[PATCH] score/arm: style fixes
Tue Jul 25 22:48:38 UTC 2023
I may have missed something. Commented in one place.
It looks like mostly spaces inside () and variable/parameter declaration
changes.
On Tue, Jul 25, 2023 at 4:38 PM Gedare Bloom <gedare at rtems.org> wrote:
>  cpukit/score/cpu/arm/__aeabi_read_tp.c        |   2 +-
>  cpukit/score/cpu/arm/__tls_get_addr.c         |   4 +-
>  .../score/cpu/arm/aarch32-psma-init-default.c |   2 +-
>  cpukit/score/cpu/arm/aarch32-psma-init.c      |  82 ++++-----
>  cpukit/score/cpu/arm/arm-exception-default.c  |   6 +-
>  .../score/cpu/arm/arm-exception-frame-print.c | 159 ++++++++----------
>  cpukit/score/cpu/arm/armv4-sync-synchronize.c |   2 +-
>  cpukit/score/cpu/arm/armv7-thread-idle.c      |   4 +-
>  .../score/cpu/arm/armv7m-context-initialize.c |  14 +-
>  cpukit/score/cpu/arm/armv7m-context-restore.c |   4 +-
>  .../score/cpu/arm/armv7m-exception-default.c  |  26 +--
>  .../cpu/arm/armv7m-exception-handler-get.c    |   4 +-
>  .../cpu/arm/armv7m-exception-handler-set.c    |  19 +--
>  .../cpu/arm/armv7m-exception-priority-get.c   |   8 +-
>  .../arm/armv7m-exception-priority-handler.c   |   8 +-
>  .../cpu/arm/armv7m-exception-priority-set.c   |   8 +-
>  cpukit/score/cpu/arm/armv7m-initialize.c      |   2 +-
>  cpukit/score/cpu/arm/armv7m-isr-dispatch.c    |  20 +--
>  cpukit/score/cpu/arm/armv7m-isr-enter-leave.c |   4 +-
>  cpukit/score/cpu/arm/armv7m-isr-level-get.c   |   2 +-
>  cpukit/score/cpu/arm/armv7m-isr-level-set.c   |   4 +-
>  .../score/cpu/arm/armv7m-isr-vector-install.c |   8 +-
>  .../cpu/arm/armv7m-multitasking-start-stop.c  |   4 +-
>  cpukit/score/cpu/arm/cpu.c                    |  51 +++---
>  24 files changed, 209 insertions(+), 238 deletions(-)
> diff --git a/cpukit/score/cpu/arm/__aeabi_read_tp.c
> b/cpukit/score/cpu/arm/__aeabi_read_tp.c
> index 0f4eba8d9a..e3bc529f18 100644
> --- a/cpukit/score/cpu/arm/__aeabi_read_tp.c
> +++ b/cpukit/score/cpu/arm/__aeabi_read_tp.c
> @@ -37,8 +37,8 @@
>  #include "config.h"
>  #endif
> -#include <rtems/score/thread.h>
>  #include <rtems/score/percpu.h>
> +#include <rtems/score/thread.h>
>  #ifndef RTEMS_SMP
> diff --git a/cpukit/score/cpu/arm/__tls_get_addr.c
> b/cpukit/score/cpu/arm/__tls_get_addr.c
> index 7ef42fdcb4..fe38368812 100644
> --- a/cpukit/score/cpu/arm/__tls_get_addr.c
> +++ b/cpukit/score/cpu/arm/__tls_get_addr.c
> @@ -47,8 +47,8 @@ void *__tls_get_addr(const TLS_Index *ti);
>    const Thread_Control *executing = _Thread_Get_executing();
> -  void *tls_data = (char *) executing->Registers.thread_id
> -    + _TLS_Get_thread_control_block_area_size();
> +  void                 *tls_data  = (char *)
> executing->Registers.thread_id;
> +  tls_data += _TLS_Get_thread_control_block_area_size();
>    assert(ti->module == 1);
> diff --git a/cpukit/score/cpu/arm/aarch32-psma-init-default.c
> b/cpukit/score/cpu/arm/aarch32-psma-init-default.c
> index 615e7a528a..8ef8b5233a 100644
> --- a/cpukit/score/cpu/arm/aarch32-psma-init-default.c
> +++ b/cpukit/score/cpu/arm/aarch32-psma-init-default.c
> @@ -42,7 +42,7 @@
>  #if __ARM_ARCH >= 8 && __ARM_ARCH_PROFILE == 'R'
> -void _AArch32_PMSA_Initialize_default( void )
> +void _AArch32_PMSA_Initialize_default(void)
>    _AArch32_PMSA_Initialize(
>      AARCH32_PMSA_MEM_ATTR(
> diff --git a/cpukit/score/cpu/arm/aarch32-psma-init.c
> b/cpukit/score/cpu/arm/aarch32-psma-init.c
> index 93a3673a98..b30cb5e308 100644
> --- a/cpukit/score/cpu/arm/aarch32-psma-init.c
> +++ b/cpukit/score/cpu/arm/aarch32-psma-init.c
> @@ -46,7 +46,7 @@
>  #include <rtems/score/cpu.h>
>  #define AARCH32_PMSA_REGION_MAX \
> -  ( ( AARCH32_MPUIR_REGION_MASK >> AARCH32_MPUIR_REGION_SHIFT ) + 1 )
> +  ((AARCH32_MPUIR_REGION_MASK >> AARCH32_MPUIR_REGION_SHIFT) + 1)
>  static void _AArch32_PMSA_Configure(
>    const AArch32_PMSA_Region *regions,
> @@ -57,36 +57,36 @@ static void _AArch32_PMSA_Configure(
>    size_t   ri;
>    uint32_t sctlr;
> -  for ( ri = 0 ; ri < region_used; ++ri ) {
> +  for ( ri = 0; ri < region_used; ++ri ) {
>      uint32_t prbar;
>      uint32_t prlar;
>      uint32_t attr;
> -    prbar = regions[ ri ].base;
> -    prlar = regions[ ri ].limit;
> -    attr = regions[ ri ].attributes;
> +    prbar = regions[ri].base;
> +    prlar = regions[ri].limit;
> +    attr  = regions[ri].attributes;
> -    prbar |= ( attr >> 6 ) & 0x3fU;
> +    prbar |= (attr >> 6) & 0x3fU;
