[PATCH] score/aarch64: style fixes
Tue Jul 25 21:05:42 UTC 2023
 .../cpu/aarch64/aarch64-exception-default.c   |  22 +--
 .../aarch64/aarch64-exception-frame-print.c   | 155 ++++++++++--------
 .../score/cpu/aarch64/aarch64-thread-idle.c   |   2 +-
 cpukit/score/cpu/aarch64/cpu.c                |  61 ++++---
 4 files changed, 132 insertions(+), 108 deletions(-)
diff --git a/cpukit/score/cpu/aarch64/aarch64-exception-default.c b/cpukit/score/cpu/aarch64/aarch64-exception-default.c
index f1591cbd5d..df15193996 100644
--- a/cpukit/score/cpu/aarch64/aarch64-exception-default.c
+++ b/cpukit/score/cpu/aarch64/aarch64-exception-default.c
@@ -46,9 +46,9 @@
 #include <rtems/score/cpu.h>
-void _AArch64_Exception_default( CPU_Exception_frame *frame )
+void _AArch64_Exception_default(CPU_Exception_frame *frame)
-  uint64_t EC = AARCH64_ESR_EL1_EC_GET( frame->register_syndrome );
+  uint64_t EC = AARCH64_ESR_EL1_EC_GET(frame->register_syndrome);
   /* Emulate FPSR flags for FENV if a FPU exception occurred */
   if ( EC == 0x2c ) {
@@ -59,19 +59,19 @@ void _AArch64_Exception_default( CPU_Exception_frame *frame )
      * functions executed in that context will need this information to be
      * accurate.
-    uint64_t ISS = AARCH64_ESR_EL1_EC_GET( frame->register_syndrome );
+    uint64_t ISS = AARCH64_ESR_EL1_EC_GET(frame->register_syndrome);
     /* If the exception bits are valid, use them */
-    if ( ( ISS & ( 1 << 23 ) ) != 0 ) {
+    if ( (ISS & (1 << 23)) != 0 ) {
       /* The bits of the lower byte match the FPSR exception bits */
-      frame->register_fpsr |= ( ISS & 0xff );
+      frame->register_fpsr |= (ISS & 0xff);
-  rtems_fatal( RTEMS_FATAL_SOURCE_EXCEPTION, (rtems_fatal_code) frame );
+  rtems_fatal(RTEMS_FATAL_SOURCE_EXCEPTION, (rtems_fatal_code) frame);
-void _CPU_Exception_disable_thread_dispatch( void )
+void _CPU_Exception_disable_thread_dispatch(void)
   Per_CPU_Control *cpu_self = _Per_CPU_Get();
@@ -88,9 +88,9 @@ void _AArch64_Exception_frame_copy(
   *new_ef = *old_ef;
-int _CPU_Exception_frame_get_signal( CPU_Exception_frame *ef )
+int _CPU_Exception_frame_get_signal(CPU_Exception_frame *ef)
-  uint64_t EC = AARCH64_ESR_EL1_EC_GET( ef->register_syndrome );
+  uint64_t EC = AARCH64_ESR_EL1_EC_GET(ef->register_syndrome);
   switch ( EC ) {
     case 0x1:  /* WFI */
@@ -115,13 +115,13 @@ int _CPU_Exception_frame_get_signal( CPU_Exception_frame *ef )
-void _CPU_Exception_frame_set_resume( CPU_Exception_frame *ef, void *address )
+void _CPU_Exception_frame_set_resume(CPU_Exception_frame *ef, void *address)
   ef->register_pc = address;
 #define AARCH64_INSTRUCTION_SIZE 4
-void  _CPU_Exception_frame_make_resume_next_instruction( CPU_Exception_frame *ef )
+void _CPU_Exception_frame_make_resume_next_instruction(CPU_Exception_frame *ef)
   ef->register_pc += AARCH64_INSTRUCTION_SIZE;
