[RSB PATCH] sb: Add sb-rtems-pkg to update the RTEMS package hashes and checksums
Kinsey Moore kinsey.moore at oarcorp.com
Wed Apr 3 16:51:53 UTC 2024
Looks fine overall. Minor nits:
"host" is set to "freebsd" and is never used.
Numeric indexes for repo config details are nice for brevity, but not for
readability.
Kinsey
On Wed, Apr 3, 2024 at 11:29 AM Joel Sherrill <joel.sherrill at gmail.com>
wrote:
> This looks handy. I don't have an issue with it.
> On Tue, Apr 2, 2024 at 11:25 PM <chrisj at rtems.org> wrote:
>> From: Chris Johns <chrisj at rtems.org>
>>  source-builder/sb-rtems-pkg   |  29 ++++
>>  source-builder/sb/download.py |   5 +-
>>  source-builder/sb/git.py      |  12 ++
>>  source-builder/sb/rtemspkg.py | 279 ++++++++++++++++++++++++++++++++++
>>  4 files changed, 324 insertions(+), 1 deletion(-)
>>  create mode 100755 source-builder/sb-rtems-pkg
>>  create mode 100644 source-builder/sb/rtemspkg.py
>> diff --git a/source-builder/sb-rtems-pkg b/source-builder/sb-rtems-pkg
>> new file mode 100755
>> index 0000000..99ed26c
>> --- /dev/null
>> +++ b/source-builder/sb-rtems-pkg
>> @@ -0,0 +1,29 @@
>> +#! /usr/bin/env python
>> +# RTEMS Tools Project (http://www.rtems.org/)
>> +# Copyright 2024 Chris Johns (chrisj at rtems.org)
>> +# All rights reserved.
>> +# This file is part of the RTEMS Tools package in 'rtems-tools'.
>> +# Permission to use, copy, modify, and/or distribute this software for
>> any
>> +# purpose with or without fee is hereby granted, provided that the above
>> +# copyright notice and this permission notice appear in all copies.
>> +# THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL
>> WARRANTIES
>> +# WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED WARRANTIES OF
>> +# MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR
>> +# ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES OR ANY DAMAGES
>> +# WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS, WHETHER IN AN
>> +# ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION, ARISING OUT OF
>> +# OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE.
>> +from __future__ import print_function
>> +try:
>> +    import sb.rtemspkg
>> +    sb.rtemspkg.run()
>> +except ImportError:
>> +    import sys
>> +    print("Incorrect Source Builder installation", file = sys.stderr)
>> +    sys.exit(1)
>> diff --git a/source-builder/sb/download.py b/source-builder/sb/download.py
>> index 6e6f9f2..0201675 100644
>> --- a/source-builder/sb/download.py
>> +++ b/source-builder/sb/download.py
>> @@ -85,6 +85,8 @@ def _hash_check(file_, absfile, macros, remove = True):
>>          hash = hash.split()
>>          if len(hash) != 2:
>>              raise error.internal('invalid hash format: %s' % (file_))
>> +        if hash[0] == 'NO-HASH':
>> +            return not failed
>>          try:
>>              hashlib_algorithms = hashlib.algorithms
>>          except:
>> @@ -479,7 +481,8 @@ def _git_downloader(url, local, config, opts):
>>      else:
>>          repo.clean(['-f', '-d'])
>>          repo.reset('--hard')
>> -        repo.checkout('master')
>> +        default_branch = repo.default_branch()
>> +        repo.checkout(default_branch)
>>      for a in us[1:]:
>>          _as = a.split('=')
>>          if _as[0] == 'branch' or _as[0] == 'checkout':
>> diff --git a/source-builder/sb/git.py b/source-builder/sb/git.py
>> index 237e690..0aa4da9 100644
>> --- a/source-builder/sb/git.py
>> +++ b/source-builder/sb/git.py
>> @@ -226,6 +226,18 @@ class repo:
>>                  hash = l1[len('commit '):]
>>          return hash
>> +    def default_branch(self):
>> +        ec, output = self._run(['remote', 'show'])
>> +        if ec == 0:
>> +            origin = output.split('\n')[0]
>> +            ec, output = self._run(['remote', 'show', origin])
>> +            if ec == 0:
>> +                for l in output.split('\n'):
>> +                    l = l.strip()
>> +                    if l.startswith('HEAD branch: '):
>> +                        return l[len('HEAD branch: '):]
>> +        return None
>>  if __name__ == '__main__':
>>      import os.path
>>      import sys
>> diff --git a/source-builder/sb/rtemspkg.py b/source-builder/sb/rtemspkg.py
>> new file mode 100644
>> index 0000000..0b43d23
>> --- /dev/null
>> +++ b/source-builder/sb/rtemspkg.py
>> @@ -0,0 +1,279 @@
>> any
>> WARRANTIES
>> +# This code builds a package compiler tool suite given a tool set. A tool
>> +# set lists the various tools. These are specific tool configurations.