>      prlar |= attr & 0x3fU;
> -    _AArch32_Write_prselr( ri );
> +    _AArch32_Write_prselr(ri);
>      _ARM_Instruction_synchronization_barrier();
> -    _AArch32_Write_prbar( prbar );
> -    _AArch32_Write_prlar( prlar );
> +    _AArch32_Write_prbar(prbar);
> +    _AArch32_Write_prlar(prlar);
> -  for ( ri = region_used ; ri < region_max; ++ri ) {
> +  for ( ri = region_used; ri < region_max; ++ri ) {
> -    _AArch32_Write_prbar( 0 );
> -    _AArch32_Write_prlar( 0 );
> +    _AArch32_Write_prbar(0);
> +    _AArch32_Write_prlar(0);
>    _ARM_Data_synchronization_barrier();
> -  sctlr = _AArch32_Read_sctlr();
> +  sctlr  = _AArch32_Read_sctlr();
>    sctlr |= AARCH32_SCTLR_M | AARCH32_SCTLR_I | AARCH32_SCTLR_C;
> -  sctlr &= ~( AARCH32_SCTLR_A | AARCH32_SCTLR_BR );
> -  _AArch32_Write_sctlr( sctlr );
> +  sctlr &= ~(AARCH32_SCTLR_A | AARCH32_SCTLR_BR);
> +  _AArch32_Write_sctlr(sctlr);
> @@ -109,16 +109,16 @@ size_t _AArch32_PMSA_Map_sections_to_regions(
>      uint32_t attr;
>      uint32_t limit;
> -    base = sections[ si ].begin;
> -    end = sections[ si ].end;
> -    attr = sections[ si ].attributes;
> +    base = sections[si].begin;
> +    end  = sections[si].end;
> +    attr = sections[si].attributes;
>      if ( base == end ) {
>        continue;
> -    base = RTEMS_ALIGN_DOWN( base, AARCH32_PMSA_MIN_REGION_ALIGN );
> -    end = RTEMS_ALIGN_UP( end, AARCH32_PMSA_MIN_REGION_ALIGN );
> +    base  = RTEMS_ALIGN_DOWN(base, AARCH32_PMSA_MIN_REGION_ALIGN);
> +    end   = RTEMS_ALIGN_UP(end, AARCH32_PMSA_MIN_REGION_ALIGN);
>      limit = end - AARCH32_PMSA_MIN_REGION_ALIGN;
> @@ -126,16 +126,16 @@ size_t _AArch32_PMSA_Map_sections_to_regions(
>        uint32_t region_limit;
>        uint32_t region_attr;
> -      region_base = regions[ ri ].base;
> -      region_limit = regions[ ri ].limit;
> -      region_attr = regions[ ri ].attributes;
> +      region_base  = regions[ri].base;
> +      region_limit = regions[ri].limit;
> +      region_attr  = regions[ri].attributes;
>        if ( attr == region_attr ) {
>          uint32_t region_end;
>          if ( end - region_base <= AARCH32_PMSA_MIN_REGION_ALIGN ) {
>            /* Extend the region */
> -          regions[ ri ].base = base;
> +          regions[ri].base = base;
>            break;
> @@ -143,7 +143,7 @@ size_t _AArch32_PMSA_Map_sections_to_regions(
>          if ( region_end - base <= AARCH32_PMSA_MIN_REGION_ALIGN ) {
> -          regions[ ri ].limit = limit;
> +          regions[ri].limit = limit;
>            break;
> @@ -161,14 +161,14 @@ size_t _AArch32_PMSA_Map_sections_to_regions(
>          for ( i = region_used; i > ri; --i ) {
> -          regions[ i ] = regions[ i - 1 ];
> +          regions[i] = regions[i - 1];
>          /* New first region */
>          ++region_used;
> -        regions[ ri ].attributes = attr;
> +        regions[ri].attributes = attr;
>          break;
> @@ -180,9 +180,9 @@ size_t _AArch32_PMSA_Map_sections_to_regions(
>        /* New last region */
>        ++region_used;
> @@ -196,15 +196,15 @@ void _AArch32_PMSA_Initialize(
>    size_t                      section_count
> -  AArch32_PMSA_Region regions[ AARCH32_PMSA_REGION_MAX ];
> -  size_t region_max;
> -  size_t region_used;
> +  AArch32_PMSA_Region regions[AARCH32_PMSA_REGION_MAX];
> +  size_t              region_max;
> +  size_t              region_used;
> -  _AArch32_Write_mair0( memory_attributes_0 );
> -  _AArch32_Write_mair1( memory_attributes_1 );
> +  _AArch32_Write_mair0(memory_attributes_0);
> +  _AArch32_Write_mair1(memory_attributes_1);
> -  region_max = ( _AArch32_Read_mpuir() & AARCH32_MPUIR_REGION_MASK ) >>
> -    AARCH32_MPUIR_REGION_SHIFT;
> +  region_max = (_AArch32_Read_mpuir() & AARCH32_MPUIR_REGION_MASK) >>
> +               AARCH32_MPUIR_REGION_SHIFT;
>    region_used = _AArch32_PMSA_Map_sections_to_regions(
>      sections,
> @@ -214,7 +214,7 @@ void _AArch32_PMSA_Initialize(
>    if ( region_used > 0 ) {
> -    _AArch32_PMSA_Configure( regions, region_used, region_max );
> +    _AArch32_PMSA_Configure(regions, region_used, region_max);
> diff --git a/cpukit/score/cpu/arm/arm-exception-default.c
> b/cpukit/score/cpu/arm/arm-exception-default.c
> index 02df769287..190c2bf68d 100644
> --- a/cpukit/score/cpu/arm/arm-exception-default.c
> +++ b/cpukit/score/cpu/arm/arm-exception-default.c
> @@ -38,10 +38,10 @@
>  #include "config.h"
