ADA, gnat, rtems 6, ubuntu 22LTS
Frank Kühndel frank.kuehndel at embedded-brains.de
Thu Oct 5 10:42:49 UTC 2023
Hello Emanuel,
I cannot say anything about your specific issue. I can just provide this
information:
Our CI/CD builds rtems-tools with ADA on Ubuntu 22.04 for RSB, Git
commit 35c73203df1e0bc7f0935cfb37ebc6581d8f1103 for aarch64, arm, bfin,
i386, m68k, mips, moxie, nios2, or1k, powerpc, riskv, sparc, x86_64. The
other architectures seem to have problems. Moreover, ADA is only build
but not tested.
The big issue between building with and without ADA comes down to have
Ubuntu specially setup for the RTEMS Source Builder to being able to
build ADA. I need these packages:
bzip2
gcc-12
g++-12
gnat-12
And I need the following links (all g** compiler tools must have the
same version 12 and all must be available without the "-12" postfix):
ln -s gcc /usr/bin/cc
for exe in /usr/bin/gcc*12 /usr/bin/gcov*12 /usr/bin/g++*12; do
    ln -s $exe ${exe%-12}
done
Greetings
Frank
On 10/4/23 19:02, emanuel stiebler wrote:
> Subject:
> From:
> emanuel stiebler <emu at e-bbes.com>
> Date:
> 10/4/23, 19:02
> To:
> "rtems-devel at rtems.org" <devel at rtems.org>
> I just tried to compile the tools for rtems6,
> and just with "C", everything(?) works.
> Trying to add ADA to the tools, it fails, complaining about gnat not
> being installed.
> In the logfile:
> hecking for objdir... .libs
> configure: WARNING: using in-tree isl, disabling version check
> configure: error: GNAT is required to build ada
> shell cmd failed: /bin/sh -ex
> /AD1/PUB/RTEMS.work/rsb/rtems/build/aarch64-rtems6-gcc-506cb58-newlib-a021448-x86_64-linux-gnu-1/do-build
> error: building
> aarch64-rtems6-gcc-506cb58-newlib-a021448-x86_64-linux-gnu-1emu at W531:/AD1/PUB/RTEMS.work/rsb/rtems$
> but "gnat" gives me:
> DDD at W531:/AD1/PUB/RTEMS.work/rsb/rtems$ gnat
> GNAT 12.3.0
> Copyright 1996-2022, Free Software Foundation, Inc.
> To list Ada build switches use --help-ada
> List of available commands
> gnat bind               x86_64-linux-gnu-gnatbind-12
> gnat chop               x86_64-linux-gnu-gnatchop-12
> gnat clean              x86_64-linux-gnu-gnatclean-12
> gnat compile            x86_64-linux-gnu-gnatmake-12 -f -u -c
> gnat check              x86_64-linux-gnu-gnatcheck-12
> gnat elim               x86_64-linux-gnu-gnatelim-12
> gnat find               x86_64-linux-gnu-gnatfind-12
> gnat krunch             x86_64-linux-gnu-gnatkr-12
> gnat link               x86_64-linux-gnu-gnatlink-12
> gnat list               x86_64-linux-gnu-gnatls-12
> gnat make               x86_64-linux-gnu-gnatmake-12
> gnat metric             x86_64-linux-gnu-gnatmetric-12
> gnat name               x86_64-linux-gnu-gnatname-12
> gnat preprocess         x86_64-linux-gnu-gnatprep-12
> gnat pretty             x86_64-linux-gnu-gnatpp-12
> gnat stack              x86_64-linux-gnu-gnatstack-12
> gnat stub               x86_64-linux-gnu-gnatstub-12
> gnat test               x86_64-linux-gnu-gnattest-12
> gnat xref               x86_64-linux-gnu-gnatxref-12
> Report bugs to report at adacore.com
> What am I missing?
> (GIT version of yesterday ...)
> Cheers & Thanks
> devel mailing list
> devel at rtems.org
embedded brains GmbH & Co. KG
Herr Frank KÜHNDEL
Dornierstr. 4
82178 Puchheim
Germany
email: frank.kuehndel at embedded-brains.de
phone:  +49-89-18 94 741 - 23
mobile: +49-176-15 22 06 - 11
Registernummer: HRA 117265
