testsuites/validation/tc-terminate.c
@@ -58,7 +58,7 @@
 #include <rtems/test-info.h>
 #include <rtems/score/atomic.h>
 #include <rtems/score/sysstate.h>
2.35.3