>  #endif
> -#include <rtems/score/cpu.h>
>  #include <rtems/fatal.h>
> +#include <rtems/score/cpu.h>
> -void _ARM_Exception_default( CPU_Exception_frame *frame )
> +void _ARM_Exception_default(CPU_Exception_frame *frame)
> -  rtems_fatal( RTEMS_FATAL_SOURCE_EXCEPTION, (rtems_fatal_code) frame );
> +  rtems_fatal(RTEMS_FATAL_SOURCE_EXCEPTION, (rtems_fatal_code) frame);
> diff --git a/cpukit/score/cpu/arm/arm-exception-frame-print.c
> b/cpukit/score/cpu/arm/arm-exception-frame-print.c
> index b089648184..c625cf2479 100644
> --- a/cpukit/score/cpu/arm/arm-exception-frame-print.c
> +++ b/cpukit/score/cpu/arm/arm-exception-frame-print.c
> @@ -46,12 +46,12 @@
>  #endif
>  #include <rtems/bspIo.h>
> -static void _ARM_VFP_context_print( const ARM_VFP_context *vfp_context )
> +static void _ARM_VFP_context_print(const ARM_VFP_context *vfp_context)
>  #ifdef ARM_MULTILIB_VFP
>    if ( vfp_context != NULL ) {
>      const uint64_t *dx = &vfp_context->register_d0;
> -    int i;
> +    int             i;
>      printk(
>        "FPEXC = 0x%08" PRIx32 "\nFPSCR = 0x%08" PRIx32 "\n",
> @@ -67,138 +67,119 @@ static void _ARM_VFP_context_print( const
>      int regcount = 0;
>  #endif
>      for ( i = 0; i < regcount; ++i ) {
> -      uint32_t low = (uint32_t) dx[i];
> +      uint32_t low  = (uint32_t) dx[i];
>        uint32_t high = (uint32_t) (dx[i] >> 32);
> -      printk( "D%02i = 0x%08" PRIx32 "%08" PRIx32 "\n", i, high, low );
> +      printk("D%02i = 0x%08" PRIx32 "%08" PRIx32 "\n", i, high, low);
>  #endif
> -static void _ARM_Cortex_M_fault_info_print( void )
> +static void _ARM_Cortex_M_fault_info_print(void)
>  #if defined(ARM_MULTILIB_ARCH_V7M)
>     * prints content of additional debugging registers
>     * available on Cortex-Mx where x > 0 cores.
> -  uint32_t cfsr = _ARMV7M_SCB->cfsr;
> -  uint8_t mmfsr = ARMV7M_SCB_CFSR_MMFSR_GET( cfsr );
> -  uint8_t bfsr = ( ARMV7M_SCB_CFSR_BFSR_GET( cfsr ) >> 8 );
> -  uint16_t ufsr = ( ARMV7M_SCB_CFSR_UFSR_GET( cfsr ) >> 16 );
> -  uint32_t hfsr = _ARMV7M_SCB->hfsr;
> +  uint32_t cfsr  = _ARMV7M_SCB->cfsr;
> +  uint8_t  mmfsr = ARMV7M_SCB_CFSR_MMFSR_GET(cfsr);
> +  uint8_t  bfsr  = (ARMV7M_SCB_CFSR_BFSR_GET(cfsr) >> 8);
> +  uint16_t ufsr  = (ARMV7M_SCB_CFSR_UFSR_GET(cfsr) >> 16);
> +  uint32_t hfsr  = _ARMV7M_SCB->hfsr;
>    if ( mmfsr > 0 ) {
> -    printk( "MMFSR= 0x%08" PRIx32 " (memory fault)\n", mmfsr );
> -    if ( ( mmfsr & 0x1 ) != 0 ) {
> -      printk( "  IACCVIOL   : 1  (instruction access violation)\n" );
> +    printk("MMFSR= 0x%08" PRIx32 " (memory fault)\n", mmfsr);
> +    if ( (mmfsr & 0x1) != 0 ) {
> +      printk("  IACCVIOL   : 1  (instruction access violation)\n");
> -    if ( ( mmfsr & 0x2 ) != 0 ) {
> -      printk( "  DACCVIOL   : 1  (data access violation)\n" );
> +    if ( (mmfsr & 0x2) != 0 ) {
> +      printk("  DACCVIOL   : 1  (data access violation)\n");
> -    if ( (mmfsr & 0x8 ) != 0 ) {
> -      printk(
> -        "  MUNSTKERR  : 1  (fault on unstacking on exception return)\n"
> +    if ( (mmfsr & 0x8) != 0 ) {
> +      printk("  MUNSTKERR  : 1  (fault on unstacking on exception
> return)\n");
> -    if ( ( mmfsr & 0x10 ) != 0 ) {
> -      printk( "  MSTKERR    : 1  (fault on stacking on exception
> entry)\n" );
> +    if ( (mmfsr & 0x10) != 0 ) {
> +      printk("  MSTKERR    : 1  (fault on stacking on exception
> entry)\n");
> -    if ( (mmfsr & 0x20 ) != 0 ) {
> -      printk( "  MLSPERR    : 1  (fault during lazy FP stack
> preservation)\n" );
> +    if ( (mmfsr & 0x20) != 0 ) {
> +      printk("  MLSPERR    : 1  (fault during lazy FP stack
> preservation)\n");
> -    if ( (mmfsr & 0x80 ) != 0 ) {
> +    if ( (mmfsr & 0x80) != 0 ) {
>        printk(
>          "  MMFARVALID : 1 -> 0x%08" PRIx32 " (error address)\n",
> -       _ARMV7M_SCB->mmfar
> +        _ARMV7M_SCB->mmfar
> -    else {
> -      printk( "  MMFARVALID : 0  (undetermined error address)\n" );
> +    } else {
> +      printk("  MMFARVALID : 0  (undetermined error address)\n");
>    if ( bfsr > 0 ) {
> -    printk( "BFSR = 0x%08" PRIx32 " (bus fault)\n", bfsr );
> -    if ( ( bfsr & 0x1 ) != 0 ) {
> -      printk( "  IBUSERR    : 1  (instruction fetch error)\n" );
> +    printk("BFSR = 0x%08" PRIx32 " (bus fault)\n", bfsr);
> +    if ( (bfsr & 0x1) != 0 ) {
> +      printk("  IBUSERR    : 1  (instruction fetch error)\n");
> -    if ( (bfsr & 0x2 ) != 0 ) {
