[PATCH] score/arm: style fixes
Tue Jul 25 21:38:00 UTC 2023
 cpukit/score/cpu/arm/__aeabi_read_tp.c        |   2 +-
 cpukit/score/cpu/arm/__tls_get_addr.c         |   4 +-
 .../score/cpu/arm/aarch32-psma-init-default.c |   2 +-
 cpukit/score/cpu/arm/aarch32-psma-init.c      |  82 ++++-----
 cpukit/score/cpu/arm/arm-exception-default.c  |   6 +-
 .../score/cpu/arm/arm-exception-frame-print.c | 159 ++++++++----------
 cpukit/score/cpu/arm/armv4-sync-synchronize.c |   2 +-
 cpukit/score/cpu/arm/armv7-thread-idle.c      |   4 +-
 .../score/cpu/arm/armv7m-context-initialize.c |  14 +-
 cpukit/score/cpu/arm/armv7m-context-restore.c |   4 +-
 .../score/cpu/arm/armv7m-exception-default.c  |  26 +--
 .../cpu/arm/armv7m-exception-handler-get.c    |   4 +-
 .../cpu/arm/armv7m-exception-handler-set.c    |  19 +--
 .../cpu/arm/armv7m-exception-priority-get.c   |   8 +-
 .../arm/armv7m-exception-priority-handler.c   |   8 +-
 .../cpu/arm/armv7m-exception-priority-set.c   |   8 +-
 cpukit/score/cpu/arm/armv7m-initialize.c      |   2 +-
 cpukit/score/cpu/arm/armv7m-isr-dispatch.c    |  20 +--
 cpukit/score/cpu/arm/armv7m-isr-enter-leave.c |   4 +-
 cpukit/score/cpu/arm/armv7m-isr-level-get.c   |   2 +-
 cpukit/score/cpu/arm/armv7m-isr-level-set.c   |   4 +-
 .../score/cpu/arm/armv7m-isr-vector-install.c |   8 +-
 .../cpu/arm/armv7m-multitasking-start-stop.c  |   4 +-
 cpukit/score/cpu/arm/cpu.c                    |  51 +++---
 24 files changed, 209 insertions(+), 238 deletions(-)
diff --git a/cpukit/score/cpu/arm/__aeabi_read_tp.c b/cpukit/score/cpu/arm/__aeabi_read_tp.c
index 0f4eba8d9a..e3bc529f18 100644
--- a/cpukit/score/cpu/arm/__aeabi_read_tp.c
+++ b/cpukit/score/cpu/arm/__aeabi_read_tp.c
@@ -37,8 +37,8 @@
 #include "config.h"
 #endif
-#include <rtems/score/thread.h>
+#include <rtems/score/thread.h>
 #ifndef RTEMS_SMP
diff --git a/cpukit/score/cpu/arm/__tls_get_addr.c b/cpukit/score/cpu/arm/__tls_get_addr.c
index 7ef42fdcb4..fe38368812 100644
--- a/cpukit/score/cpu/arm/__tls_get_addr.c
+++ b/cpukit/score/cpu/arm/__tls_get_addr.c
@@ -47,8 +47,8 @@ void *__tls_get_addr(const TLS_Index *ti);
   const Thread_Control *executing = _Thread_Get_executing();
-  void *tls_data = (char *) executing->Registers.thread_id
-    + _TLS_Get_thread_control_block_area_size();
+  void                 *tls_data  = (char *) executing->Registers.thread_id;
+  tls_data += _TLS_Get_thread_control_block_area_size();
   assert(ti->module == 1);
diff --git a/cpukit/score/cpu/arm/aarch32-psma-init-default.c b/cpukit/score/cpu/arm/aarch32-psma-init-default.c
index 615e7a528a..8ef8b5233a 100644
--- a/cpukit/score/cpu/arm/aarch32-psma-init-default.c
+++ b/cpukit/score/cpu/arm/aarch32-psma-init-default.c
@@ -42,7 +42,7 @@
 #if __ARM_ARCH >= 8 && __ARM_ARCH_PROFILE == 'R'
-void _AArch32_PMSA_Initialize_default( void )
+void _AArch32_PMSA_Initialize_default(void)
   _AArch32_PMSA_Initialize(
     AARCH32_PMSA_MEM_ATTR(
diff --git a/cpukit/score/cpu/arm/aarch32-psma-init.c b/cpukit/score/cpu/arm/aarch32-psma-init.c
index 93a3673a98..b30cb5e308 100644
--- a/cpukit/score/cpu/arm/aarch32-psma-init.c
+++ b/cpukit/score/cpu/arm/aarch32-psma-init.c
@@ -46,7 +46,7 @@
 #include <rtems/score/cpu.h>
 #define AARCH32_PMSA_REGION_MAX \
-  ( ( AARCH32_MPUIR_REGION_MASK >> AARCH32_MPUIR_REGION_SHIFT ) + 1 )
+  ((AARCH32_MPUIR_REGION_MASK >> AARCH32_MPUIR_REGION_SHIFT) + 1)
 static void _AArch32_PMSA_Configure(
   const AArch32_PMSA_Region *regions,
@@ -57,36 +57,36 @@ static void _AArch32_PMSA_Configure(
   size_t   ri;
   uint32_t sctlr;
-  for ( ri = 0 ; ri < region_used; ++ri ) {
+  for ( ri = 0; ri < region_used; ++ri ) {
     uint32_t prbar;
     uint32_t prlar;
     uint32_t attr;
-    prbar = regions[ ri ].base;
-    prlar = regions[ ri ].limit;
-    attr = regions[ ri ].attributes;
+    prbar = regions[ri].base;
+    prlar = regions[ri].limit;
+    attr  = regions[ri].attributes;
-    prbar |= ( attr >> 6 ) & 0x3fU;
+    prbar |= (attr >> 6) & 0x3fU;
     prlar |= attr & 0x3fU;
-    _AArch32_Write_prselr( ri );
+    _AArch32_Write_prselr(ri);
     _ARM_Instruction_synchronization_barrier();
-    _AArch32_Write_prbar( prbar );