diff --git a/cpukit/score/cpu/aarch64/aarch64-exception-frame-print.c b/cpukit/score/cpu/aarch64/aarch64-exception-frame-print.c
index c5b477c72f..e0fbab68dc 100644
--- a/cpukit/score/cpu/aarch64/aarch64-exception-frame-print.c
+++ b/cpukit/score/cpu/aarch64/aarch64-exception-frame-print.c
@@ -44,37 +44,37 @@
 #include <inttypes.h>
+#include <rtems/bspIo.h>
 #include <rtems/score/io.h>
-#include <rtems/bspIo.h>
 typedef struct {
-	char *s;
-	size_t n;
+  char  *s;
+  size_t n;
 } String_Context;
-static void _CPU_Put_char( int c, void *arg )
+static void _CPU_Put_char(int c, void *arg)
   String_Context *sctx = arg;
-  size_t n = sctx->n;
+  size_t          n    = sctx->n;
-  if (n > 0) {
+  if ( n > 0 ) {
     char *s = sctx->s;
-    *s = (char) c;
+    *s      = (char) c;
     sctx->s = s + 1;
     sctx->n = n - 1;
 static void _CPU_Binary_sprintf(
-  char *s,
-  size_t maxlen,
+  char    *s,
+  size_t   maxlen,
   uint32_t num_bits,
   uint32_t value
   String_Context sctx;
-  uint32_t mask;
+  uint32_t       mask;
   sctx.s = s;
   sctx.n = maxlen;
@@ -82,14 +82,14 @@ static void _CPU_Binary_sprintf(
   mask = 1 << (num_bits - 1);
   while ( mask != 0 ) {
-    _IO_Printf( _CPU_Put_char, &sctx, "%d", (value & mask ? 1 : 0) );
+    _IO_Printf(_CPU_Put_char, &sctx, "%d", (value & mask ? 1 : 0));
     mask >>= 1;
   s[num_bits] = '\0';
-static const char* _CPU_Exception_class_to_string( uint16_t exception_class )
+static const char *_CPU_Exception_class_to_string(uint16_t exception_class)
   /* The 80 character limit is intentionally ignored for these strings. */
   switch ( exception_class ) {
@@ -142,82 +142,107 @@ static const char* _CPU_Exception_class_to_string( uint16_t exception_class )
-void _CPU_Exception_frame_print( const CPU_Exception_frame *frame )
+void _CPU_Exception_frame_print(const CPU_Exception_frame *frame)
-  uint32_t ec;
-  uint32_t il;
-  uint32_t iss;
-  char     ec_str[7];
-  char     iss_str[26];
-  int      i;
+  uint32_t         ec;
+  uint32_t         il;
+  uint32_t         iss;
+  char             ec_str[7];
+  char             iss_str[26];
+  int              i;
   const uint128_t *qx;
   printk(
     "\n"
-    "X0   = 0x%016" PRIx64  " X17  = 0x%016" PRIx64 "\n"
-    "X1   = 0x%016" PRIx64  " X18  = 0x%016" PRIx64 "\n"
-    "X2   = 0x%016" PRIx64  " X19  = 0x%016" PRIx64 "\n"
-    "X3   = 0x%016" PRIx64  " X20  = 0x%016" PRIx64 "\n"
-    "X4   = 0x%016" PRIx64  " X21  = 0x%016" PRIx64 "\n"
-    "X5   = 0x%016" PRIx64  " X22  = 0x%016" PRIx64 "\n"
-    "X6   = 0x%016" PRIx64  " X23  = 0x%016" PRIx64 "\n"
-    "X7   = 0x%016" PRIx64  " X24  = 0x%016" PRIx64 "\n"
-    "X8   = 0x%016" PRIx64  " X25  = 0x%016" PRIx64 "\n"
-    "X9   = 0x%016" PRIx64  " X26  = 0x%016" PRIx64 "\n"
-    "X10  = 0x%016" PRIx64  " X27  = 0x%016" PRIx64 "\n"
-    "X11  = 0x%016" PRIx64  " X28  = 0x%016" PRIx64 "\n"
-    "X12  = 0x%016" PRIx64  " FP   = 0x%016" PRIx64 "\n"