> -      printk(
> -        "  PRECISERR  : 1  (data bus error with known exact location)\n"
> +    if ( (bfsr & 0x2) != 0 ) {
> +      printk("  PRECISERR  : 1  (data bus error with known exact
> location)\n");
> -    if ( ( bfsr & 0x4) != 0 ) {
> -      printk(
> -        "  IMPRECISERR: 1  (data bus error without known exact
> location)\n"
> +    if ( (bfsr & 0x4) != 0 ) {
> +      printk("  IMPRECISERR: 1  (data bus error without known exact
> location)\n"
> -    if ( (bfsr & 0x8 ) != 0 ) {
> -      printk(
> -        "  UNSTKERR   : 1  (fault on unstacking on exception return)\n"
> +    if ( (bfsr & 0x8) != 0 ) {
> +      printk("  UNSTKERR   : 1  (fault on unstacking on exception
> return)\n");
> -    if ( ( bfsr & 0x10 ) != 0 ) {
> -      printk( "  STKERR     : 1  (fault on stacking on exception
> entry)\n" );
> +    if ( (bfsr & 0x10) != 0 ) {
> +      printk("  STKERR     : 1  (fault on stacking on exception
> entry)\n");
> -    if ( ( bfsr & 0x20 ) != 0 ) {
> -      printk( "  LSPERR     : 1  (fault during lazy FP stack
> preservation)\n" );
> +    if ( (bfsr & 0x20) != 0 ) {
> +      printk("  LSPERR     : 1  (fault during lazy FP stack
> preservation)\n");
> -    if ( (bfsr & 0x80 ) != 0 ) {
> +    if ( (bfsr & 0x80) != 0 ) {
>        printk(
>          "  BFARVALID  : 1 -> 0x%08" PRIx32 "  (error address)\n",
> -       _ARMV7M_SCB->bfar
> +        _ARMV7M_SCB->bfar
> -    else {
> -      printk( "  BFARVALID  : 0  (undetermined error address)\n" );
> +    } else {
> +      printk("  BFARVALID  : 0  (undetermined error address)\n");
>    if ( ufsr > 0 ) {
> -    printk( "UFSR = 0x%08" PRIx32 " (usage fault)\n", ufsr);
> -    if ( (ufsr & 0x1 ) != 0 ) {
> -      printk( "  UNDEFINSTR : 1  (undefined instruction issued)\n");
> +    printk("UFSR = 0x%08" PRIx32 " (usage fault)\n", ufsr);
> +    if ( (ufsr & 0x1) != 0 ) {
> +      printk("  UNDEFINSTR : 1  (undefined instruction issued)\n");
> -    if ( (ufsr & 0x2 ) != 0 ) {
> -      printk(
> -        "  INVSTATE   : 1"
> -        "  (invalid instruction state"
> -        " (Thumb not set in EPSR or invalid IT state in EPSR))\n"
> +    if ( (ufsr & 0x2) != 0 ) {
> +      printk("  INVSTATE   : 1"
> +             "  (invalid instruction state"
> +             " (Thumb not set in EPSR or invalid IT state in EPSR))\n");
> -    if ( (ufsr & 0x4 ) != 0 ) {
> -      printk( "  INVPC      : 1  (integrity check failure on
> EXC_RETURN)\n" );
> +    if ( (ufsr & 0x4) != 0 ) {
> +      printk("  INVPC      : 1  (integrity check failure on
> EXC_RETURN)\n");
> -    if ( (ufsr & 0x8 ) != 0 ) {
> -      printk(
> -        "  NOCP       : 1"
> -        "  (coprocessor instruction issued"
> -        " but coprocessor disabled or non existent)\n"
> +    if ( (ufsr & 0x8) != 0 ) {
> +      printk("  NOCP       : 1"
> +             "  (coprocessor instruction issued"
> +             " but coprocessor disabled or non existent)\n");
> -    if ( ( ufsr & 0x100) != 0 ) {
> -      printk( "  UNALIGNED  : 1  (unaligned access operation occurred)\n"
> +    if ( (ufsr & 0x100) != 0 ) {
> +      printk("  UNALIGNED  : 1  (unaligned access operation occurred)\n");
> -    if ( ( ufsr & 0x200) != 0 ) {
> -      printk( "  DIVBYZERO  : 1  (division by zero)" );
> +    if ( (ufsr & 0x200) != 0 ) {
> +      printk("  DIVBYZERO  : 1  (division by zero)");
> -  if ( (hfsr & (
> -    ARMV7M_SCB_HFSR_VECTTBL_MASK
> -    | ARMV7M_SCB_HFSR_DEBUGEVT_MASK
> -    | ARMV7M_SCB_HFSR_FORCED_MASK
> -    ) ) != 0 ) {
> -    printk( "HFSR = 0x%08" PRIx32 " (hard fault)\n", hfsr );
> -    if ( (hfsr & ARMV7M_SCB_HFSR_VECTTBL_MASK ) != 0 ) {
> -      printk(
> -        "  VECTTBL    : 1  (error in address located in vector table)\n"
> -    if ( (hfsr & ARMV7M_SCB_HFSR_FORCED_MASK ) != 0 ) {
> -      printk(
> -        "  FORCED     : 1  (configurable fault escalated to hard fault)\n"
> +  if ( (hfsr & (ARMV7M_SCB_HFSR_VECTTBL_MASK |
> ARMV7M_SCB_HFSR_DEBUGEVT_MASK |
> +                ARMV7M_SCB_HFSR_FORCED_MASK)) != 0 ) {
> +    printk("HFSR = 0x%08" PRIx32 " (hard fault)\n", hfsr);
> +    if ( (hfsr & ARMV7M_SCB_HFSR_VECTTBL_MASK) != 0 ) {
> +      printk("  VECTTBL    : 1  (error in address located in vector
> table)\n");
> +    if ( (hfsr & ARMV7M_SCB_HFSR_FORCED_MASK) != 0 ) {
> +      printk("  FORCED     : 1  (configurable fault escalated to hard
> fault)\n"