-    _AArch32_Write_prlar( prlar );
+    _AArch32_Write_prbar(prbar);
+    _AArch32_Write_prlar(prlar);
-  for ( ri = region_used ; ri < region_max; ++ri ) {
+  for ( ri = region_used; ri < region_max; ++ri ) {
-    _AArch32_Write_prbar( 0 );
-    _AArch32_Write_prlar( 0 );
+    _AArch32_Write_prbar(0);
+    _AArch32_Write_prlar(0);
   _ARM_Data_synchronization_barrier();
-  sctlr = _AArch32_Read_sctlr();
+  sctlr  = _AArch32_Read_sctlr();
   sctlr |= AARCH32_SCTLR_M | AARCH32_SCTLR_I | AARCH32_SCTLR_C;
-  sctlr &= ~( AARCH32_SCTLR_A | AARCH32_SCTLR_BR );
-  _AArch32_Write_sctlr( sctlr );
+  sctlr &= ~(AARCH32_SCTLR_A | AARCH32_SCTLR_BR);
+  _AArch32_Write_sctlr(sctlr);
@@ -109,16 +109,16 @@ size_t _AArch32_PMSA_Map_sections_to_regions(
     uint32_t attr;
     uint32_t limit;
-    base = sections[ si ].begin;
-    end = sections[ si ].end;
-    attr = sections[ si ].attributes;
+    base = sections[si].begin;
+    end  = sections[si].end;
+    attr = sections[si].attributes;
     if ( base == end ) {
       continue;
-    base = RTEMS_ALIGN_DOWN( base, AARCH32_PMSA_MIN_REGION_ALIGN );
-    end = RTEMS_ALIGN_UP( end, AARCH32_PMSA_MIN_REGION_ALIGN );
+    base  = RTEMS_ALIGN_DOWN(base, AARCH32_PMSA_MIN_REGION_ALIGN);
+    end   = RTEMS_ALIGN_UP(end, AARCH32_PMSA_MIN_REGION_ALIGN);
     limit = end - AARCH32_PMSA_MIN_REGION_ALIGN;
@@ -126,16 +126,16 @@ size_t _AArch32_PMSA_Map_sections_to_regions(
       uint32_t region_limit;
       uint32_t region_attr;
-      region_base = regions[ ri ].base;
-      region_limit = regions[ ri ].limit;
-      region_attr = regions[ ri ].attributes;
+      region_base  = regions[ri].base;
+      region_limit = regions[ri].limit;
+      region_attr  = regions[ri].attributes;
       if ( attr == region_attr ) {
         uint32_t region_end;
         if ( end - region_base <= AARCH32_PMSA_MIN_REGION_ALIGN ) {
           /* Extend the region */
-          regions[ ri ].base = base;
+          regions[ri].base = base;
           break;
@@ -143,7 +143,7 @@ size_t _AArch32_PMSA_Map_sections_to_regions(
         if ( region_end - base <= AARCH32_PMSA_MIN_REGION_ALIGN ) {
-          regions[ ri ].limit = limit;
+          regions[ri].limit = limit;
           break;
@@ -161,14 +161,14 @@ size_t _AArch32_PMSA_Map_sections_to_regions(
         for ( i = region_used; i > ri; --i ) {
-          regions[ i ] = regions[ i - 1 ];
+          regions[i] = regions[i - 1];
         /* New first region */
         ++region_used;
-        regions[ ri ].attributes = attr;
+        regions[ri].attributes = attr;
         break;
@@ -180,9 +180,9 @@ size_t _AArch32_PMSA_Map_sections_to_regions(
       /* New last region */
       ++region_used;
@@ -196,15 +196,15 @@ void _AArch32_PMSA_Initialize(
   size_t                      section_count
-  AArch32_PMSA_Region regions[ AARCH32_PMSA_REGION_MAX ];
-  size_t region_max;
-  size_t region_used;
+  AArch32_PMSA_Region regions[AARCH32_PMSA_REGION_MAX];
+  size_t              region_max;
+  size_t              region_used;
-  _AArch32_Write_mair0( memory_attributes_0 );
-  _AArch32_Write_mair1( memory_attributes_1 );
+  _AArch32_Write_mair0(memory_attributes_0);
+  _AArch32_Write_mair1(memory_attributes_1);
-  region_max = ( _AArch32_Read_mpuir() & AARCH32_MPUIR_REGION_MASK ) >>
-    AARCH32_MPUIR_REGION_SHIFT;
+  region_max = (_AArch32_Read_mpuir() & AARCH32_MPUIR_REGION_MASK) >>
+               AARCH32_MPUIR_REGION_SHIFT;
   region_used = _AArch32_PMSA_Map_sections_to_regions(
     sections,
@@ -214,7 +214,7 @@ void _AArch32_PMSA_Initialize(
   if ( region_used > 0 ) {
-    _AArch32_PMSA_Configure( regions, region_used, region_max );
+    _AArch32_PMSA_Configure(regions, region_used, region_max);
diff --git a/cpukit/score/cpu/arm/arm-exception-default.c b/cpukit/score/cpu/arm/arm-exception-default.c
index 02df769287..190c2bf68d 100644
--- a/cpukit/score/cpu/arm/arm-exception-default.c
+++ b/cpukit/score/cpu/arm/arm-exception-default.c
@@ -38,10 +38,10 @@
 #include "config.h"
 #endif
-#include <rtems/score/cpu.h>
 #include <rtems/fatal.h>
+#include <rtems/score/cpu.h>
-void _ARM_Exception_default( CPU_Exception_frame *frame )
