[PATCH 1/3] bsps/xilinx-zynqmp: Unify JFFS2 OOB write locking
Kinsey Moore kinsey.moore at oarcorp.com
Fri Oct 6 20:09:04 UTC 2023
Ensure that a single locking session is carried over OOB writes
including the OOB read that is sometimes required. This removes the
possibility of another write occurring between the read and write that
would make the write incorrect.
 bsps/aarch64/xilinx-zynqmp/jffs2_xnandpsu.c | 23 +++++++++++++++------
 1 file changed, 17 insertions(+), 6 deletions(-)
diff --git a/bsps/aarch64/xilinx-zynqmp/jffs2_xnandpsu.c b/bsps/aarch64/xilinx-zynqmp/jffs2_xnandpsu.c
index 5fb00d5eeb..ab0eb1ccd5 100644
--- a/bsps/aarch64/xilinx-zynqmp/jffs2_xnandpsu.c
+++ b/bsps/aarch64/xilinx-zynqmp/jffs2_xnandpsu.c
@@ -175,7 +175,7 @@ static int flash_block_mark_bad(
   return RTEMS_SUCCESSFUL;
-static int flash_read_oob(
+static int flash_read_oob_locked(
   rtems_jffs2_flash_control *super,
   uint32_t offset,
   uint8_t *oobbuf,
@@ -203,7 +203,6 @@ static int flash_read_oob(
     return -ENOMEM;
-  rtems_mutex_lock(&(get_flash_control(super)->access_lock));
   while (ooblen) {
     int rv = XNandPsu_ReadSpareBytes(nandpsu, PageIndex, spare_bytes);
     /* no guarantee oobbuf can hold all of spare bytes, so read and then copy */
@@ -213,7 +212,6 @@ static int flash_read_oob(
     if (rv) {
-      rtems_mutex_unlock(&(get_flash_control(super)->access_lock));
       free(spare_bytes);
       return -EIO;
@@ -224,11 +222,23 @@ static int flash_read_oob(
     ooblen -= readlen;
     oobbuf += readlen;
   free(spare_bytes);
+static int flash_read_oob(
+  rtems_jffs2_flash_control *super,
+  uint32_t offset,
+  uint8_t *oobbuf,
+  uint32_t ooblen
+  rtems_mutex_lock(&(get_flash_control(super)->access_lock));
+  int ret = flash_read_oob_locked(super, offset, oobbuf, ooblen);
+  rtems_mutex_unlock(&(get_flash_control(super)->access_lock));
+  return ret;
 static int flash_write_oob(
   uint32_t offset,
@@ -257,10 +267,12 @@ static int flash_write_oob(
   /* Writing a page spare area to small will result in invalid accesses */
   if (ooblen < SpareBytesPerPage) {
-    int rv = flash_read_oob(super, offset, spare_bytes, SpareBytesPerPage);
+    int rv = flash_read_oob_locked(super, offset, spare_bytes, SpareBytesPerPage);
     if (rv) {
       free(spare_bytes);
       return rv;
     buffer = spare_bytes;
@@ -270,7 +282,6 @@ static int flash_write_oob(
   /* Get page index */
   uint32_t PageIndex = offset / nandpsu->Geometry.BytesPerPage;
   sc = XNandPsu_WriteSpareBytes(nandpsu, PageIndex, buffer);
   free(spare_bytes);
2.39.2
