[PATCH] build: Add optional RTEMS_VERSION_VC_KEY
Tue Jul 25 18:27:58 UTC 2023
On Tue, Jul 25, 2023 at 12:15 PM Sebastian Huber <
> On 25.07.23 19:09, Joel Sherrill wrote:
> > On Tue, Jul 25, 2023 at 10:12 AM Sebastian Huber
> > <sebastian.huber at embedded-brains.de
> > <mailto:sebastian.huber at embedded-brains.de>> wrote:
> >     Allow the user to set the version control key.
> >       spec/build/cpukit/grp.yml             |  2 ++
> >       spec/build/cpukit/optversionvckey.yml | 20 ++++++++++++++
> >       wscript                               | 38
> >       3 files changed, 44 insertions(+), 16 deletions(-)
> >       create mode 100644 spec/build/cpukit/optversionvckey.yml
> >     diff --git a/spec/build/cpukit/grp.yml b/spec/build/cpukit/grp.yml
> >     index e07e975d7d..fbeab45b5c 100644
> >     --- a/spec/build/cpukit/grp.yml
> >     +++ b/spec/build/cpukit/grp.yml
> >     @@ -18,6 +18,8 @@ links:
> >         uid: cpuopts
> >       - role: build-dependency
> >         uid: cfghdr
> >     +- role: build-dependency
> >     +  uid: optversionvckey
> >         uid: libdebugger
> >     diff --git a/spec/build/cpukit/optversionvckey.yml
> >     b/spec/build/cpukit/optversionvckey.yml
> >     new file mode 100644
> >     index 0000000000..7197381342
> >     --- /dev/null
> >     +++ b/spec/build/cpukit/optversionvckey.yml
> >     @@ -0,0 +1,20 @@
> >     +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> >     +actions:
> >     +- get-string: null
> >     +- env-assign: null
> >     +build-type: option
> >     +copyrights:
> >     +- Copyright (C) 2022, 2023 embedded brains GmbH & Co. KG
> >     +default:
> >     +- enabled-by: true
> >     +  value: ''
> >     +description: |
> >     +  If defined to a non-empty value, then the value will be used for
> >     the version
> >     +  control key returned by rtems_version() and
> >     rtems_version_control_key(),
> >     +  otherwise the value will be determined by the Git repository
> >     containing the
> >     +  waf top directory.
> > And would this change for a release tarball?
> Which RTEMS_VERSION_VC_KEY has a release tarball? What happens if you
> unpack an release archive in an external Git repository?
I don't know but think we should discuss it.
Chris should speak up since the release scripts are his and this
might be used by the distribution packaging he has made available.
--joel
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230725/d6dc1c01/attachment.htm>