+void _ARM_Exception_default(CPU_Exception_frame *frame)
-  rtems_fatal( RTEMS_FATAL_SOURCE_EXCEPTION, (rtems_fatal_code) frame );
+  rtems_fatal(RTEMS_FATAL_SOURCE_EXCEPTION, (rtems_fatal_code) frame);
diff --git a/cpukit/score/cpu/arm/arm-exception-frame-print.c b/cpukit/score/cpu/arm/arm-exception-frame-print.c
index b089648184..c625cf2479 100644
--- a/cpukit/score/cpu/arm/arm-exception-frame-print.c
+++ b/cpukit/score/cpu/arm/arm-exception-frame-print.c
@@ -46,12 +46,12 @@
 #endif
 #include <rtems/bspIo.h>
-static void _ARM_VFP_context_print( const ARM_VFP_context *vfp_context )
+static void _ARM_VFP_context_print(const ARM_VFP_context *vfp_context)
 #ifdef ARM_MULTILIB_VFP
   if ( vfp_context != NULL ) {
     const uint64_t *dx = &vfp_context->register_d0;
-    int i;
+    int             i;
     printk(
       "FPEXC = 0x%08" PRIx32 "\nFPSCR = 0x%08" PRIx32 "\n",
@@ -67,138 +67,119 @@ static void _ARM_VFP_context_print( const ARM_VFP_context *vfp_context )
     int regcount = 0;
 #endif
     for ( i = 0; i < regcount; ++i ) {
-      uint32_t low = (uint32_t) dx[i];
+      uint32_t low  = (uint32_t) dx[i];
       uint32_t high = (uint32_t) (dx[i] >> 32);
-      printk( "D%02i = 0x%08" PRIx32 "%08" PRIx32 "\n", i, high, low );
+      printk("D%02i = 0x%08" PRIx32 "%08" PRIx32 "\n", i, high, low);
 #endif
-static void _ARM_Cortex_M_fault_info_print( void )
+static void _ARM_Cortex_M_fault_info_print(void)
 #if defined(ARM_MULTILIB_ARCH_V7M)
    * prints content of additional debugging registers
    * available on Cortex-Mx where x > 0 cores.
-  uint32_t cfsr = _ARMV7M_SCB->cfsr;
-  uint8_t mmfsr = ARMV7M_SCB_CFSR_MMFSR_GET( cfsr );
-  uint8_t bfsr = ( ARMV7M_SCB_CFSR_BFSR_GET( cfsr ) >> 8 );
-  uint16_t ufsr = ( ARMV7M_SCB_CFSR_UFSR_GET( cfsr ) >> 16 );
-  uint32_t hfsr = _ARMV7M_SCB->hfsr;
+  uint32_t cfsr  = _ARMV7M_SCB->cfsr;
+  uint8_t  mmfsr = ARMV7M_SCB_CFSR_MMFSR_GET(cfsr);
+  uint8_t  bfsr  = (ARMV7M_SCB_CFSR_BFSR_GET(cfsr) >> 8);
+  uint16_t ufsr  = (ARMV7M_SCB_CFSR_UFSR_GET(cfsr) >> 16);
+  uint32_t hfsr  = _ARMV7M_SCB->hfsr;
   if ( mmfsr > 0 ) {
-    printk( "MMFSR= 0x%08" PRIx32 " (memory fault)\n", mmfsr );
-    if ( ( mmfsr & 0x1 ) != 0 ) {
-      printk( "  IACCVIOL   : 1  (instruction access violation)\n" );
+    printk("MMFSR= 0x%08" PRIx32 " (memory fault)\n", mmfsr);
+    if ( (mmfsr & 0x1) != 0 ) {
+      printk("  IACCVIOL   : 1  (instruction access violation)\n");
-    if ( ( mmfsr & 0x2 ) != 0 ) {
-      printk( "  DACCVIOL   : 1  (data access violation)\n" );
+    if ( (mmfsr & 0x2) != 0 ) {
+      printk("  DACCVIOL   : 1  (data access violation)\n");
-    if ( (mmfsr & 0x8 ) != 0 ) {
-      printk(
-        "  MUNSTKERR  : 1  (fault on unstacking on exception return)\n"
+    if ( (mmfsr & 0x8) != 0 ) {
+      printk("  MUNSTKERR  : 1  (fault on unstacking on exception return)\n");
-    if ( ( mmfsr & 0x10 ) != 0 ) {
-      printk( "  MSTKERR    : 1  (fault on stacking on exception entry)\n" );
+    if ( (mmfsr & 0x10) != 0 ) {
+      printk("  MSTKERR    : 1  (fault on stacking on exception entry)\n");
-    if ( (mmfsr & 0x20 ) != 0 ) {
-      printk( "  MLSPERR    : 1  (fault during lazy FP stack preservation)\n" );
+    if ( (mmfsr & 0x20) != 0 ) {
+      printk("  MLSPERR    : 1  (fault during lazy FP stack preservation)\n");
-    if ( (mmfsr & 0x80 ) != 0 ) {
+    if ( (mmfsr & 0x80) != 0 ) {
       printk(
         "  MMFARVALID : 1 -> 0x%08" PRIx32 " (error address)\n",
-	_ARMV7M_SCB->mmfar
+        _ARMV7M_SCB->mmfar
-    else {
-      printk( "  MMFARVALID : 0  (undetermined error address)\n" );
+    } else {
+      printk("  MMFARVALID : 0  (undetermined error address)\n");
   if ( bfsr > 0 ) {
-    printk( "BFSR = 0x%08" PRIx32 " (bus fault)\n", bfsr );
-    if ( ( bfsr & 0x1 ) != 0 ) {
-      printk( "  IBUSERR    : 1  (instruction fetch error)\n" );
+    printk("BFSR = 0x%08" PRIx32 " (bus fault)\n", bfsr);
+    if ( (bfsr & 0x1) != 0 ) {
+      printk("  IBUSERR    : 1  (instruction fetch error)\n");
-    if ( (bfsr & 0x2 ) != 0 ) {
-      printk(
-        "  PRECISERR  : 1  (data bus error with known exact location)\n"
+    if ( (bfsr & 0x2) != 0 ) {
