[PATCH 0/3] Revert CAN API
Thu Jul 27 18:50:31 UTC 2023
Thanks. I checked these in with one little change for a missed line in
a spec file.
On Thu, Jul 27, 2023 at 12:49 PM Joel Sherrill <joel at rtems.org> wrote:
> OK to revert. I didn't catch that it was 3 commits to revert cleanly.
> On Thu, Jul 27, 2023 at 1:28 PM Gedare Bloom <gedare at rtems.org> wrote:
>> The CAN API is not mature enough for a release. This patch set
>> reverts it. See #4803.
>> I expect to revisit this during the 7 development cycle.
>> Gedare Bloom (3):
>>   Revert "cpukit/dev/can: Resolve warnings in 64bit builds"
>>   Revert "build: Fix copyright statement format"
>>   Revert "cpukit/dev/can: Added CAN support"
>>  cpukit/dev/can/can.c                     | 507 -----------------------
>>  cpukit/include/dev/can/can-msg.h         | 105 -----
>>  cpukit/include/dev/can/can.h             | 284 -------------
>>  cpukit/include/dev/can/canqueueimpl.h    | 231 -----------
>>  spec/build/cpukit/librtemscpu.yml        |   5 -
>>  spec/build/testsuites/libtests/can01.yml |  20 -
>>  spec/build/testsuites/libtests/grp.yml   |   2 -
>>  testsuites/libtests/can01/can-loopback.c | 110 -----
>>  testsuites/libtests/can01/init.c         | 249 -----------
>>  9 files changed, 1513 deletions(-)
>>  delete mode 100644 cpukit/dev/can/can.c
>>  delete mode 100644 cpukit/include/dev/can/can-msg.h
>>  delete mode 100644 cpukit/include/dev/can/can.h
>>  delete mode 100644 cpukit/include/dev/can/canqueueimpl.h
>>  delete mode 100644 spec/build/testsuites/libtests/can01.yml
>>  delete mode 100644 testsuites/libtests/can01/can-loopback.c
>>  delete mode 100644 testsuites/libtests/can01/init.c
>> 2.34.1
>> devel mailing list
>> devel at rtems.org