-    "X13  = 0x%016" PRIx64  " LR   = 0x%016" PRIxPTR "\n"
-    "X14  = 0x%016" PRIx64  " SP   = 0x%016" PRIxPTR "\n"
-    "X15  = 0x%016" PRIx64  " PC   = 0x%016" PRIxPTR "\n"
-    "X16  = 0x%016" PRIx64  " DAIF = 0x%016" PRIx64 "\n"
+    "X0   = 0x%016" PRIx64 " X17  = 0x%016" PRIx64 "\n"
+    "X1   = 0x%016" PRIx64 " X18  = 0x%016" PRIx64 "\n"
+    "X2   = 0x%016" PRIx64 " X19  = 0x%016" PRIx64 "\n"
+    "X3   = 0x%016" PRIx64 " X20  = 0x%016" PRIx64 "\n"
+    "X4   = 0x%016" PRIx64 " X21  = 0x%016" PRIx64 "\n"
+    "X5   = 0x%016" PRIx64 " X22  = 0x%016" PRIx64 "\n"
+    "X6   = 0x%016" PRIx64 " X23  = 0x%016" PRIx64 "\n"
+    "X7   = 0x%016" PRIx64 " X24  = 0x%016" PRIx64 "\n"
+    "X8   = 0x%016" PRIx64 " X25  = 0x%016" PRIx64 "\n"
+    "X9   = 0x%016" PRIx64 " X26  = 0x%016" PRIx64 "\n"
+    "X10  = 0x%016" PRIx64 " X27  = 0x%016" PRIx64 "\n"
+    "X11  = 0x%016" PRIx64 " X28  = 0x%016" PRIx64 "\n"
+    "X12  = 0x%016" PRIx64 " FP   = 0x%016" PRIx64 "\n"
+    "X13  = 0x%016" PRIx64 " LR   = 0x%016" PRIxPTR "\n"
+    "X14  = 0x%016" PRIx64 " SP   = 0x%016" PRIxPTR "\n"
+    "X15  = 0x%016" PRIx64 " PC   = 0x%016" PRIxPTR "\n"
+    "X16  = 0x%016" PRIx64 " DAIF = 0x%016" PRIx64 "\n"
     "VEC  = 0x%016" PRIxPTR " CPSR = 0x%016" PRIx64 "\n",
-    frame->register_x0, frame->register_x17,
-    frame->register_x1, frame->register_x18,
-    frame->register_x2, frame->register_x19,
-    frame->register_x3, frame->register_x20,
-    frame->register_x4, frame->register_x21,
-    frame->register_x5, frame->register_x22,
-    frame->register_x6, frame->register_x23,
-    frame->register_x7, frame->register_x24,
-    frame->register_x8, frame->register_x25,
-    frame->register_x9, frame->register_x26,
-    frame->register_x10, frame->register_x27,
-    frame->register_x11, frame->register_x28,
-    frame->register_x12, frame->register_fp,
-    frame->register_x13, (intptr_t) frame->register_lr,
-    frame->register_x14, (intptr_t) frame->register_sp,
-    frame->register_x15, (intptr_t) frame->register_pc,
-    frame->register_x16, frame->register_daif,
-    (intptr_t) frame->vector, frame->register_cpsr
+    frame->register_x0,
+    frame->register_x17,
+    frame->register_x1,
+    frame->register_x18,
+    frame->register_x2,
+    frame->register_x19,
+    frame->register_x3,
+    frame->register_x20,
+    frame->register_x4,
+    frame->register_x21,
+    frame->register_x5,
+    frame->register_x22,
+    frame->register_x6,
+    frame->register_x23,
+    frame->register_x7,
+    frame->register_x24,
+    frame->register_x8,
+    frame->register_x25,
+    frame->register_x9,
+    frame->register_x26,
+    frame->register_x10,
+    frame->register_x27,
+    frame->register_x11,
+    frame->register_x28,
+    frame->register_x12,
+    frame->register_fp,
+    frame->register_x13,
+    (intptr_t) frame->register_lr,