+      printk("  PRECISERR  : 1  (data bus error with known exact location)\n");
-    if ( ( bfsr & 0x4) != 0 ) {
-      printk(
-        "  IMPRECISERR: 1  (data bus error without known exact location)\n"
+    if ( (bfsr & 0x4) != 0 ) {
+      printk("  IMPRECISERR: 1  (data bus error without known exact location)\n"
-    if ( (bfsr & 0x8 ) != 0 ) {
-      printk(
-        "  UNSTKERR   : 1  (fault on unstacking on exception return)\n"
+    if ( (bfsr & 0x8) != 0 ) {
+      printk("  UNSTKERR   : 1  (fault on unstacking on exception return)\n");
-    if ( ( bfsr & 0x10 ) != 0 ) {
-      printk( "  STKERR     : 1  (fault on stacking on exception entry)\n" );
+    if ( (bfsr & 0x10) != 0 ) {
+      printk("  STKERR     : 1  (fault on stacking on exception entry)\n");
-    if ( ( bfsr & 0x20 ) != 0 ) {
-      printk( "  LSPERR     : 1  (fault during lazy FP stack preservation)\n" );
+    if ( (bfsr & 0x20) != 0 ) {
+      printk("  LSPERR     : 1  (fault during lazy FP stack preservation)\n");
-    if ( (bfsr & 0x80 ) != 0 ) {
+    if ( (bfsr & 0x80) != 0 ) {
       printk(
         "  BFARVALID  : 1 -> 0x%08" PRIx32 "  (error address)\n",
-	_ARMV7M_SCB->bfar
+        _ARMV7M_SCB->bfar
-    else {
-      printk( "  BFARVALID  : 0  (undetermined error address)\n" );
+    } else {
+      printk("  BFARVALID  : 0  (undetermined error address)\n");
   if ( ufsr > 0 ) {
-    printk( "UFSR = 0x%08" PRIx32 " (usage fault)\n", ufsr);
-    if ( (ufsr & 0x1 ) != 0 ) {
-      printk( "  UNDEFINSTR : 1  (undefined instruction issued)\n");
+    printk("UFSR = 0x%08" PRIx32 " (usage fault)\n", ufsr);
+    if ( (ufsr & 0x1) != 0 ) {
+      printk("  UNDEFINSTR : 1  (undefined instruction issued)\n");
-    if ( (ufsr & 0x2 ) != 0 ) {
-      printk(
-        "  INVSTATE   : 1"
-        "  (invalid instruction state"
-        " (Thumb not set in EPSR or invalid IT state in EPSR))\n"
+    if ( (ufsr & 0x2) != 0 ) {
+      printk("  INVSTATE   : 1"
+             "  (invalid instruction state"
+             " (Thumb not set in EPSR or invalid IT state in EPSR))\n");
-    if ( (ufsr & 0x4 ) != 0 ) {
-      printk( "  INVPC      : 1  (integrity check failure on EXC_RETURN)\n" );
+    if ( (ufsr & 0x4) != 0 ) {
+      printk("  INVPC      : 1  (integrity check failure on EXC_RETURN)\n");
-    if ( (ufsr & 0x8 ) != 0 ) {
-      printk(
-        "  NOCP       : 1"
-        "  (coprocessor instruction issued"
-        " but coprocessor disabled or non existent)\n"
+    if ( (ufsr & 0x8) != 0 ) {
+      printk("  NOCP       : 1"
+             "  (coprocessor instruction issued"
+             " but coprocessor disabled or non existent)\n");
-    if ( ( ufsr & 0x100) != 0 ) {
-      printk( "  UNALIGNED  : 1  (unaligned access operation occurred)\n" );
+    if ( (ufsr & 0x100) != 0 ) {
+      printk("  UNALIGNED  : 1  (unaligned access operation occurred)\n");
-    if ( ( ufsr & 0x200) != 0 ) {
-      printk( "  DIVBYZERO  : 1  (division by zero)" );
+    if ( (ufsr & 0x200) != 0 ) {
+      printk("  DIVBYZERO  : 1  (division by zero)");
-  if ( (hfsr & (
-    ARMV7M_SCB_HFSR_VECTTBL_MASK
-    | ARMV7M_SCB_HFSR_DEBUGEVT_MASK
-    | ARMV7M_SCB_HFSR_FORCED_MASK
-    ) ) != 0 ) {
-    printk( "HFSR = 0x%08" PRIx32 " (hard fault)\n", hfsr );
-    if ( (hfsr & ARMV7M_SCB_HFSR_VECTTBL_MASK ) != 0 ) {
-      printk(
-        "  VECTTBL    : 1  (error in address located in vector table)\n"
-    if ( (hfsr & ARMV7M_SCB_HFSR_FORCED_MASK ) != 0 ) {
-      printk(
-        "  FORCED     : 1  (configurable fault escalated to hard fault)\n"
+  if ( (hfsr & (ARMV7M_SCB_HFSR_VECTTBL_MASK | ARMV7M_SCB_HFSR_DEBUGEVT_MASK |
+                ARMV7M_SCB_HFSR_FORCED_MASK)) != 0 ) {
+    printk("HFSR = 0x%08" PRIx32 " (hard fault)\n", hfsr);
+    if ( (hfsr & ARMV7M_SCB_HFSR_VECTTBL_MASK) != 0 ) {
+      printk("  VECTTBL    : 1  (error in address located in vector table)\n");
+    if ( (hfsr & ARMV7M_SCB_HFSR_FORCED_MASK) != 0 ) {
+      printk("  FORCED     : 1  (configurable fault escalated to hard fault)\n"
-    if ( (hfsr & ARMV7M_SCB_HFSR_DEBUGEVT_MASK ) != 0 ) {
+    if ( (hfsr & ARMV7M_SCB_HFSR_DEBUGEVT_MASK) != 0 ) {
       printk(
