[PATCH rtems-docs 0/2] Sphinx Version Check
Tue Jul 25 22:03:15 UTC 2023
Looks good.
Thanks
On 26/7/2023 6:25 am, Joel Sherrill wrote:
> Hi
> There has been Discord and email discussion that upgrading to Sphinx >=
> 6.0 breaks unordered bullet lists. But using Sphinx < 6.0 does not
> produce correct results with the patch which enabled us to use newer
> versions of Sphinx. There are two patches in this series.
> (1) Reverts the patch which broke document generation. Hopefully this
> can be reapplied once someone with time and more Sphinx knowledge than I
> have figures out what is actually broken.
> (2) Enhances the Sphinx version check to be able to check for a version
> greater than a minimum (current behavior) or if the Sphinx version is
> within an acceptable range. The acceptable min/max versions are set at
> the top of the file.
> I think these are simple patches to unwedge documentation generation
> until a solution allowing us to upgrade is figured out. Then the minimum
> can be changed to 6.0 and maximum to None.
> OK to commit?
> --joel
> Joel Sherrill (2):
>   layout.html: Revert patch forcing Spinx to >= 6.0
>   common/waf.py: Add option to check maximum Sphinx version
>  common/sphinx_rtd_theme_rtems/layout.html |  2 --
>  common/waf.py                             | 17 ++++++++++++++---
>  2 files changed, 14 insertions(+), 5 deletions(-)
