[PATCH 1/2] score: Fix RTEMS_DEFINE_GLOBAL_SYMBOL()
Tue Sep 12 14:44:19 UTC 2023
The availability of a proper RTEMS_DEFINE_GLOBAL_SYMBOL() implementation
depends on __asm__() and thus __GNUC__.
Clarify documentation.
Update #4953.
 cpukit/include/rtems/score/basedefs.h | 5 +++--
 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/cpukit/include/rtems/score/basedefs.h b/cpukit/include/rtems/score/basedefs.h
index 99fda67e8c..0cf7272b5d 100644
--- a/cpukit/include/rtems/score/basedefs.h
+++ b/cpukit/include/rtems/score/basedefs.h
@@ -999,11 +999,12 @@ extern "C" {
  * @param _value is the value of the symbol.  On the value a macro expansion is
  *   performed and afterwards it is stringified.  It shall expand to an integer
- *   expression understood by the assembler.
+ *   expression understood by the assembler.  The value shall be representable
+ *   in the code model of the target architecture.
  * This macro shall be placed at file scope.
-#if defined(__USER_LABEL_PREFIX__)
+#if defined(__GNUC__)
   #define RTEMS_DEFINE_GLOBAL_SYMBOL( _name, _value ) \
     __asm__( \
       "\t.globl " RTEMS_XSTRING( RTEMS_SYMBOL_NAME( _name ) ) \
2.35.3