         "  DEBUGEVT   : 1  (debug event occurred with debug system disabled)\n"
@@ -206,7 +187,7 @@ static void _ARM_Cortex_M_fault_info_print( void )
 #endif
-void _CPU_Exception_frame_print( const CPU_Exception_frame *frame )
+void _CPU_Exception_frame_print(const CPU_Exception_frame *frame)
   printk(
     "\n"
@@ -248,6 +229,6 @@ void _CPU_Exception_frame_print( const CPU_Exception_frame *frame )
     (intptr_t) frame->vector
-  _ARM_VFP_context_print( frame->vfp_context );
+  _ARM_VFP_context_print(frame->vfp_context);
   _ARM_Cortex_M_fault_info_print();
diff --git a/cpukit/score/cpu/arm/armv4-sync-synchronize.c b/cpukit/score/cpu/arm/armv4-sync-synchronize.c
index 2f454306d8..82b0a69566 100644
--- a/cpukit/score/cpu/arm/armv4-sync-synchronize.c
+++ b/cpukit/score/cpu/arm/armv4-sync-synchronize.c
@@ -35,7 +35,7 @@
-void __sync_synchronize( void )
+void __sync_synchronize(void)
   _ARM_Data_memory_barrier();
diff --git a/cpukit/score/cpu/arm/armv7-thread-idle.c b/cpukit/score/cpu/arm/armv7-thread-idle.c
index 720cb2be83..c4e8e66210 100644
--- a/cpukit/score/cpu/arm/armv7-thread-idle.c
+++ b/cpukit/score/cpu/arm/armv7-thread-idle.c
@@ -40,8 +40,7 @@
-void *_CPU_Thread_Idle_body( uintptr_t ignored )
+void *_CPU_Thread_Idle_body(uintptr_t ignored)
   while ( true ) {
 #ifdef ARM_MULTILIB_HAS_WFI
@@ -49,4 +48,3 @@ void *_CPU_Thread_Idle_body( uintptr_t ignored )
 #endif /* ARM_MULTILIB_HAS_WFI */
diff --git a/cpukit/score/cpu/arm/armv7m-context-initialize.c b/cpukit/score/cpu/arm/armv7m-context-initialize.c
index d67bcf93b5..b0cfbccef2 100644
--- a/cpukit/score/cpu/arm/armv7m-context-initialize.c
+++ b/cpukit/score/cpu/arm/armv7m-context-initialize.c
@@ -48,12 +48,12 @@
 void _CPU_Context_Initialize(
   Context_Control *context,
-  void *stack_area_begin,
-  size_t stack_area_size,
-  uint32_t new_level,
-  void (*entry_point)( void ),
-  bool is_fp,
-  void *tls_area
+  void            *stack_area_begin,
+  size_t           stack_area_size,
+  uint32_t         new_level,
+  void             (*entry_point)(void),
+  bool             is_fp,
+  void            *tls_area
   char *stack_area_end = (char *) stack_area_begin + stack_area_size;
@@ -64,7 +64,7 @@ void _CPU_Context_Initialize(
   context->register_sp = stack_area_end;
   if ( tls_area != NULL ) {
-    context->thread_id = (uint32_t) _TLS_Initialize_area( tls_area );
+    context->thread_id = (uint32_t) _TLS_Initialize_area(tls_area);
diff --git a/cpukit/score/cpu/arm/armv7m-context-restore.c b/cpukit/score/cpu/arm/armv7m-context-restore.c
index b888abe29f..625a33c626 100644
--- a/cpukit/score/cpu/arm/armv7m-context-restore.c
+++ b/cpukit/score/cpu/arm/armv7m-context-restore.c
@@ -43,9 +43,7 @@
 #ifdef ARM_MULTILIB_ARCH_V7M
-void __attribute__((naked)) _CPU_Context_restore(
-  Context_Control *heir
+void __attribute__((naked)) _CPU_Context_restore(Context_Control *heir)
   __asm__ volatile (
     "movw r2, #:lower16:_Per_CPU_Information\n"
diff --git a/cpukit/score/cpu/arm/armv7m-exception-default.c b/cpukit/score/cpu/arm/armv7m-exception-default.c
index 35dde50dc3..6d3eb49ea0 100644
--- a/cpukit/score/cpu/arm/armv7m-exception-default.c
+++ b/cpukit/score/cpu/arm/armv7m-exception-default.c
@@ -42,21 +42,21 @@
-void __attribute__((naked)) _ARMV7M_Exception_default( void )
+void __attribute__((naked)) _ARMV7M_Exception_default(void)
-    /* On exception entry, ARMv7M saves context state onto a stack pointed to
-     * by either MSP or PSP. The value stored in LR indicates whether we were
-     * in Thread or Handler mode, whether we were using the FPU (if any),
-     * and which stack pointer we were using.
-     * In particular, bit 2 of LR will be 0 if we were using MSP.
-     * For a more detailed explanation, see the Exception Entry Behavior
-     * section of the ARMv7M Architecture Reference Manual.
+  /* On exception entry, ARMv7M saves context state onto a stack pointed to
+   * by either MSP or PSP. The value stored in LR indicates whether we were
+   * in Thread or Handler mode, whether we were using the FPU (if any),
+   * and which stack pointer we were using.
+   * In particular, bit 2 of LR will be 0 if we were using MSP.
