[PATCH] build: Add optional RTEMS_VERSION_VC_KEY
Wed Jul 26 04:58:43 UTC 2023
On 26.07.23 00:08, Chris Johns wrote:
> On 26/7/2023 4:27 am, Joel Sherrill wrote:
>> On Tue, Jul 25, 2023 at 12:15 PM Sebastian Huber
>> <sebastian.huber at embedded-brains.de  <mailto:sebastian.huber at embedded-brains.de>>
>> wrote:
>>      On 25.07.23 19:09, Joel Sherrill wrote:
>>      > On Tue, Jul 25, 2023 at 10:12 AM Sebastian Huber
>>      <mailto:sebastian.huber at embedded-brains.de>>> wrote:
>>      >     Allow the user to set the version control key.
>>      >       spec/build/cpukit/grp.yml             |  2 ++
>>      >       spec/build/cpukit/optversionvckey.yml | 20 ++++++++++++++
>>      >       wscript                               | 38 ++++++++++++++++-----------
>>      >       3 files changed, 44 insertions(+), 16 deletions(-)
>>      >       create mode 100644 spec/build/cpukit/optversionvckey.yml
>>      >     diff --git a/spec/build/cpukit/grp.yml b/spec/build/cpukit/grp.yml
>>      >     index e07e975d7d..fbeab45b5c 100644
>>      >     --- a/spec/build/cpukit/grp.yml
>>      >     +++ b/spec/build/cpukit/grp.yml
>>      >     @@ -18,6 +18,8 @@ links:
>>      >         uid: cpuopts
>>      >       - role: build-dependency
>>      >         uid: cfghdr
>>      >     +- role: build-dependency
>>      >     +  uid: optversionvckey
>>      >         uid: libdebugger
>>      >     diff --git a/spec/build/cpukit/optversionvckey.yml
>>      >     b/spec/build/cpukit/optversionvckey.yml
>>      >     new file mode 100644
>>      >     index 0000000000..7197381342
>>      >     --- /dev/null
>>      >     +++ b/spec/build/cpukit/optversionvckey.yml
>>      >     @@ -0,0 +1,20 @@
>>      >     +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
>>      >     +actions:
>>      >     +- get-string: null
>>      >     +- env-assign: null
>>      >     +build-type: option
>>      >     +copyrights:
>>      >     +- Copyright (C) 2022, 2023 embedded brains GmbH & Co. KG
>>      >     +default:
>>      >     +- enabled-by: true
>>      >     +  value: ''
>>      >     +description: |
>>      >     +  If defined to a non-empty value, then the value will be used for
>>      >     the version
>>      >     +  control key returned by rtems_version() and
>>      >     rtems_version_control_key(),
>>      >     +  otherwise the value will be determined by the Git repository
>>      >     containing the
>>      >     +  waf top directory.
>>      > And would this change for a release tarball?
>>      Which RTEMS_VERSION_VC_KEY has a release tarball? What happens if you
>>      unpack an release archive in an external Git repository?
>> I don't know but think we should discuss it.
>> Chris should speak up since the release scripts are his and this
>> might be used by the distribution packaging he has made available.
> I am not sure what the purpose of this change is. It would be good to understand
> what it is for. The RTEMS_VERSION_VC_KEY could mean a number of things such as a
> means to set the git hash in sources not in a git repo but that is guess.
Yes, this is helpful if you have the RTEMS sources not in a Git
repository or the Git repository has the wrong commit (git subtree for
example).
It could be also useful for the release archive. We could use this scheme:
* If the value is "git", then get the value from git.
* If the value is "", then we use no version key.
* Otherwise we set the key to the value.
For the release archive we would set the default value of the option
from "git" to "".
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
