[PATCH] glossary: Add terms
Andrew.Butterfield at scss.tcd.ie Andrew.Butterfield at scss.tcd.ie
Tue Nov 28 19:49:10 UTC 2023
From: devel <devel-bounces at rtems.org> on behalf of Joel Sherrill <joel at rtems.org>
Reply to: "joel at rtems.org" <joel at rtems.org>
Date: Tuesday 28 November 2023 at 19:31
To: Sebastian Huber <sebastian.huber at embedded-brains.de>
Cc: "devel at rtems.org" <devel at rtems.org>
Subject: Re: [PATCH] glossary: Add terms
On Tue, Nov 28, 2023 at 10:27 AM Sebastian Huber <sebastian.huber at embedded-brains.de<mailto:sebastian.huber at embedded-brains.de>> wrote:
 c-user/glossary.rst   | 50 +++++++++++++++++++++++++++++++++++++++++++
 eng/fv/approaches.rst |  2 +-
 eng/fv/overview.rst   |  6 +++---
 eng/glossary.rst      | 26 +++++++++++++++++-----
 4 files changed, 75 insertions(+), 9 deletions(-)
diff --git a/c-user/glossary.rst b/c-user/glossary.rst
index 82aedcd..9a9d12c 100644
--- a/c-user/glossary.rst
+++ b/c-user/glossary.rst
@@ -1,5 +1,6 @@
 .. SPDX-License-Identifier: CC-BY-SA-4.0
+.. Copyright (C) 2022, 2023 Trinity College Dublin
 .. Copyright (C) 2020 Richi Dubey (richidubey at gmail.com<mailto:richidubey at gmail.com>)
 .. Copyright (C) 2015, 2023 embedded brains GmbH & Co. KG
 .. Copyright (C) 1988, 1998 On-Line Applications Research Corporation (OAR)
@@ -17,6 +18,9 @@ Glossary
         A term used to describe an object which has been created by an
         application.
+    AMP
+        This term is an acronym for Asymmetric Multiprocessing.
     APA
         This term is an acronym for Arbitrary Processor Affinity.  APA schedulers
         allow a thread to have an arbitrary affinity to a processor set, rather than
@@ -357,6 +361,10 @@ Glossary
         mathematically intensive situations.  It is typically viewed as a logical
         extension of the primary processor.
+    formal model
+        A model of a computing component (hardware or software) that has a
+        mathematically based :term:`semantics`.
This is in the neighborhood of the definitions I found but is missing a word
like rigorous.
For me "mathematically based" implies "rigorous", but I think you are right to emphasise this
How about: "A rigorous model of ...." ?
     freed
         A resource that has been released by the application to RTEMS.
@@ -386,6 +394,14 @@ Glossary
     GNU
         This term is an acronym for `GNU's Not Unix <https://www.gnu.org/>`_.
+    GPL
+        `GNU General Public License <https://www.gnu.org/licenses>`__.
+    GPLv3
+        `GNU General Public License Version 3 <https://www.gnu.org/licenses/gpl-3.0.html>`__.
Do we need to include an entry for the GPLv2 w/exception that is actually used by some RTEMS code.
     GR712RC
         The
         `GR712RC <https://www.gaisler.com/index.php/products/components/gr712rc>`_
@@ -511,6 +527,10 @@ Glossary
     LIFO
         This term is an acronym for :term:`Last In First Out`.
+    Linear Temporal Logic
+        This is a logic that states properties about (possibly infinite) sequences of
+        states.
     list
         A data structure which allows for dynamic addition and removal of
         entries.  It is not statically limited to a particular size.
@@ -520,6 +540,12 @@ Glossary
         are arranged such that the least significant byte is at the lowest
         address.
+    LLVM
+        `Low Level Virtual Machine <https://www.llvm.org>`__.
+        The LLVM Project is a collection of modular and reusable compiler and
+        toolchain technologies.
     local
         An object which was created with the LOCAL attribute and is accessible
         only on the node it was created and resides upon.  In a single processor
@@ -541,6 +567,9 @@ Glossary
         A :term:`task` ``L`` has a lower :term:`priority` than a task ``H``, if
         task ``L`` is less important than task ``H``.
+    LTL
+        This term is an acronym for :term:`Linear Temporal Logic`.
     major number
         The index of a device driver in the Device Driver Table.
@@ -632,6 +661,9 @@ Glossary
+    OBC
+        This term is an acronym for On-Board Computer.
     object
         In this document, this term is used to refer collectively to tasks,
         timers, message queues, partitions, regions, semaphores, ports, and rate
@@ -806,6 +838,10 @@ Glossary
         A term used to describe routines which do not modify themselves or global
         variables.
+    refinement
+        A *refinement* is a relationship between a specification and its
+        implementation as code.
     region
         An RTEMS object which is used to allocate and deallocate variable size
         blocks of memory from a dynamically specified area of memory.