+   * For a more detailed explanation, see the Exception Entry Behavior
+   * section of the ARMv7M Architecture Reference Manual.
-    /* As we're in Handler mode here, we'll always operate on MSP.
-     * However, we need to store the right SP in our CPU_Exception_frame.
+  /* As we're in Handler mode here, we'll always operate on MSP.
+   * However, we need to store the right SP in our CPU_Exception_frame.
   __asm__ volatile (
     "sub sp, %[cpufsz]\n"   /* Allocate space for a CPU_Exception_frame. */
     "stm sp, {r0-r12}\n"
diff --git a/cpukit/score/cpu/arm/armv7m-exception-handler-get.c b/cpukit/score/cpu/arm/armv7m-exception-handler-get.c
index 41effd1e18..c26d783723 100644
--- a/cpukit/score/cpu/arm/armv7m-exception-handler-get.c
+++ b/cpukit/score/cpu/arm/armv7m-exception-handler-get.c
@@ -43,9 +43,9 @@
-ARMV7M_Exception_handler _ARMV7M_Get_exception_handler( int index )
+ARMV7M_Exception_handler _ARMV7M_Get_exception_handler(int index)
-  return _ARMV7M_SCB->vtor [index];
+  return _ARMV7M_SCB->vtor[index];
 #endif /* ARM_MULTILIB_ARCH_V7M */
diff --git a/cpukit/score/cpu/arm/armv7m-exception-handler-set.c b/cpukit/score/cpu/arm/armv7m-exception-handler-set.c
index 94c9dc5360..9dd81a5df7 100644
--- a/cpukit/score/cpu/arm/armv7m-exception-handler-set.c
+++ b/cpukit/score/cpu/arm/armv7m-exception-handler-set.c
@@ -38,25 +38,22 @@
 #include "config.h"
 #endif
-#include <rtems/score/armv7m.h>
 #include <rtems/rtems/cache.h>
+#include <rtems/score/armv7m.h>
-void _ARMV7M_Set_exception_handler(
-  int index,
-  ARMV7M_Exception_handler handler
+void _ARMV7M_Set_exception_handler(int index, ARMV7M_Exception_handler handler)
-  if ( _ARMV7M_SCB->vtor [index] != handler ) {
-    _ARMV7M_SCB->vtor [index] = handler;
+  if ( _ARMV7M_SCB->vtor[index] != handler ) {
+    _ARMV7M_SCB->vtor[index] = handler;
     rtems_cache_flush_multiple_data_lines(
-      &_ARMV7M_SCB->vtor [index],
-      sizeof(_ARMV7M_SCB->vtor [index])
+      &_ARMV7M_SCB->vtor[index],
+      sizeof(_ARMV7M_SCB->vtor[index])
     rtems_cache_invalidate_multiple_instruction_lines(
diff --git a/cpukit/score/cpu/arm/armv7m-exception-priority-get.c b/cpukit/score/cpu/arm/armv7m-exception-priority-get.c
index bb0892a32f..fdcc2f0f68 100644
--- a/cpukit/score/cpu/arm/armv7m-exception-priority-get.c
+++ b/cpukit/score/cpu/arm/armv7m-exception-priority-get.c
@@ -42,12 +42,12 @@
-int _ARMV7M_Get_exception_priority( int vector )
+int _ARMV7M_Get_exception_priority(int vector)
-  if ( _ARMV7M_Is_vector_an_irq( vector ) ) {
-    return _ARMV7M_NVIC_Get_priority( ARMV7M_IRQ_OF_VECTOR( vector ) );
+  if ( _ARMV7M_Is_vector_an_irq(vector) ) {
+    return _ARMV7M_NVIC_Get_priority(ARMV7M_IRQ_OF_VECTOR(vector));
   } else if ( vector >= ARMV7M_VECTOR_MEM_MANAGE ) {
-    return _ARMV7M_SCB->shpr [vector - 4];
+    return _ARMV7M_SCB->shpr[vector - 4];
   } else {
     return vector - 4;
diff --git a/cpukit/score/cpu/arm/armv7m-exception-priority-handler.c b/cpukit/score/cpu/arm/armv7m-exception-priority-handler.c
index b94366e07c..7f868fed79 100644
--- a/cpukit/score/cpu/arm/armv7m-exception-priority-handler.c
+++ b/cpukit/score/cpu/arm/armv7m-exception-priority-handler.c
@@ -43,13 +43,13 @@
 void _ARMV7M_Set_exception_priority_and_handler(
-  int index,
-  int priority,
+  int                      index,
+  int                      priority,
-  _ARMV7M_Set_exception_priority( index, priority );
-  _ARMV7M_Set_exception_handler( index, handler );
+  _ARMV7M_Set_exception_priority(index, priority);
+  _ARMV7M_Set_exception_handler(index, handler);
diff --git a/cpukit/score/cpu/arm/armv7m-exception-priority-set.c b/cpukit/score/cpu/arm/armv7m-exception-priority-set.c
index 05136a47db..0cd7a4f28a 100644
--- a/cpukit/score/cpu/arm/armv7m-exception-priority-set.c
+++ b/cpukit/score/cpu/arm/armv7m-exception-priority-set.c
@@ -42,12 +42,12 @@
-void _ARMV7M_Set_exception_priority( int vector, int priority )
+void _ARMV7M_Set_exception_priority(int vector, int priority)
-    _ARMV7M_NVIC_Set_priority( ARMV7M_IRQ_OF_VECTOR( vector ), priority );
+    _ARMV7M_NVIC_Set_priority(ARMV7M_IRQ_OF_VECTOR(vector), priority);