> -    if ( (hfsr & ARMV7M_SCB_HFSR_DEBUGEVT_MASK ) != 0 ) {
> +    if ( (hfsr & ARMV7M_SCB_HFSR_DEBUGEVT_MASK) != 0 ) {
>        printk(
>          "  DEBUGEVT   : 1  (debug event occurred with debug system
> disabled)\n"
> @@ -206,7 +187,7 @@ static void _ARM_Cortex_M_fault_info_print( void )
>  #endif
> -void _CPU_Exception_frame_print( const CPU_Exception_frame *frame )
> +void _CPU_Exception_frame_print(const CPU_Exception_frame *frame)
>    printk(
>      "\n"
> @@ -248,6 +229,6 @@ void _CPU_Exception_frame_print( const
>      (intptr_t) frame->vector
> -  _ARM_VFP_context_print( frame->vfp_context );
> +  _ARM_VFP_context_print(frame->vfp_context);
>    _ARM_Cortex_M_fault_info_print();
> diff --git a/cpukit/score/cpu/arm/armv4-sync-synchronize.c
> b/cpukit/score/cpu/arm/armv4-sync-synchronize.c
> index 2f454306d8..82b0a69566 100644
> --- a/cpukit/score/cpu/arm/armv4-sync-synchronize.c
> +++ b/cpukit/score/cpu/arm/armv4-sync-synchronize.c
> @@ -35,7 +35,7 @@
> -void __sync_synchronize( void )
> +void __sync_synchronize(void)
>    _ARM_Data_memory_barrier();
> diff --git a/cpukit/score/cpu/arm/armv7-thread-idle.c
> b/cpukit/score/cpu/arm/armv7-thread-idle.c
> index 720cb2be83..c4e8e66210 100644
> --- a/cpukit/score/cpu/arm/armv7-thread-idle.c
> +++ b/cpukit/score/cpu/arm/armv7-thread-idle.c
> @@ -40,8 +40,7 @@
> -void *_CPU_Thread_Idle_body( uintptr_t ignored )
> +void *_CPU_Thread_Idle_body(uintptr_t ignored)
>    while ( true ) {
>  #ifdef ARM_MULTILIB_HAS_WFI
> @@ -49,4 +48,3 @@ void *_CPU_Thread_Idle_body( uintptr_t ignored )
>  #endif /* ARM_MULTILIB_HAS_WFI */
> diff --git a/cpukit/score/cpu/arm/armv7m-context-initialize.c
> b/cpukit/score/cpu/arm/armv7m-context-initialize.c
> index d67bcf93b5..b0cfbccef2 100644
> --- a/cpukit/score/cpu/arm/armv7m-context-initialize.c
> +++ b/cpukit/score/cpu/arm/armv7m-context-initialize.c
> @@ -48,12 +48,12 @@
>  void _CPU_Context_Initialize(
>    Context_Control *context,
> -  void *stack_area_begin,
> -  size_t stack_area_size,
> -  uint32_t new_level,
> -  void (*entry_point)( void ),
> -  bool is_fp,
> -  void *tls_area
> +  void            *stack_area_begin,
> +  size_t           stack_area_size,
> +  uint32_t         new_level,
> +  void             (*entry_point)(void),
> +  bool             is_fp,
> +  void            *tls_area
>    char *stack_area_end = (char *) stack_area_begin + stack_area_size;
> @@ -64,7 +64,7 @@ void _CPU_Context_Initialize(
>    context->register_sp = stack_area_end;
>    if ( tls_area != NULL ) {
> -    context->thread_id = (uint32_t) _TLS_Initialize_area( tls_area );
> +    context->thread_id = (uint32_t) _TLS_Initialize_area(tls_area);
> diff --git a/cpukit/score/cpu/arm/armv7m-context-restore.c
> b/cpukit/score/cpu/arm/armv7m-context-restore.c
> index b888abe29f..625a33c626 100644
> --- a/cpukit/score/cpu/arm/armv7m-context-restore.c
> +++ b/cpukit/score/cpu/arm/armv7m-context-restore.c
> @@ -43,9 +43,7 @@
>  #ifdef ARM_MULTILIB_ARCH_V7M
> -void __attribute__((naked)) _CPU_Context_restore(
> -  Context_Control *heir
> +void __attribute__((naked)) _CPU_Context_restore(Context_Control *heir)
>    __asm__ volatile (
>      "movw r2, #:lower16:_Per_CPU_Information\n"
> diff --git a/cpukit/score/cpu/arm/armv7m-exception-default.c
> b/cpukit/score/cpu/arm/armv7m-exception-default.c
> index 35dde50dc3..6d3eb49ea0 100644
> --- a/cpukit/score/cpu/arm/armv7m-exception-default.c
> +++ b/cpukit/score/cpu/arm/armv7m-exception-default.c
> @@ -42,21 +42,21 @@
> -void __attribute__((naked)) _ARMV7M_Exception_default( void )
> +void __attribute__((naked)) _ARMV7M_Exception_default(void)
> -    /* On exception entry, ARMv7M saves context state onto a stack
> pointed to
> -     * by either MSP or PSP. The value stored in LR indicates whether we
> were
> -     * in Thread or Handler mode, whether we were using the FPU (if any),
> -     * and which stack pointer we were using.
> -     * In particular, bit 2 of LR will be 0 if we were using MSP.
> -     * For a more detailed explanation, see the Exception Entry Behavior
> -     * section of the ARMv7M Architecture Reference Manual.
> +  /* On exception entry, ARMv7M saves context state onto a stack pointed
> to
> +   * by either MSP or PSP. The value stored in LR indicates whether we
> were
> +   * in Thread or Handler mode, whether we were using the FPU (if any),
> +   * and which stack pointer we were using.