+    frame->register_x14,
+    (intptr_t) frame->register_sp,
+    frame->register_x15,
+    (intptr_t) frame->register_pc,
+    frame->register_x16,
+    frame->register_daif,
+    (intptr_t) frame->vector,
+    frame->register_cpsr
-  ec = frame->register_syndrome >> 26 & 0x3f;
-  il = frame->register_syndrome >> 25 & 0x1;
+  ec  = frame->register_syndrome >> 26 & 0x3f;
+  il  = frame->register_syndrome >> 25 & 0x1;
   iss = frame->register_syndrome & 0x1ffffff;
-  _CPU_Binary_sprintf( ec_str, sizeof( ec_str ), sizeof( ec_str ) - 1, ec );
-  _CPU_Binary_sprintf( iss_str, sizeof( iss_str ), sizeof( iss_str ) - 1, iss );
+  _CPU_Binary_sprintf(ec_str, sizeof(ec_str), sizeof(ec_str) - 1, ec);
+  _CPU_Binary_sprintf(iss_str, sizeof(iss_str), sizeof(iss_str) - 1, iss);
   printk(
-    "ESR  = EC: 0b%s" " IL: 0b%d" " ISS: 0b%s" "\n"
+    "ESR  = EC: 0b%s"
+    " IL: 0b%d"
+    " ISS: 0b%s"
+    "\n"
     "       %s\n",
-    ec_str, il, iss_str, _CPU_Exception_class_to_string( ec )
+    ec_str,
+    il,
+    iss_str,
+    _CPU_Exception_class_to_string(ec)
-  printk( "FAR  = 0x%016" PRIx64 "\n", frame->register_fault_address );
+  printk("FAR  = 0x%016" PRIx64 "\n", frame->register_fault_address);
   qx = &frame->register_q0;
   printk(
     "FPCR = 0x%016" PRIx64 " FPSR = 0x%016" PRIx64 "\n",
-    frame->register_fpcr, frame->register_fpsr
+    frame->register_fpcr,
-  for ( i = 0 ; i < 32 ; ++i ) {
-    uint64_t low = (uint64_t) qx[i];
+  for ( i = 0; i < 32; ++i ) {
+    uint64_t low  = (uint64_t) qx[i];
     uint64_t high = (uint64_t) (qx[i] >> 64);
-    printk( "Q%02i  = 0x%016" PRIx64 "%016" PRIx64 "\n", i, high, low );
+    printk("Q%02i  = 0x%016" PRIx64 "%016" PRIx64 "\n", i, high, low);
diff --git a/cpukit/score/cpu/aarch64/aarch64-thread-idle.c b/cpukit/score/cpu/aarch64/aarch64-thread-idle.c
index ce93b4facd..188ac618d9 100644
--- a/cpukit/score/cpu/aarch64/aarch64-thread-idle.c
+++ b/cpukit/score/cpu/aarch64/aarch64-thread-idle.c
@@ -38,7 +38,7 @@
-void *_CPU_Thread_Idle_body( uintptr_t ignored )
+void *_CPU_Thread_Idle_body(uintptr_t ignored)
   while ( true ) {
     __asm__ volatile ("wfi");
diff --git a/cpukit/score/cpu/aarch64/cpu.c b/cpukit/score/cpu/aarch64/cpu.c
index 207508302b..e8b68f7bbe 100644
--- a/cpukit/score/cpu/aarch64/cpu.c
+++ b/cpukit/score/cpu/aarch64/cpu.c
@@ -71,66 +71,65 @@
 #endif
 RTEMS_STATIC_ASSERT(
-  sizeof( CPU_Exception_frame ) == AARCH64_EXCEPTION_FRAME_SIZE,
+  sizeof(CPU_Exception_frame) == AARCH64_EXCEPTION_FRAME_SIZE,
-  sizeof( CPU_Exception_frame ) % CPU_STACK_ALIGNMENT == 0,
+  sizeof(CPU_Exception_frame) % CPU_STACK_ALIGNMENT == 0,
   CPU_Exception_frame_alignment
-  offsetof( CPU_Exception_frame, register_sp )
-    == AARCH64_EXCEPTION_FRAME_REGISTER_SP_OFFSET,
+  offsetof(CPU_Exception_frame, register_sp) ==
+    AARCH64_EXCEPTION_FRAME_REGISTER_SP_OFFSET,
