[PATCH 0/3] Revert CAN API
Thu Jul 27 18:48:52 UTC 2023
OK to revert. I didn't catch that it was 3 commits to revert cleanly.
On Thu, Jul 27, 2023 at 1:28 PM Gedare Bloom <gedare at rtems.org> wrote:
> The CAN API is not mature enough for a release. This patch set
> reverts it. See #4803.
> I expect to revisit this during the 7 development cycle.
> Gedare Bloom (3):
>   Revert "cpukit/dev/can: Resolve warnings in 64bit builds"
>   Revert "build: Fix copyright statement format"
>   Revert "cpukit/dev/can: Added CAN support"
>  cpukit/dev/can/can.c                     | 507 -----------------------
>  cpukit/include/dev/can/can-msg.h         | 105 -----
>  cpukit/include/dev/can/can.h             | 284 -------------
>  cpukit/include/dev/can/canqueueimpl.h    | 231 -----------
>  spec/build/cpukit/librtemscpu.yml        |   5 -
>  spec/build/testsuites/libtests/can01.yml |  20 -
>  spec/build/testsuites/libtests/grp.yml   |   2 -
>  testsuites/libtests/can01/can-loopback.c | 110 -----
>  testsuites/libtests/can01/init.c         | 249 -----------
>  9 files changed, 1513 deletions(-)
>  delete mode 100644 cpukit/dev/can/can.c
>  delete mode 100644 cpukit/include/dev/can/can-msg.h
>  delete mode 100644 cpukit/include/dev/can/can.h
>  delete mode 100644 cpukit/include/dev/can/canqueueimpl.h
>  delete mode 100644 spec/build/testsuites/libtests/can01.yml
>  delete mode 100644 testsuites/libtests/can01/can-loopback.c
>  delete mode 100644 testsuites/libtests/can01/init.c
> 2.34.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230727/ff02b79e/attachment.htm>
