[PATCH] build: Add optional RTEMS_VERSION_VC_KEY
Wed Jul 26 05:44:51 UTC 2023
On 26.07.23 06:58, Sebastian Huber wrote:
> On 26.07.23 00:08, Chris Johns wrote:
>> On 26/7/2023 4:27 am, Joel Sherrill wrote:
>>> On Tue, Jul 25, 2023 at 12:15 PM Sebastian Huber
>>> <sebastian.huber at embedded-brains.de
>>> <mailto:sebastian.huber at embedded-brains.de>>
>>> wrote:
>>>      On 25.07.23 19:09, Joel Sherrill wrote:
>>>      > On Tue, Jul 25, 2023 at 10:12 AM Sebastian Huber
>>>      > <sebastian.huber at embedded-brains.de
>>>      > <mailto:sebastian.huber at embedded-brains.de
>>> <mailto:sebastian.huber at embedded-brains.de>>> wrote:
>>>      >     Allow the user to set the version control key.
>>>      >       spec/build/cpukit/grp.yml             |  2 ++
>>>      >       spec/build/cpukit/optversionvckey.yml | 20 ++++++++++++++
>>>      >       wscript                               | 38
>>>      >       3 files changed, 44 insertions(+), 16 deletions(-)
>>>      >       create mode 100644 spec/build/cpukit/optversionvckey.yml
>>>      >     diff --git a/spec/build/cpukit/grp.yml
>>> b/spec/build/cpukit/grp.yml
>>>      >     index e07e975d7d..fbeab45b5c 100644
>>>      >     --- a/spec/build/cpukit/grp.yml
>>>      >     +++ b/spec/build/cpukit/grp.yml
>>>      >     @@ -18,6 +18,8 @@ links:
>>>      >         uid: cpuopts
>>>      >       - role: build-dependency
>>>      >         uid: cfghdr
>>>      >     +- role: build-dependency
>>>      >     +  uid: optversionvckey
>>>      >         uid: libdebugger
>>>      >     diff --git a/spec/build/cpukit/optversionvckey.yml
>>>      >     b/spec/build/cpukit/optversionvckey.yml
>>>      >     new file mode 100644
>>>      >     index 0000000000..7197381342
>>>      >     --- /dev/null
>>>      >     +++ b/spec/build/cpukit/optversionvckey.yml
>>>      >     @@ -0,0 +1,20 @@
>>>      >     +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
>>>      >     +actions:
>>>      >     +- get-string: null
>>>      >     +- env-assign: null
>>>      >     +build-type: option
>>>      >     +copyrights:
>>>      >     +- Copyright (C) 2022, 2023 embedded brains GmbH & Co. KG
>>>      >     +default:
>>>      >     +- enabled-by: true
>>>      >     +  value: ''
>>>      >     +description: |
>>>      >     +  If defined to a non-empty value, then the value will be
>>> used for
>>>      >     the version
>>>      >     +  control key returned by rtems_version() and
>>>      >     rtems_version_control_key(),
>>>      >     +  otherwise the value will be determined by the Git
>>> repository
>>>      >     containing the
>>>      >     +  waf top directory.
>>>      > And would this change for a release tarball?
>>>      Which RTEMS_VERSION_VC_KEY has a release tarball? What happens
>>> if you
>>>      unpack an release archive in an external Git repository?
>>> I don't know but think we should discuss it.
>>> Chris should speak up since the release scripts are his and this
>>> might be used by the distribution packaging he has made available.
>> I am not sure what the purpose of this change is. It would be good to
>> understand
>> what it is for. The RTEMS_VERSION_VC_KEY could mean a number of things
>> such as a
>> means to set the git hash in sources not in a git repo but that is guess.
> Yes, this is helpful if you have the RTEMS sources not in a Git
> repository or the Git repository has the wrong commit (git subtree for
> example).
> It could be also useful for the release archive. We could use this scheme:
> * If the value is "git", then get the value from git.
> * If the value is "", then we use no version key.
> * Otherwise we set the key to the value.
> For the release archive we would set the default value of the option
> from "git" to "".
I sent a patch with this approach:
https://lists.rtems.org/pipermail/devel/2023-July/075989.html
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