>> +import argparse
>> +import base64
>> +import copy
>> +import datetime
>> +import hashlib
>> +import os
>> +import sys
>> +try:
>> +    from . import build
>> +    from . import download
>> +    from . import error
>> +    from . import git
>> +    from . import log
>> +    from . import path
>> +    from . import simhost
>> +    from . import version
>> +except KeyboardInterrupt:
>> +    print('abort: user terminated', file=sys.stderr)
>> +    sys.exit(1)
>> +except:
>> +    raise
>> +# RTEMS Packages we maintian a git hash of in the RSB
>> +rtems_pkg_cfgs = [
>> +        'RTEMS Tools', 'tools/rtems-tools-%{rtems_version}.cfg',
>> +        'rtems_tools_version', 'git://git.rtems.org/rtems-tools',
>> +        'rtems-tools.git', 'master',
>> https://git.rtems.org/rtems-tools/snapshot/rtems-tools-%{rtems_tools_version}.tar.bz2
>> +        'rtems-tools-%{rtems_tools_version}.tar.bz2'
>> +        'RTEMS Kernel', 'tools/rtems-kernel-%{rtems_version}.cfg',
>> +        'rtems_kernel_version', 'git://git.rtems.org/rtems',
>> 'rtems.git',
>> +        'master',
>> https://git.rtems.org/rtems/snapshot/rtems-%{rtems_kernel_version}.tar.bz2
>> +        'rtems-kernel-%{rtems_kernel_version}.tar.bz2'
>> +        'RTEMS LibBSD', 'tools/rtems-libbsd-%{rtems_version}.cfg',
>> +        'rtems_libbsd_version', 'git://git.rtems.org/rtems-libbsd',
>> +        'rtems-libbsd.git', '6-freebsd-12',
>> https://git.rtems.org/rtems-libbsd/snapshot/rtems-libbsd-%{rtems_libbsd_version}.tar.%{rtems_libbsd_ext}
>> +        'rtems-libbsd-%{rtems_libbsd_version}.tar.%{rtems_libbsd_ext}'
>> +        'RTEMS Net Legacy',
>> 'tools/rtems-net-legacy-%{rtems_version}.cfg',
>> +        'rtems_net_version', 'git://git.rtems.org/rtems-net-legacy',
>> +        'rtems-net-legacy.git', 'main',
>> https://git.rtems.org/rtems-net-legacy/snapshot/rtems-net-legacy-%{rtems_net_version}.tar.%{rtems_net_ext}
>> +        'rtems-net-legacy-%{rtems_net_version}.tar.%{rtems_net_ext}'
>> +        'RTEMS Net Services', 'net/net-services-1.cfg',
>> +        'rtems_net_services_version', 'git://
>> git.rtems.org/rtems-net-services',
>> +        'rtems-net-services.git', 'master',
>> https://git.rtems.org/rtems-net-services/snapshot/rtems-net-services-%{rtems_net_services_version}.tar.%{rtems_net_services_ext}
>> 'rtems-net-services-%{rtems_net_services_version}.tar.%{rtems_net_services_ext}'
>> +def clean_line(line):
>> +    line = line[0:-1]
>> +    b = line.find('#')
>> +    if b >= 0:
>> +        line = line[1:b] + ('\\' if line[-1] == '\\' else '')
>> +    return line.strip()
>> +def clean_and_pack(line, last_line):
>> +    leading_ws = ' ' if len(line) > 0 and line[0].isspace() else ''
>> +    line = clean_line(line)
>> +    if len(last_line) > 0:
>> +        line = last_line + leading_ws + line
>> +    return line
>> +def config_patch(configdir, config, version_label, config_hash,
>> repo_hash,
>> +                 checksum):
>> +    for cd in configdir.split(':'):
>> +        cf = path.join(cd, config)
>> +        if path.exists(cf):
>> +            try:
>> +                with open(cf) as f:
>> +                    lines = f.readlines()
>> +            except IOError as err:
>> +                raise error.general('config: %s: read error: %s' %
>> +                                    (config, str(err)))
>> +            new_config = []
>> +            new_lines = []
>> +            last_line = ''
>> +            for line in lines:
>> +                new_lines += [line]
>> +                line = clean_and_pack(line, last_line)
>> +                if len(line) > 0:
>> +                    if line[-1] == '\\':
>> +                        last_line = line[:-1]
>> +                        continue
>> +                    last_line = ''
>> +                    if version_label in line and not 'rsb_version' in
>> line:
>> +                        if line.startswith('%define ' + version_label):
>> +                            new_lines = [
>> +                                '%define ' + version_label + ' ' +
>> repo_hash +
>> +                                os.linesep
>> +                        elif line.startswith('%hash '):
>> +                            ls = line.split()
>> +                            if len(ls) != 4:
>> +                                raise error.general('invalid %hash: ' +
>> line)
>> +                            new_lines = [
>> +                                ' '.join(ls[0:3]) + ' \\' + os.linesep,
>> +                                '              ' + checksum + os.linesep
>> +                new_config += new_lines
>> +                new_lines = []
>> +            try:
>> +                with open(cf, 'w') as f:
>> +                    f.writelines(new_config)
>> +                raise error.general('config: %s: write error: %s' %
>> +            return
>> +    raise error.general('could not find: ' + config)
>> +def checksum_shar512_base64(tarball):
>> +    hasher = hashlib.new('sha512')
>> +    try:
>> +        with open(path.host(tarball), 'rb') as f:
>> +            hasher.update(f.read())
>> +        log.notice('hash: %s: read error: %s' % (file_, str(err)))
>> +    except:
>> +        raise
>> +        raise error.general('cannot hash the tar file')
>> +    hash_hex = hasher.hexdigest()
>> +    hash_base64 = base64.b64encode(hasher.digest()).decode('utf-8')
>> +    return hash_base64
>> +def run(args=sys.argv):
>> +    ec = 0
>> +    output = []
>> +    try:
>> +        # The RSB options support cannot be used because it loads the
>> defaults
>> +        # for the host which we cannot do here.