-  offsetof( CPU_Exception_frame, register_lr )
-    == AARCH64_EXCEPTION_FRAME_REGISTER_LR_OFFSET,
+  offsetof(CPU_Exception_frame, register_lr) ==
+    AARCH64_EXCEPTION_FRAME_REGISTER_LR_OFFSET,
-  offsetof( CPU_Exception_frame, register_daif )
-    == AARCH64_EXCEPTION_FRAME_REGISTER_DAIF_OFFSET,
+  offsetof(CPU_Exception_frame, register_daif) ==
+    AARCH64_EXCEPTION_FRAME_REGISTER_DAIF_OFFSET,
-  offsetof( CPU_Exception_frame, register_syndrome )
-    == AARCH64_EXCEPTION_FRAME_REGISTER_SYNDROME_OFFSET,
+  offsetof(CPU_Exception_frame, register_syndrome) ==
+    AARCH64_EXCEPTION_FRAME_REGISTER_SYNDROME_OFFSET,
-  offsetof( CPU_Exception_frame, vector )
-    == AARCH64_EXCEPTION_FRAME_REGISTER_VECTOR_OFFSET,
+  offsetof(CPU_Exception_frame, vector) ==
+    AARCH64_EXCEPTION_FRAME_REGISTER_VECTOR_OFFSET,
-  offsetof( CPU_Exception_frame, register_fpsr )
-    == AARCH64_EXCEPTION_FRAME_REGISTER_FPSR_OFFSET,
+  offsetof(CPU_Exception_frame, register_fpsr) ==
+    AARCH64_EXCEPTION_FRAME_REGISTER_FPSR_OFFSET,
-  offsetof( CPU_Exception_frame, register_q0 )
-    == AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET,
+  offsetof(CPU_Exception_frame, register_q0) ==
+    AARCH64_EXCEPTION_FRAME_REGISTER_Q0_OFFSET,
 void _CPU_Context_Initialize(
   Context_Control *the_context,
-  void *stack_area_begin,
-  size_t stack_area_size,
-  uint64_t new_level,
-  void (*entry_point)( void ),
-  bool is_fp,
-  void *tls_area
+  void            *stack_area_begin,
+  size_t           stack_area_size,
+  uint64_t         new_level,
+  void             (*entry_point)(void),
+  bool             is_fp,
+  void            *tls_area
   (void) new_level;
@@ -142,11 +141,11 @@ void _CPU_Context_Initialize(
   the_context->thread_id = (uintptr_t) tls_area;
   if ( tls_area != NULL ) {
-    the_context->thread_id = (uintptr_t) _TLS_Initialize_area( tls_area );
+    the_context->thread_id = (uintptr_t) _TLS_Initialize_area(tls_area);
-void _CPU_ISR_Set_level( uint32_t level )
+void _CPU_ISR_Set_level(uint32_t level)
   /* Set the mask bit if interrupts are disabled */
   if ( level ) {
@@ -162,7 +161,7 @@ void _CPU_ISR_Set_level( uint32_t level )
-uint32_t _CPU_ISR_Get_level( void )
+uint32_t _CPU_ISR_Get_level(void)
   uint64_t level;
@@ -171,23 +170,23 @@ uint32_t _CPU_ISR_Get_level( void )
     : [level] "=&r" (level)
-  return ( level & AARCH64_PSTATE_I ) != 0;
+  return (level & AARCH64_PSTATE_I) != 0;
-void _CPU_Initialize( void )
+void _CPU_Initialize(void)
   /* Do nothing */
-void _CPU_Fatal_halt( uint32_t source, CPU_Uint32ptr error )
+void _CPU_Fatal_halt(uint32_t source, CPU_Uint32ptr error)
   ISR_Level level;
-  _CPU_ISR_Disable( level );
+  _CPU_ISR_Disable(level);
   (void) level;
   __asm__ volatile ("mov x0, %0\n"
                 : "=r" (error)
                 : "0" (error)
                 : "x0" );
-  while (1);
+  while ( 1 );
2.34.1
