[PATCH] build: Export BSP base and family via pkg-config
Wed Jul 26 04:54:22 UTC 2023
On 25.07.23 20:26, Joel Sherrill wrote:
> On Tue, Jul 25, 2023 at 12:19 PM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     On 25.07.23 19:15, Gedare Bloom wrote:
>      > On Tue, Jul 25, 2023 at 11:11 AM Sebastian Huber
>      >> On 25.07.23 18:01, Gedare Bloom wrote:
>      >>> On Tue, Jul 25, 2023 at 5:13 AM Sebastian Huber
>      >>>> This allows application and library build systems to derive option
>      >>>> values from the BSP base and family names.
>      >>>>    spec/build/bsps/pkgconfig.yml | 2 ++
>      >>>>    1 file changed, 2 insertions(+)
>      >>>> diff --git a/spec/build/bsps/pkgconfig.yml
>     b/spec/build/bsps/pkgconfig.yml
>      >>>> index e08c83fe27..afaffbbf0f 100644
>      >>>> --- a/spec/build/bsps/pkgconfig.yml
>      >>>> +++ b/spec/build/bsps/pkgconfig.yml
>      >>>> @@ -15,6 +15,8 @@ content: |
>      >>>>      ABI_FLAGS=${ABI_FLAGS}
>      >>>>      RTEMS_ARCH=${ARCH}
>      >>>>      RTEMS_BSP=${BSP_NAME}
>      >>>> +  RTEMS_BSP_BASE=${BSP_BASE}
>      >>>> +  RTEMS_BSP_FAMILY=${BSP_FAMILY}
>      >>> These expose a little bit of the internal working of the build
>     system.
>      >>> I think it's fine, since these two fields should not change
>     over time.
>      >>> But, it commits us to maintain this mapping and these variables.
>      >> We had the RTEMS_BSP also in the old build system, but it was
>     actually
>      >> what is now the RTEMS_BSP_BASE in this patch. With the
>     user-defined BSP
>      >> names we have for:
>      >> [arch/user_bsp_name]
>      >> INHERIT = system_bsp_name
>      >> This results in:
>      >> RTEMS_BSP = user_bsp_name
>      >> RTEMS_BSP_BASE = system_bsp_name
>      >> Maybe we should change this to:
>      >> RTEMS_BSP = system_bsp_name
>      >> RTEMS_BSP_NAME = user_bsp_name
>      > This would make more sense. I don't know what it might break to make
>      > this change now though, as external build tools may rely on the
>      > current definition of RTEMS_BSP?
>     Yes, this is a bit tricky since the BSP name is also encoded in the
>     *.pc
>     file name: ${arch}-rtems6-{user_bsp_name}.pc. This is an argument for
>     keeping RTEMS_BSP = user_bsp_name.
> I would agree with that since that's the name the user expects and will be
> part of any installed path, pkg config file, etc.
> That leaves RTEMS_BSP_NAME is not great. How about RTEMS_BSP_CANONICAL?
I would not reinvent a new name. In the documentation this canonical is
called base. So, I think the patch is fine as is.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