> +   * In particular, bit 2 of LR will be 0 if we were using MSP.
> +   * For a more detailed explanation, see the Exception Entry Behavior
> +   * section of the ARMv7M Architecture Reference Manual.
> -    /* As we're in Handler mode here, we'll always operate on MSP.
> -     * However, we need to store the right SP in our CPU_Exception_frame.
> +  /* As we're in Handler mode here, we'll always operate on MSP.
> +   * However, we need to store the right SP in our CPU_Exception_frame.
>    __asm__ volatile (
>      "sub sp, %[cpufsz]\n"   /* Allocate space for a CPU_Exception_frame.
>      "stm sp, {r0-r12}\n"
> diff --git a/cpukit/score/cpu/arm/armv7m-exception-handler-get.c
> b/cpukit/score/cpu/arm/armv7m-exception-handler-get.c
> index 41effd1e18..c26d783723 100644
> --- a/cpukit/score/cpu/arm/armv7m-exception-handler-get.c
> +++ b/cpukit/score/cpu/arm/armv7m-exception-handler-get.c
> @@ -43,9 +43,9 @@
> -ARMV7M_Exception_handler _ARMV7M_Get_exception_handler( int index )
> +ARMV7M_Exception_handler _ARMV7M_Get_exception_handler(int index)
> -  return _ARMV7M_SCB->vtor [index];
> +  return _ARMV7M_SCB->vtor[index];
>  #endif /* ARM_MULTILIB_ARCH_V7M */
> diff --git a/cpukit/score/cpu/arm/armv7m-exception-handler-set.c
> b/cpukit/score/cpu/arm/armv7m-exception-handler-set.c
> index 94c9dc5360..9dd81a5df7 100644
> --- a/cpukit/score/cpu/arm/armv7m-exception-handler-set.c
> +++ b/cpukit/score/cpu/arm/armv7m-exception-handler-set.c
> @@ -38,25 +38,22 @@
>  #include "config.h"
>  #endif
> -#include <rtems/score/armv7m.h>
>  #include <rtems/rtems/cache.h>
> +#include <rtems/score/armv7m.h>
> -void _ARMV7M_Set_exception_handler(
> -  int index,
> -  ARMV7M_Exception_handler handler
> +void _ARMV7M_Set_exception_handler(int index, ARMV7M_Exception_handler
> handler)
> -  if ( _ARMV7M_SCB->vtor [index] != handler ) {
> -    _ARMV7M_SCB->vtor [index] = handler;
> +  if ( _ARMV7M_SCB->vtor[index] != handler ) {
> +    _ARMV7M_SCB->vtor[index] = handler;
>      rtems_cache_flush_multiple_data_lines(
> -      &_ARMV7M_SCB->vtor [index],
> -      sizeof(_ARMV7M_SCB->vtor [index])
> +      &_ARMV7M_SCB->vtor[index],
> +      sizeof(_ARMV7M_SCB->vtor[index])
>      rtems_cache_invalidate_multiple_instruction_lines(
> diff --git a/cpukit/score/cpu/arm/armv7m-exception-priority-get.c
> b/cpukit/score/cpu/arm/armv7m-exception-priority-get.c
> index bb0892a32f..fdcc2f0f68 100644
> --- a/cpukit/score/cpu/arm/armv7m-exception-priority-get.c
> +++ b/cpukit/score/cpu/arm/armv7m-exception-priority-get.c
> @@ -42,12 +42,12 @@
> -int _ARMV7M_Get_exception_priority( int vector )
> +int _ARMV7M_Get_exception_priority(int vector)
> -  if ( _ARMV7M_Is_vector_an_irq( vector ) ) {
> -    return _ARMV7M_NVIC_Get_priority( ARMV7M_IRQ_OF_VECTOR( vector ) );
> +  if ( _ARMV7M_Is_vector_an_irq(vector) ) {
> +    return _ARMV7M_NVIC_Get_priority(ARMV7M_IRQ_OF_VECTOR(vector));
>    } else if ( vector >= ARMV7M_VECTOR_MEM_MANAGE ) {
> -    return _ARMV7M_SCB->shpr [vector - 4];
> +    return _ARMV7M_SCB->shpr[vector - 4];
>    } else {
>      return vector - 4;
> diff --git a/cpukit/score/cpu/arm/armv7m-exception-priority-handler.c
> b/cpukit/score/cpu/arm/armv7m-exception-priority-handler.c
> index b94366e07c..7f868fed79 100644
> --- a/cpukit/score/cpu/arm/armv7m-exception-priority-handler.c
> +++ b/cpukit/score/cpu/arm/armv7m-exception-priority-handler.c
> @@ -43,13 +43,13 @@
>  void _ARMV7M_Set_exception_priority_and_handler(
> -  int index,
> -  int priority,
> +  int                      index,
> +  int                      priority,
> -  _ARMV7M_Set_exception_priority( index, priority );
> -  _ARMV7M_Set_exception_handler( index, handler );
> +  _ARMV7M_Set_exception_priority(index, priority);
> +  _ARMV7M_Set_exception_handler(index, handler);
> diff --git a/cpukit/score/cpu/arm/armv7m-exception-priority-set.c
> b/cpukit/score/cpu/arm/armv7m-exception-priority-set.c
> index 05136a47db..0cd7a4f28a 100644
> --- a/cpukit/score/cpu/arm/armv7m-exception-priority-set.c
> +++ b/cpukit/score/cpu/arm/armv7m-exception-priority-set.c
> @@ -42,12 +42,12 @@
> -void _ARMV7M_Set_exception_priority( int vector, int priority )
> +void _ARMV7M_Set_exception_priority(int vector, int priority)
> -    _ARMV7M_NVIC_Set_priority( ARMV7M_IRQ_OF_VECTOR( vector ), priority );
> +    _ARMV7M_NVIC_Set_priority(ARMV7M_IRQ_OF_VECTOR(vector), priority);
