[PATCH] build: Add optional RTEMS_VERSION_VC_KEY
Tue Jul 25 17:15:24 UTC 2023
On 25.07.23 19:09, Joel Sherrill wrote:
> On Tue, Jul 25, 2023 at 10:12 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     Allow the user to set the version control key.
>       spec/build/cpukit/grp.yml             |  2 ++
>       spec/build/cpukit/optversionvckey.yml | 20 ++++++++++++++
>       wscript                               | 38 ++++++++++++++++-----------
>       3 files changed, 44 insertions(+), 16 deletions(-)
>       create mode 100644 spec/build/cpukit/optversionvckey.yml
>     diff --git a/spec/build/cpukit/grp.yml b/spec/build/cpukit/grp.yml
>     index e07e975d7d..fbeab45b5c 100644
>     --- a/spec/build/cpukit/grp.yml
>     +++ b/spec/build/cpukit/grp.yml
>     @@ -18,6 +18,8 @@ links:
>         uid: cpuopts
>       - role: build-dependency
>         uid: cfghdr
>     +- role: build-dependency
>     +  uid: optversionvckey
>         uid: libdebugger
>     diff --git a/spec/build/cpukit/optversionvckey.yml
>     b/spec/build/cpukit/optversionvckey.yml
>     new file mode 100644
>     index 0000000000..7197381342
>     --- /dev/null
>     +++ b/spec/build/cpukit/optversionvckey.yml
>     @@ -0,0 +1,20 @@
>     +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
>     +actions:
>     +- get-string: null
>     +- env-assign: null
>     +build-type: option
>     +copyrights:
>     +- Copyright (C) 2022, 2023 embedded brains GmbH & Co. KG
>     +default:
>     +- enabled-by: true
>     +  value: ''
>     +description: |
>     +  If defined to a non-empty value, then the value will be used for
>     the version
>     +  control key returned by rtems_version() and
>     rtems_version_control_key(),
>     +  otherwise the value will be determined by the Git repository
>     containing the
>     +  waf top directory.
> And would this change for a release tarball?
Which RTEMS_VERSION_VC_KEY has a release tarball? What happens if you
unpack an release archive in an external Git repository?
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
