[PATCH rtems-source-builder] qemu: Adjust cgem interrupt patch
Sat Oct 7 04:27:20 UTC 2023
OK
Thanks
On 7/10/2023 6:05 am, Kinsey Moore wrote:
> This patch is being moved to the 5.2.0-1 QEMU configuration because the
> Xilinx QEMU build uses the 5-1 configuration and this patch does not
> apply to Xilinx's modified tree. This also adds a new patch that applies
> correctly to Xilinx's modified QEMU tree.
> Updates #4919
>  bare/config/devel/qemu-5.2.0-1.cfg          | 7 +++++++
>  bare/config/devel/qemu-xilinx-v2020.2-1.cfg | 7 +++++++
>  source-builder/config/qemu-5-1.cfg          | 4 ----
>  3 files changed, 14 insertions(+), 4 deletions(-)
> diff --git a/bare/config/devel/qemu-5.2.0-1.cfg b/bare/config/devel/qemu-5.2.0-1.cfg
> index 1c1cfeb..3c8186b 100644
> --- a/bare/config/devel/qemu-5.2.0-1.cfg
> +++ b/bare/config/devel/qemu-5.2.0-1.cfg
> @@ -36,6 +36,13 @@
>  %hash sha512 qemu-5.2.0-leon3.patch \
>         cQju/ja5SAM+gsXEkzSteeR+7PjG9g2w+yUb4kg1eZoOSm2MmZDjA/auINVdRax8wgtIEWnzq5/hdY7/THnowg==
> +# Patch to fix cgem priority queue interrupt functionality issue
> +%patch add qemu --rsb-file=cgem_zynqmp_versal.patch -p1 https://devel.rtems.org/raw-attachment/ticket/4919/0001-hw-arm-xlnx-Connect-secondary-CGEM-IRQs.patch
> +%hash sha512 cgem_zynqmp_versal.patch \
> +  XIAGD29Qa4uaEKij3TYh1HJUJb7r9ZjZXl19t3Vk+8uleG2O7M1xgqmeA6zoQq+GCrcMRoJxqV4kniRapLgZRQ==
>  # The Qemu build instructions. We use 5.x.x Release 1.
> diff --git a/bare/config/devel/qemu-xilinx-v2020.2-1.cfg b/bare/config/devel/qemu-xilinx-v2020.2-1.cfg
> index 2c3fb94..ca70ebd 100644
> --- a/bare/config/devel/qemu-xilinx-v2020.2-1.cfg
> +++ b/bare/config/devel/qemu-xilinx-v2020.2-1.cfg
> @@ -17,6 +17,13 @@
>  %source set qemu git://github.com/Xilinx/qemu.git?protocol=https?checkout=%{qemu_version}?submodule=dtc?submodule=slirp?submodule=ui/keycodemapdb?submodule=tests/fp/berkeley-softfloat-3?submodule=tests/fp/berkeley-testfloat-3
> +%patch add qemu --rsb-file=xlnx_cgem_zynqmp_versal.patch -p1 https://devel.rtems.org/raw-attachment/ticket/4919/0001-hw-arm-xlnx-Connect-secondary-CGEM-IRQs-xlnx.patch
> +%hash sha512 xlnx_cgem_zynqmp_versal.patch \
> +  tGjJn7o8/fQwdC0sgsYmPW6bqDzMkwhKRqBwuuy8sdEKivDj7uGISMj7p8Iwy9fkHiO3Dd3feno+iz5fHYGBkA==
> diff --git a/source-builder/config/qemu-5-1.cfg b/source-builder/config/qemu-5-1.cfg
> index 89d203c..7ca58b8 100644
> --- a/source-builder/config/qemu-5-1.cfg
> +++ b/source-builder/config/qemu-5-1.cfg
> @@ -7,7 +7,3 @@
>  %define qemu_disables --disable-nettle
>  %include %{_configdir}/qemu-common-2.cfg
> -%patch add qemu --rsb-file=cgem_zynqmp_versal.patch -p1 https://devel.rtems.org/raw-attachment/ticket/4919/0001-hw-arm-xlnx-Connect-secondary-CGEM-IRQs.patch
> -%hash sha512 cgem_zynqmp_versal.patch \
> -  XIAGD29Qa4uaEKij3TYh1HJUJb7r9ZjZXl19t3Vk+8uleG2O7M1xgqmeA6zoQq+GCrcMRoJxqV4kniRapLgZRQ==
