[PATCH 1/2] cpukit/jffs2: Set extracted nodes off-chain
Kinsey Moore kinsey.moore at oarcorp.com
Wed Sep 20 18:35:07 UTC 2023
The code here was developed under RTEMS_DEBUG=true which automatically
sets nodes off-chain upon extraction. Extraction does not set nodes
off-chain when not running under RTEMS_DEBUG=true. This code relies on
this behavior, so set nodes off-chain as needed.
Updates #4956
 cpukit/libfs/src/jffs2/src/fs-rtems.c | 15 +++++++++++++++
 1 file changed, 15 insertions(+)
diff --git a/cpukit/libfs/src/jffs2/src/fs-rtems.c b/cpukit/libfs/src/jffs2/src/fs-rtems.c
index 1a677c9772..36bada9a98 100644
--- a/cpukit/libfs/src/jffs2/src/fs-rtems.c
+++ b/cpukit/libfs/src/jffs2/src/fs-rtems.c
@@ -1268,6 +1268,7 @@ static void jffs2_remove_delayed_work(struct delayed_work *dwork)
 		rtems_chain_node* next_node = rtems_chain_next(node);
 		if (work == dwork) {
 			rtems_chain_extract(node);
+			rtems_chain_set_off_chain(node);
 			mutex_unlock(&delayed_work_mutex);
 			return;
@@ -1306,8 +1307,22 @@ static void process_delayed_work(void)
 	while (!rtems_chain_is_tail(&process_work_chain, node)) {
 		work = (struct delayed_work*) node;
+		 * Don't leave extracted node exposed to other operations
+		 * under RTEMS_DEBUG
+#ifdef RTEMS_DEBUG
+		mutex_lock(&delayed_work_mutex);
+#endif
+#ifdef RTEMS_DEBUG
+		node->next = node;
+		mutex_unlock(&delayed_work_mutex);
+#endif
 		work->callback(&work->work);
 		node = next_node;
2.39.2