@@ -818,6 +854,9 @@ Glossary
         Registers are locations physically located within a component, typically
         used for device control or general purpose storage.
+    reification
+        Another term used to denote :term:`refinement`.
     remote
         Any object that does not reside on the local node.
@@ -865,6 +904,12 @@ Glossary
         The state of a rate monotonic timer while it is being used to delineate a
         period.  The timer exits this state by either expiring or being canceled.
+    scenario
+        In a setting that involves many concurrent tasks that interleave in arbitrary
+        ways, a scenario describes a single specific possible interleaving.  One
+        interpretation of the behaviour of a concurrent system is the set of all its
+        scenarios.
This doesn't cover the common use case of a test scenario which is usually
less about threading and more about values and using a set of methods in
a particular manner.
In the context in which Sebastian asked me for this entry, the term `scenario` is used as described above.
But you are right that there are nuances here. In the Promela/SPIN based test-generation work, each
counter example we get from SPIN describes a scenario as defined above, and we generate C test code
that reproduces that scenario, including the precise interleaving of the tasks as per  that scenario.
     schedulable
         A set of tasks which can be guaranteed to meet their deadlines based upon
         a specific scheduling algorithm.
@@ -901,6 +946,11 @@ Glossary
     segments
         Variable sized memory blocks allocated from a region.
+    semantics
+        This term refers to the meaning of text or utterances in some language.  In a
+        software engineering context these will be programming, modelling or
+        specification languages.
     semaphore
         An RTEMS object which is used to synchronize tasks and provide mutually
         exclusive access to resources.
diff --git a/eng/fv/approaches.rst b/eng/fv/approaches.rst
index 6bbac20..fe58a06 100644
--- a/eng/fv/approaches.rst
+++ b/eng/fv/approaches.rst
@@ -168,7 +168,7 @@ in such a way that tests can be generated using the SPIN model checker
 Promela is quite a low-level modelling language that makes it easy to get close
 to code level, and is specifically targeted to modelling software. It is one of
 the most widely used model-checkers, both in industry and education. It uses
-assertions, and :term:`Linear Temporal Logic` (LTL) to express properties of
+assertions, and :term:`Linear Temporal Logic` (:term:`LTL`) to express properties of
 interest.
 Given a Promela model that checks key properties successfully,
diff --git a/eng/fv/overview.rst b/eng/fv/overview.rst
index 15ce7d8..da981f2 100755
--- a/eng/fv/overview.rst
+++ b/eng/fv/overview.rst
@@ -30,9 +30,9 @@ such as a specification. This relationship is commonly referred to as a
 Often it is quite difficult to get a useful formal model of real code. Some
 formal modelling approaches are capable of generating machine-readable
-:term:`scenarios` that describe possible correct behaviors of the system at the
-relevant level of abstraction. A refinement for these can be defined by
-using them to generate test code.
+:term:`scenarios <scenario>` that describe possible correct behaviors of the
+system at the relevant level of abstraction. A refinement for these can be
+defined by using them to generate test code.
This definition of scenario is different from the one in the glossary. It
is more inline with what I expected.
Hmmm. For me, the use of scenarios up above is precisely the same as per the scenario glossary entry!
 This is the technique that is used in :ref:`FormalVerifMethodology` to
 verify parts of RTEMS. Formal models are constructed based on requirements
 documentation, and are used as a basis for test generation.
diff --git a/eng/glossary.rst b/eng/glossary.rst
index 0e0b708..42cadc4 100644
--- a/eng/glossary.rst
+++ b/eng/glossary.rst
@@ -1,5 +1,6 @@
 .. Copyright (C) 2017, 2019 embedded brains GmbH & Co. KG
@@ -39,6 +40,10 @@ Glossary
         `Executable and Linkable Format <https://en.wikipedia.org/wiki/Executable_and_Linkable_Format>`_.
+    formal model
Why is this duplicated? Don't we have a single glossary file?
There are other duplicates below. Can we have a single source of truth?
     GCC
         This term is an acronym for `GNU Compiler Collection <https://gcc.gnu.org/>`_.
@@ -64,15 +69,15 @@ Glossary
         This term is an acronym for Independent Software Verification and Validation.
-        This is a logic that states properties about
-        (possibly infinite) sequences of states.
+        states.
     LTL
-        This term is an acronym for Linear Temporal Logic.
     refinement
-        A *refinement* is a relationship between a specification
-        and its implementation as code.
     reification
@@ -84,6 +89,17 @@ Glossary
     RTEMS
         This term is an acronym for Real-Time Executive for Multiprocessor Systems.
+    scenario
+        scenarios.
+    semantics
     software component
         This term is defined by ECSS-E-ST-40C 3.2.28 as a "part of a software
         system".  For this project a *software component* shall be any of the
2.35.3
devel mailing list
devel at rtems.org<mailto:devel at rtems.org>
http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20231128/2a3f8722/attachment-0001.htm>