> -    _ARMV7M_SCB->shpr [vector - 4] = (uint8_t) priority;
> +    _ARMV7M_SCB->shpr[vector - 4] = (uint8_t) priority;
> diff --git a/cpukit/score/cpu/arm/armv7m-initialize.c
> b/cpukit/score/cpu/arm/armv7m-initialize.c
> index 0f47b49af7..1c9a66523b 100644
> --- a/cpukit/score/cpu/arm/armv7m-initialize.c
> +++ b/cpukit/score/cpu/arm/armv7m-initialize.c
> @@ -42,7 +42,7 @@
> -void _CPU_Initialize( void )
> +void _CPU_Initialize(void)
>     * The exception handler used to carry out the thead dispatching must
> have
> diff --git a/cpukit/score/cpu/arm/armv7m-isr-dispatch.c
> b/cpukit/score/cpu/arm/armv7m-isr-dispatch.c
> index ea168969ba..dfc125d545 100644
> --- a/cpukit/score/cpu/arm/armv7m-isr-dispatch.c
> +++ b/cpukit/score/cpu/arm/armv7m-isr-dispatch.c
> @@ -43,7 +43,7 @@
> -static void __attribute__((naked)) _ARMV7M_Thread_dispatch( void )
> +static void __attribute__((naked)) _ARMV7M_Thread_dispatch(void)
>    __asm__ volatile (
>      "bl _Thread_Dispatch\n"
> @@ -53,7 +53,7 @@ static void __attribute__((naked))
> -static void _ARMV7M_Trigger_lazy_floating_point_context_save( void )
> +static void _ARMV7M_Trigger_lazy_floating_point_context_save(void)
>    __asm__ volatile (
> @@ -62,7 +62,7 @@ static void
>  #endif
> -void _ARMV7M_Pendable_service_call( void )
> +void _ARMV7M_Pendable_service_call(void)
>    Per_CPU_Control *cpu_self = _Per_CPU_Get();
> @@ -73,7 +73,7 @@ void _ARMV7M_Pendable_service_call( void )
>     * this interrupt service may be delayed until interrupts are enable
> again.
>    if (
> -    ( cpu_self->isr_nest_level | cpu_self->thread_dispatch_disable_level
> ) == 0
> +    (cpu_self->isr_nest_level | cpu_self->thread_dispatch_disable_level)
> == 0
Does this fit on a single line?
Ignoring the fact it is using bitwise operations on two integer counters.
Perhaps
it should be a +?
>      ARMV7M_Exception_frame *ef;
> @@ -84,29 +84,29 @@ void _ARMV7M_Pendable_service_call( void )
>      ef = (ARMV7M_Exception_frame *) _ARMV7M_Get_PSP();
>      --ef;
> -    _ARMV7M_Set_PSP( (uint32_t) ef );
> +    _ARMV7M_Set_PSP((uint32_t) ef);
>       * According to "ARMv7-M Architecture Reference Manual" section B1.5.6
>       * "Exception entry behavior" the return address is half-word aligned.
> -    ef->register_pc = (void *)
> -      ((uintptr_t) _ARMV7M_Thread_dispatch & ~((uintptr_t) 1));
> +    ef->register_pc = (void *) ((uintptr_t) _ARMV7M_Thread_dispatch &
> +                                ~((uintptr_t) 1));
>      ef->register_xpsr = 0x01000000U;
> -void _ARMV7M_Supervisor_call( void )
> +void _ARMV7M_Supervisor_call(void)
> -  Per_CPU_Control *cpu_self = _Per_CPU_Get();
> +  Per_CPU_Control        *cpu_self = _Per_CPU_Get();
>    _ARMV7M_Trigger_lazy_floating_point_context_save();
>    ++ef;
>    cpu_self->isr_nest_level = 0;
> diff --git a/cpukit/score/cpu/arm/armv7m-isr-enter-leave.c
> b/cpukit/score/cpu/arm/armv7m-isr-enter-leave.c
> index 1490f6e219..04f7ab1749 100644
> --- a/cpukit/score/cpu/arm/armv7m-isr-enter-leave.c
> +++ b/cpukit/score/cpu/arm/armv7m-isr-enter-leave.c
> @@ -44,7 +44,7 @@
> -void _ARMV7M_Interrupt_service_enter( void )
> +void _ARMV7M_Interrupt_service_enter(void)
> @@ -52,7 +52,7 @@ void _ARMV7M_Interrupt_service_enter( void )
>    ++cpu_self->isr_nest_level;
> -void _ARMV7M_Interrupt_service_leave( void )
> +void _ARMV7M_Interrupt_service_leave(void)
> diff --git a/cpukit/score/cpu/arm/armv7m-isr-level-get.c
> b/cpukit/score/cpu/arm/armv7m-isr-level-get.c
> index cc2b674e13..48b11d923a 100644
> --- a/cpukit/score/cpu/arm/armv7m-isr-level-get.c
> +++ b/cpukit/score/cpu/arm/armv7m-isr-level-get.c
> @@ -41,7 +41,7 @@
> -uint32_t _CPU_ISR_Get_level( void )
> +uint32_t _CPU_ISR_Get_level(void)
>    return _ARMV7M_Get_basepri() != 0;
> diff --git a/cpukit/score/cpu/arm/armv7m-isr-level-set.c
> b/cpukit/score/cpu/arm/armv7m-isr-level-set.c
> index 72c9684025..982c5df687 100644
> --- a/cpukit/score/cpu/arm/armv7m-isr-level-set.c
> +++ b/cpukit/score/cpu/arm/armv7m-isr-level-set.c
> @@ -41,9 +41,9 @@
> -void _CPU_ISR_Set_level( uint32_t level )
> +void _CPU_ISR_Set_level(uint32_t level)
> -  _ARMV7M_Set_basepri( 0 );
> +  _ARMV7M_Set_basepri(0);
> diff --git a/cpukit/score/cpu/arm/armv7m-isr-vector-install.c
> b/cpukit/score/cpu/arm/armv7m-isr-vector-install.c
> index c1e9eb70cb..a9e14ba1e6 100644
> --- a/cpukit/score/cpu/arm/armv7m-isr-vector-install.c
> +++ b/cpukit/score/cpu/arm/armv7m-isr-vector-install.c
