Clarification Regarding Initial Project Scope for "Add BSP for Polarfire based Beagle"
Tue Apr 2 14:35:03 UTC 2024
On Tue, Apr 2, 2024, 9:28 AM Purva Yeshi <purvayeshi550 at gmail.com> wrote:
> Hello,
> I'm reaching out to seek clarification regarding the initial scope of the
> "Add BSP for Polarfire based Beagle" project that I've applied for.
> As outlined in the project description, the primary aim is to create a BSP
> for the Beagle-V Fire board. Therefore, one part of the project involves
> developing support for essential components such as CPU cores (both E51 and
> U54), interrupt controller (PLIC), timer (CLINT), and UART. If the
> UART, CPU cores, interrupt controller and timer are already supported, I'm
> considering modifications may be required for the *particular hardware*
> BSP.
> Considering these requirements,  I'm seeking clarification on whether it
> would be acceptable   to focus on running a "Hello World" code on the
> Beagle-V Fire board at the initial stage. My plan is to prioritize the
> implementation of support for the aforementioned components while keeping
> Ethernet and U54 MMU support for future development.
> Could you please provide guidance on whether running a "Hello World" code
> initially aligns with the project's expectations? Additionally, I would
> like to know if there is a high requirement to include support for Ethernet
> and U54 MMU in the proposal, or if it could be considered as part of the
> future scope.
When authoring a new BSP, it is best to focus on hello world and then
ticker. With those working, all of the tests in RTEMS.git should be ok. So
third is testing using RTEMS tester
Then focus on additional capabilities like adding individual devices
drivers, SMP, etc.
But if you cannot run hello and ticker, nothing else will be worth running
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240402/d0778db9/attachment.htm>
