ADA, gnat, rtems 6, ubuntu 22LTS
Wed Oct 4 19:15:47 UTC 2023
Random thought. Is there a gnat1? Can you build a native Ada hello world?
I'm not sure what that configure check is trying but looking at that is the
next step.
On Wed, Oct 4, 2023, 12:02 PM emanuel stiebler <emu at e-bbes.com> wrote:
> I just tried to compile the tools for rtems6,
> and just with "C", everything(?) works.
> Trying to add ADA to the tools, it fails, complaining about gnat not
> being installed.
> In the logfile:
> hecking for objdir... .libs
> configure: WARNING: using in-tree isl, disabling version check
> configure: error: GNAT is required to build ada
> shell cmd failed: /bin/sh -ex
> /AD1/PUB/RTEMS.work/rsb/rtems/build/aarch64-rtems6-gcc-506cb58-newlib-a021448-x86_64-linux-gnu-1/do-build
> error: building
> aarch64-rtems6-gcc-506cb58-newlib-a021448-x86_64-linux-gnu-1emu at W531:/AD1/PUB/RTEMS.work/rsb/rtems$
> but "gnat" gives me:
> DDD at W531:/AD1/PUB/RTEMS.work/rsb/rtems$ gnat
> GNAT 12.3.0
> Copyright 1996-2022, Free Software Foundation, Inc.
> To list Ada build switches use --help-ada
> List of available commands
> gnat bind               x86_64-linux-gnu-gnatbind-12
> gnat chop               x86_64-linux-gnu-gnatchop-12
> gnat clean              x86_64-linux-gnu-gnatclean-12
> gnat compile            x86_64-linux-gnu-gnatmake-12 -f -u -c
> gnat check              x86_64-linux-gnu-gnatcheck-12
> gnat elim               x86_64-linux-gnu-gnatelim-12
> gnat find               x86_64-linux-gnu-gnatfind-12
> gnat krunch             x86_64-linux-gnu-gnatkr-12
> gnat link               x86_64-linux-gnu-gnatlink-12
> gnat list               x86_64-linux-gnu-gnatls-12
> gnat make               x86_64-linux-gnu-gnatmake-12
> gnat metric             x86_64-linux-gnu-gnatmetric-12
> gnat name               x86_64-linux-gnu-gnatname-12
> gnat preprocess         x86_64-linux-gnu-gnatprep-12
> gnat pretty             x86_64-linux-gnu-gnatpp-12
> gnat stack              x86_64-linux-gnu-gnatstack-12
> gnat stub               x86_64-linux-gnu-gnatstub-12
> gnat test               x86_64-linux-gnu-gnattest-12
> gnat xref               x86_64-linux-gnu-gnatxref-12
> Report bugs to report at adacore.com
> What am I missing?
> (GIT version of yesterday ...)
> Cheers & Thanks
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20231004/5161141a/attachment-0001.htm>