-    _ARMV7M_SCB->shpr [vector - 4] = (uint8_t) priority;
+    _ARMV7M_SCB->shpr[vector - 4] = (uint8_t) priority;
diff --git a/cpukit/score/cpu/arm/armv7m-initialize.c b/cpukit/score/cpu/arm/armv7m-initialize.c
index 0f47b49af7..1c9a66523b 100644
--- a/cpukit/score/cpu/arm/armv7m-initialize.c
+++ b/cpukit/score/cpu/arm/armv7m-initialize.c
@@ -42,7 +42,7 @@
-void _CPU_Initialize( void )
+void _CPU_Initialize(void)
    * The exception handler used to carry out the thead dispatching must have
diff --git a/cpukit/score/cpu/arm/armv7m-isr-dispatch.c b/cpukit/score/cpu/arm/armv7m-isr-dispatch.c
index ea168969ba..dfc125d545 100644
--- a/cpukit/score/cpu/arm/armv7m-isr-dispatch.c
+++ b/cpukit/score/cpu/arm/armv7m-isr-dispatch.c
@@ -43,7 +43,7 @@
-static void __attribute__((naked)) _ARMV7M_Thread_dispatch( void )
+static void __attribute__((naked)) _ARMV7M_Thread_dispatch(void)
   __asm__ volatile (
     "bl _Thread_Dispatch\n"
@@ -53,7 +53,7 @@ static void __attribute__((naked)) _ARMV7M_Thread_dispatch( void )
-static void _ARMV7M_Trigger_lazy_floating_point_context_save( void )
+static void _ARMV7M_Trigger_lazy_floating_point_context_save(void)
   __asm__ volatile (
@@ -62,7 +62,7 @@ static void _ARMV7M_Trigger_lazy_floating_point_context_save( void )
 #endif
-void _ARMV7M_Pendable_service_call( void )
+void _ARMV7M_Pendable_service_call(void)
   Per_CPU_Control *cpu_self = _Per_CPU_Get();
@@ -73,7 +73,7 @@ void _ARMV7M_Pendable_service_call( void )
    * this interrupt service may be delayed until interrupts are enable again.
   if (
-    ( cpu_self->isr_nest_level | cpu_self->thread_dispatch_disable_level ) == 0
+    (cpu_self->isr_nest_level | cpu_self->thread_dispatch_disable_level) == 0
     ARMV7M_Exception_frame *ef;
@@ -84,29 +84,29 @@ void _ARMV7M_Pendable_service_call( void )
     ef = (ARMV7M_Exception_frame *) _ARMV7M_Get_PSP();
     --ef;
-    _ARMV7M_Set_PSP( (uint32_t) ef );
+    _ARMV7M_Set_PSP((uint32_t) ef);
      * According to "ARMv7-M Architecture Reference Manual" section B1.5.6
      * "Exception entry behavior" the return address is half-word aligned.
-    ef->register_pc = (void *)
-      ((uintptr_t) _ARMV7M_Thread_dispatch & ~((uintptr_t) 1));
+    ef->register_pc = (void *) ((uintptr_t) _ARMV7M_Thread_dispatch &
+                                ~((uintptr_t) 1));
     ef->register_xpsr = 0x01000000U;
-void _ARMV7M_Supervisor_call( void )
+void _ARMV7M_Supervisor_call(void)
-  Per_CPU_Control *cpu_self = _Per_CPU_Get();
+  Per_CPU_Control        *cpu_self = _Per_CPU_Get();
   _ARMV7M_Trigger_lazy_floating_point_context_save();
   ++ef;
   cpu_self->isr_nest_level = 0;
diff --git a/cpukit/score/cpu/arm/armv7m-isr-enter-leave.c b/cpukit/score/cpu/arm/armv7m-isr-enter-leave.c
index 1490f6e219..04f7ab1749 100644
--- a/cpukit/score/cpu/arm/armv7m-isr-enter-leave.c
+++ b/cpukit/score/cpu/arm/armv7m-isr-enter-leave.c
@@ -44,7 +44,7 @@
-void _ARMV7M_Interrupt_service_enter( void )
+void _ARMV7M_Interrupt_service_enter(void)
@@ -52,7 +52,7 @@ void _ARMV7M_Interrupt_service_enter( void )
   ++cpu_self->isr_nest_level;
-void _ARMV7M_Interrupt_service_leave( void )
+void _ARMV7M_Interrupt_service_leave(void)
diff --git a/cpukit/score/cpu/arm/armv7m-isr-level-get.c b/cpukit/score/cpu/arm/armv7m-isr-level-get.c
index cc2b674e13..48b11d923a 100644
--- a/cpukit/score/cpu/arm/armv7m-isr-level-get.c
+++ b/cpukit/score/cpu/arm/armv7m-isr-level-get.c
@@ -41,7 +41,7 @@
-uint32_t _CPU_ISR_Get_level( void )
+uint32_t _CPU_ISR_Get_level(void)
   return _ARMV7M_Get_basepri() != 0;
diff --git a/cpukit/score/cpu/arm/armv7m-isr-level-set.c b/cpukit/score/cpu/arm/armv7m-isr-level-set.c
index 72c9684025..982c5df687 100644
--- a/cpukit/score/cpu/arm/armv7m-isr-level-set.c
+++ b/cpukit/score/cpu/arm/armv7m-isr-level-set.c
@@ -41,9 +41,9 @@
-void _CPU_ISR_Set_level( uint32_t level )
+void _CPU_ISR_Set_level(uint32_t level)
-  _ARMV7M_Set_basepri( 0 );
+  _ARMV7M_Set_basepri(0);
diff --git a/cpukit/score/cpu/arm/armv7m-isr-vector-install.c b/cpukit/score/cpu/arm/armv7m-isr-vector-install.c
index c1e9eb70cb..a9e14ba1e6 100644
--- a/cpukit/score/cpu/arm/armv7m-isr-vector-install.c
+++ b/cpukit/score/cpu/arm/armv7m-isr-vector-install.c