> @@ -51,12 +51,12 @@ void _CPU_ISR_install_vector(
>    uint32_t level;
> -  _ISR_Local_disable( level );
> +  _ISR_Local_disable(level);
>    if ( old_handler != NULL ) {
> -    *old_handler = _ARMV7M_Get_exception_handler( (int) vector );
> +    *old_handler = _ARMV7M_Get_exception_handler((int) vector);
> -  _ARMV7M_Set_exception_handler( (int) vector, new_handler );
> -  _ISR_Local_enable( level );
> +  _ARMV7M_Set_exception_handler((int) vector, new_handler);
> +  _ISR_Local_enable(level);
> diff --git a/cpukit/score/cpu/arm/armv7m-multitasking-start-stop.c
> b/cpukit/score/cpu/arm/armv7m-multitasking-start-stop.c
> index a9b59dec84..4c6d969f4f 100644
> --- a/cpukit/score/cpu/arm/armv7m-multitasking-start-stop.c
> +++ b/cpukit/score/cpu/arm/armv7m-multitasking-start-stop.c
> @@ -42,9 +42,7 @@
> -void __attribute__((naked)) _ARMV7M_Start_multitasking(
> +void __attribute__((naked)) _ARMV7M_Start_multitasking(Context_Control
> *heir)
>    __asm__ volatile (
>      /* Restore heir context */
> diff --git a/cpukit/score/cpu/arm/cpu.c b/cpukit/score/cpu/arm/cpu.c
> index 65f1ad2014..c7d7527dce 100644
> --- a/cpukit/score/cpu/arm/cpu.c
> +++ b/cpukit/score/cpu/arm/cpu.c
> @@ -61,8 +61,7 @@
>  #endif
>  RTEMS_STATIC_ASSERT(
> -  offsetof( Context_Control, thread_id )
> -    == ARM_CONTEXT_CONTROL_THREAD_ID_OFFSET,
> +  offsetof(Context_Control, thread_id) ==
> @@ -83,23 +82,23 @@ RTEMS_STATIC_ASSERT(
>  #endif
> -  sizeof( CPU_Exception_frame ) == ARM_EXCEPTION_FRAME_SIZE,
> +  sizeof(CPU_Exception_frame) == ARM_EXCEPTION_FRAME_SIZE,
> -  sizeof( CPU_Exception_frame ) % CPU_STACK_ALIGNMENT == 0,
> +  sizeof(CPU_Exception_frame) % CPU_STACK_ALIGNMENT == 0,
>    CPU_Exception_frame_alignment
> -  offsetof( CPU_Exception_frame, register_sp )
> -    == ARM_EXCEPTION_FRAME_REGISTER_SP_OFFSET,
> +  offsetof(CPU_Exception_frame, register_sp) ==
> +    ARM_EXCEPTION_FRAME_REGISTER_SP_OFFSET,
> -  sizeof( ARM_VFP_context ) == ARM_VFP_CONTEXT_SIZE,
> +  sizeof(ARM_VFP_context) == ARM_VFP_CONTEXT_SIZE,
> @@ -107,12 +106,12 @@ RTEMS_STATIC_ASSERT(
>    Context_Control *the_context,
> -  bool is_fp,
> -  void *tls_area
> +  bool             is_fp,
> +  void            *tls_area
>    (void) new_level;
> @@ -120,14 +119,14 @@ void _CPU_Context_Initialize(
>    the_context->register_sp = (uint32_t) stack_area_begin +
> stack_area_size;
>    the_context->register_lr = (uint32_t) entry_point;
>    the_context->isr_dispatch_disable = 0;
> -  the_context->thread_id = (uint32_t) tls_area;
> +  the_context->thread_id            = (uint32_t) tls_area;
> -    the_context->thread_id = (uint32_t) _TLS_Initialize_area( tls_area );
> +    the_context->thread_id = (uint32_t) _TLS_Initialize_area(tls_area);
>    uint32_t arm_switch_reg;
> @@ -144,7 +143,7 @@ void _CPU_ISR_Set_level( uint32_t level )
>    ARM_SWITCH_REGISTERS;
>    uint32_t level;
> @@ -157,7 +156,7 @@ uint32_t _CPU_ISR_Get_level( void )
>      : [level] "=&r" (level) ARM_SWITCH_ADDITIONAL_OUTPUT
> -  return ( level & ARM_PSR_I ) != 0;
> +  return (level & ARM_PSR_I) != 0;
> @@ -169,34 +168,34 @@ void _CPU_ISR_install_vector(
>  #pragma GCC diagnostic push
>  #pragma GCC diagnostic ignored "-Warray-bounds"
>    /* Redirection table starts at the end of the vector table */
> -  CPU_ISR_handler volatile  *table = (CPU_ISR_handler *) (MAX_EXCEPTIONS
> * 4);
> +  CPU_ISR_handler volatile *table = (CPU_ISR_handler *) (MAX_EXCEPTIONS *
> 4);
> -  CPU_ISR_handler current_handler = table [vector];
> +  CPU_ISR_handler current_handler = table[vector];
>    /* The current handler is now the old one */
> -  if (old_handler != NULL) {
> +  if ( old_handler != NULL ) {
>      *old_handler = current_handler;
>    /* Write only if necessary to avoid writes to a maybe read-only memory
> -  if (current_handler != new_handler) {
> -    table [vector] = new_handler;
> +  if ( current_handler != new_handler ) {
> +    table[vector] = new_handler;
>  #pragma GCC diagnostic pop
>    /* Do nothing */
>  #endif /* ARM_MULTILIB_ARCH_V4 */
> -void _CPU_Fatal_halt( uint32_t source, CPU_Uint32ptr error )
> +void _CPU_Fatal_halt(uint32_t source, CPU_Uint32ptr error)
>    ISR_Level level;
> -  _CPU_ISR_Disable( level );
> +  _CPU_ISR_Disable(level);
>    (void) level;
>    __asm__ volatile ("mov r0, %0\n"
> 2.34.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230725/660a63a7/attachment-0001.htm>