>> +        description = 'RTEMS Track Dependencies a build set has for all
>> hosts.'
>> +        argsp = argparse.ArgumentParser(prog='sb-rtems-pkg',
>> +                                        description=description)
>> +        argsp.add_argument('--rtems-version',
>> +                           help='Set the RTEMS version.',
>> +                           type=str,
>> +                           default=version.version())
>> +        argsp.add_argument('--output',
>> +                           help='Output file.',
>> +                           type=str,
>> +                           default=None)
>> +        argsp.add_argument('--log',
>> +                           help='Log file.',
>> +                           type=str,
>> +                           default=simhost.log_default('rtems-pkg'))
>> +        argsp.add_argument('--trace',
>> +                           help='Enable trace logging for debugging.',
>> +                           action='store_true')
>> +        argsp.add_argument('--dry-run',
>> +                           help='Dry run, do not update the
>> configurations',
>> +        argsp.add_argument('bsets', nargs='*', help='Build sets.')
>> +        argopts = argsp.parse_args(args[1:])
>> +        simhost.load_log(argopts.log)
>> +        log.notice('RTEMS Source Builder - RTEMS Package Update, %s' %
>> +                   (version.string()))
>> +        log.tracing = argopts.trace
>> +        opts = simhost.load_options(args, argopts,
>> extras=['--with-download'])
>> +        opts.defaults['_rsb_getting_source'] = '1'
>> +        opts.defaults[
>> +            'rtems_waf_build_root_suffix'] = '%{waf_build_root_suffix}'
>> +        host = 'freebsd'
>> +        for cfg in rtems_pkg_cfgs:
>> +            b = None
>> +            try:
>> +                bopts = copy.copy(opts)
>> +                bmacros = copy.copy(opts.defaults)
>> +                b = build.build(cfg[1], False, bopts, bmacros)
>> +                git_hash_key = b.macros.find(cfg[2])
>> +                if len(git_hash_key) == 0:
>> +                    raise error.general(cfg[0] + ': cannot find version
>> macro')
>> +                source_dir = b.macros.expand('%{_sourcedir}')
>> +                config_hash = b.macros.expand('%{' + cfg[2] + '}')
>> +                repo_path = path.join(source_dir, cfg[4])
>> +                download.get_file(cfg[3] + '?fetch?checkout=' + cfg[5],
>> +                                  repo_path, bopts, b)
>> +                repo = git.repo(repo_path)
>> +                repo_hash = repo.head()
>> +                if config_hash != repo_hash:
>> +                    update = True
>> +                    update_str = 'UPDATE'
>> +                else:
>> +                    update = False
>> +                    update_str = 'matching'
>> +                print(cfg[0] + ': ' + update_str + ' config:' +
>> config_hash +
>> +                      ' repo:' + repo_hash)
>> +                b.macros[cfg[2]] = repo_hash
>> +                tarball = b.macros.expand(cfg[7])
>> +                b.macros.set_write_map('hashes')
>> +                b.macros[tarball] = 'NO-HASH NO-HASH'
>> +                b.macros.unset_write_map()
>> +                tarball_path = path.join(source_dir,
>> b.macros.expand(cfg[7]))
>> +                download.get_file(b.macros.expand(cfg[6]), tarball_path,
>> bopts,
>> +                                  b)
>> +                tarball_hash = checksum_shar512_base64(tarball_path)
>> +                if update:
>> +                    config_patch(b.macros.expand('%{_configdir}'),
>> +                                 b.macros.expand(cfg[1]), cfg[2],
>> config_hash,
>> +                                 repo_hash, tarball_hash)
>> +                del b
>> +            except error.general as gerr:
>> +                log.stderr(str(gerr))
>> +                log.stderr('Build FAILED')
>> +                b = None
>> +        ec = 1
>> +    except error.internal as ierr:
>> +        log.stderr(str(ierr))
>> +        log.stderr('Internal Build FAILED')
>> +        ec = 1
>> +    except error.exit as eerr:
>> +        pass
>> +    except KeyboardInterrupt:
>> +        log.notice('abort: user terminated')
>> +        ec = 1
>> +    except:
>> +        raise
>> +        log.notice('abort: unknown error')
>> +        ec = 1
>> +    sys.exit(ec)
>> +if __name__ == "__main__":
>> +    run()
>> 2.42.0
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240403/d4b2cc45/attachment-0001.htm>