@@ -51,12 +51,12 @@ void _CPU_ISR_install_vector(
   uint32_t level;
-  _ISR_Local_disable( level );
+  _ISR_Local_disable(level);
   if ( old_handler != NULL ) {
-    *old_handler = _ARMV7M_Get_exception_handler( (int) vector );
+    *old_handler = _ARMV7M_Get_exception_handler((int) vector);
-  _ARMV7M_Set_exception_handler( (int) vector, new_handler );
-  _ISR_Local_enable( level );
+  _ARMV7M_Set_exception_handler((int) vector, new_handler);
+  _ISR_Local_enable(level);
diff --git a/cpukit/score/cpu/arm/armv7m-multitasking-start-stop.c b/cpukit/score/cpu/arm/armv7m-multitasking-start-stop.c
index a9b59dec84..4c6d969f4f 100644
--- a/cpukit/score/cpu/arm/armv7m-multitasking-start-stop.c
+++ b/cpukit/score/cpu/arm/armv7m-multitasking-start-stop.c
@@ -42,9 +42,7 @@
-void __attribute__((naked)) _ARMV7M_Start_multitasking(
+void __attribute__((naked)) _ARMV7M_Start_multitasking(Context_Control *heir)
   __asm__ volatile (
     /* Restore heir context */
diff --git a/cpukit/score/cpu/arm/cpu.c b/cpukit/score/cpu/arm/cpu.c
index 65f1ad2014..c7d7527dce 100644
--- a/cpukit/score/cpu/arm/cpu.c
+++ b/cpukit/score/cpu/arm/cpu.c
@@ -61,8 +61,7 @@
 #endif
 RTEMS_STATIC_ASSERT(
-  offsetof( Context_Control, thread_id )
-    == ARM_CONTEXT_CONTROL_THREAD_ID_OFFSET,
+  offsetof(Context_Control, thread_id) == ARM_CONTEXT_CONTROL_THREAD_ID_OFFSET,
@@ -83,23 +82,23 @@ RTEMS_STATIC_ASSERT(
 #endif
-  sizeof( CPU_Exception_frame ) == ARM_EXCEPTION_FRAME_SIZE,
+  sizeof(CPU_Exception_frame) == ARM_EXCEPTION_FRAME_SIZE,
-  sizeof( CPU_Exception_frame ) % CPU_STACK_ALIGNMENT == 0,
+  sizeof(CPU_Exception_frame) % CPU_STACK_ALIGNMENT == 0,
   CPU_Exception_frame_alignment
-  offsetof( CPU_Exception_frame, register_sp )
-    == ARM_EXCEPTION_FRAME_REGISTER_SP_OFFSET,
+  offsetof(CPU_Exception_frame, register_sp) ==
+    ARM_EXCEPTION_FRAME_REGISTER_SP_OFFSET,
-  sizeof( ARM_VFP_context ) == ARM_VFP_CONTEXT_SIZE,
+  sizeof(ARM_VFP_context) == ARM_VFP_CONTEXT_SIZE,
@@ -107,12 +106,12 @@ RTEMS_STATIC_ASSERT(
   Context_Control *the_context,
-  bool is_fp,
-  void *tls_area
+  bool             is_fp,
+  void            *tls_area
   (void) new_level;
@@ -120,14 +119,14 @@ void _CPU_Context_Initialize(
   the_context->register_sp = (uint32_t) stack_area_begin + stack_area_size;
   the_context->register_lr = (uint32_t) entry_point;
   the_context->isr_dispatch_disable = 0;
-  the_context->thread_id = (uint32_t) tls_area;
+  the_context->thread_id            = (uint32_t) tls_area;
-    the_context->thread_id = (uint32_t) _TLS_Initialize_area( tls_area );
+    the_context->thread_id = (uint32_t) _TLS_Initialize_area(tls_area);
   uint32_t arm_switch_reg;
@@ -144,7 +143,7 @@ void _CPU_ISR_Set_level( uint32_t level )
   ARM_SWITCH_REGISTERS;
   uint32_t level;
@@ -157,7 +156,7 @@ uint32_t _CPU_ISR_Get_level( void )
     : [level] "=&r" (level) ARM_SWITCH_ADDITIONAL_OUTPUT
-  return ( level & ARM_PSR_I ) != 0;
+  return (level & ARM_PSR_I) != 0;
@@ -169,34 +168,34 @@ void _CPU_ISR_install_vector(
 #pragma GCC diagnostic push
 #pragma GCC diagnostic ignored "-Warray-bounds"
   /* Redirection table starts at the end of the vector table */
-  CPU_ISR_handler volatile  *table = (CPU_ISR_handler *) (MAX_EXCEPTIONS * 4);
+  CPU_ISR_handler volatile *table = (CPU_ISR_handler *) (MAX_EXCEPTIONS * 4);
-  CPU_ISR_handler current_handler = table [vector];
+  CPU_ISR_handler current_handler = table[vector];
   /* The current handler is now the old one */
-  if (old_handler != NULL) {
+  if ( old_handler != NULL ) {
     *old_handler = current_handler;
   /* Write only if necessary to avoid writes to a maybe read-only memory */
-  if (current_handler != new_handler) {
-    table [vector] = new_handler;
+  if ( current_handler != new_handler ) {
+    table[vector] = new_handler;
 #pragma GCC diagnostic pop
   /* Do nothing */
 #endif /* ARM_MULTILIB_ARCH_V4 */
-void _CPU_Fatal_halt( uint32_t source, CPU_Uint32ptr error )
+void _CPU_Fatal_halt(uint32_t source, CPU_Uint32ptr error)
   ISR_Level level;
-  _CPU_ISR_Disable( level );
+  _CPU_ISR_Disable(level);
   (void) level;
   __asm__ volatile ("mov r0, %0\n"
2.34.1
