[PATCH] glossary: Add terms
Wed Nov 29 08:13:29 UTC 2023
On 28.11.23 20:49, Andrew.Butterfield at scss.tcd.ie wrote:
>     +    scenario
>     +        In a setting that involves many concurrent tasks that
>     interleave in arbitrary
>     +        ways, a scenario describes a single specific possible
>     interleaving.  One
>     +        interpretation of the behaviour of a concurrent system is
>     the set of all its
>     +        scenarios.
> This doesn't cover the common use case of a test scenario which is usually
> less about threading and more about values and using a set of methods in
> a particular manner.
> In the context in which Sebastian asked me for this entry, the term
> `scenario` is used as described above.
> But you are right that there are nuances here. In the Promela/SPIN based
> test-generation work, each
> counter example we get from SPIN describes a scenario as defined above,
> and we generate C test code
> that reproduces that scenario, including the precise interleaving of the
> tasks as per  that scenario.
The term scenario is used a lot in the formal verification chapter, so
it should have an entry. Joel, do you have a suggestion to improve the
wording?
embedded brains GmbH & Co. KG
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
