[PATCH 2/2] cpukit/jffs2: Use unprotected chain calls
Kinsey Moore kinsey.moore at oarcorp.com
Wed Sep 20 18:35:08 UTC 2023
Use unprotected chain calls for delayed write workqueues since these
calls are either protected by locks or only operate on local chains and
are never accessed from interrupt context.
Updates #4956
 cpukit/libfs/src/jffs2/src/fs-rtems.c | 10 +++++-----
 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/cpukit/libfs/src/jffs2/src/fs-rtems.c b/cpukit/libfs/src/jffs2/src/fs-rtems.c
index 36bada9a98..644c7385c5 100644
--- a/cpukit/libfs/src/jffs2/src/fs-rtems.c
+++ b/cpukit/libfs/src/jffs2/src/fs-rtems.c
@@ -1246,7 +1246,7 @@ void jffs2_queue_delayed_work(struct delayed_work *work, int delay_ms)
 	mutex_lock(&delayed_work_mutex);
 	if (rtems_chain_is_node_off_chain(&work->work.node)) {
 		work->execution_time = rtems_clock_get_uptime_nanoseconds() + delay_ms*1000000;
-		rtems_chain_append(&delayed_work_chain, &work->work.node);
+		rtems_chain_append_unprotected(&delayed_work_chain, &work->work.node);
 	mutex_unlock(&delayed_work_mutex);
@@ -1267,7 +1267,7 @@ static void jffs2_remove_delayed_work(struct delayed_work *dwork)
 		work = (struct delayed_work*) node;
 		rtems_chain_node* next_node = rtems_chain_next(node);
 		if (work == dwork) {
-			rtems_chain_extract(node);
+			rtems_chain_extract_unprotected(node);
 			rtems_chain_set_off_chain(node);
 			return;
@@ -1296,8 +1296,8 @@ static void process_delayed_work(void)
 		if (rtems_clock_get_uptime_nanoseconds() >= work->execution_time) {
-			rtems_chain_append(&process_work_chain, node);
+			rtems_chain_append_unprotected(&process_work_chain, node);
 		node = next_node;
@@ -1315,7 +1315,7 @@ static void process_delayed_work(void)
 #ifdef RTEMS_DEBUG
 #endif
 #ifdef RTEMS_DEBUG
 		node->next = node;
2.39.2
