[PATCH 1/2] score: Fix RTEMS_DEFINE_GLOBAL_SYMBOL()
Wed Sep 13 01:14:36 UTC 2023
OK
Thanks
On 13/9/2023 12:44 am, Sebastian Huber wrote:
> The availability of a proper RTEMS_DEFINE_GLOBAL_SYMBOL() implementation
> depends on __asm__() and thus __GNUC__.
> Clarify documentation.
> Update #4953.
>  cpukit/include/rtems/score/basedefs.h | 5 +++--
>  1 file changed, 3 insertions(+), 2 deletions(-)
> diff --git a/cpukit/include/rtems/score/basedefs.h b/cpukit/include/rtems/score/basedefs.h
> index 99fda67e8c..0cf7272b5d 100644
> --- a/cpukit/include/rtems/score/basedefs.h
> +++ b/cpukit/include/rtems/score/basedefs.h
> @@ -999,11 +999,12 @@ extern "C" {
>   * @param _value is the value of the symbol.  On the value a macro expansion is
>   *   performed and afterwards it is stringified.  It shall expand to an integer
> - *   expression understood by the assembler.
> + *   expression understood by the assembler.  The value shall be representable
> + *   in the code model of the target architecture.
>   * This macro shall be placed at file scope.
> -#if defined(__USER_LABEL_PREFIX__)
> +#if defined(__GNUC__)
>    #define RTEMS_DEFINE_GLOBAL_SYMBOL( _name, _value ) \
>      __asm__( \
>        "\t.globl " RTEMS_XSTRING( RTEMS_SYMBOL_NAME( _name ) ) \
