[RSB PATCH] sb: Add sb-rtems-pkg to update the RTEMS package hashes and checksums
Wed Apr 3 16:59:24 UTC 2024
Chris.. if you post a V2 addressing those, I will commit it.
On Wed, Apr 3, 2024, 11:52 AM Kinsey Moore <kinsey.moore at oarcorp.com> wrote:
> Looks fine overall. Minor nits:
> "host" is set to "freebsd" and is never used.
> Numeric indexes for repo config details are nice for brevity, but not for
> readability.
> Kinsey
> On Wed, Apr 3, 2024 at 11:29 AM Joel Sherrill <joel.sherrill at gmail.com>
> wrote:
>> This looks handy. I don't have an issue with it.
>> On Tue, Apr 2, 2024 at 11:25 PM <chrisj at rtems.org> wrote:
>>> From: Chris Johns <chrisj at rtems.org>
>>>  source-builder/sb-rtems-pkg   |  29 ++++
>>>  source-builder/sb/download.py |   5 +-
>>>  source-builder/sb/git.py      |  12 ++
>>>  source-builder/sb/rtemspkg.py | 279 ++++++++++++++++++++++++++++++++++
>>>  4 files changed, 324 insertions(+), 1 deletion(-)
>>>  create mode 100755 source-builder/sb-rtems-pkg
>>>  create mode 100644 source-builder/sb/rtemspkg.py
>>> diff --git a/source-builder/sb-rtems-pkg b/source-builder/sb-rtems-pkg
>>> new file mode 100755
>>> index 0000000..99ed26c
>>> --- /dev/null
>>> +++ b/source-builder/sb-rtems-pkg
>>> @@ -0,0 +1,29 @@
>>> +#! /usr/bin/env python
>>> +# RTEMS Tools Project (http://www.rtems.org/)
>>> +# Copyright 2024 Chris Johns (chrisj at rtems.org)
>>> +# All rights reserved.
>>> +# This file is part of the RTEMS Tools package in 'rtems-tools'.
>>> +# Permission to use, copy, modify, and/or distribute this software for
>>> any
>>> +# purpose with or without fee is hereby granted, provided that the above
>>> +# copyright notice and this permission notice appear in all copies.
>>> +# THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL
>>> WARRANTIES
>>> +# WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED WARRANTIES OF
>>> +# MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE AUTHOR BE LIABLE
>>> FOR
>>> +# ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES OR ANY DAMAGES
>>> +# WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS, WHETHER IN AN
>>> +# ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION, ARISING OUT
>>> OF
>>> +# OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE.
>>> +from __future__ import print_function
>>> +try:
>>> +    import sb.rtemspkg
>>> +    sb.rtemspkg.run()
>>> +except ImportError:
>>> +    import sys
>>> +    print("Incorrect Source Builder installation", file = sys.stderr)
>>> +    sys.exit(1)
>>> diff --git a/source-builder/sb/download.py
>>> b/source-builder/sb/download.py
>>> index 6e6f9f2..0201675 100644
>>> --- a/source-builder/sb/download.py
>>> +++ b/source-builder/sb/download.py
>>> @@ -85,6 +85,8 @@ def _hash_check(file_, absfile, macros, remove = True):
>>>          hash = hash.split()
>>>          if len(hash) != 2:
>>>              raise error.internal('invalid hash format: %s' % (file_))
>>> +        if hash[0] == 'NO-HASH':
>>> +            return not failed
>>>          try:
>>>              hashlib_algorithms = hashlib.algorithms
>>>          except:
>>> @@ -479,7 +481,8 @@ def _git_downloader(url, local, config, opts):
>>>      else:
>>>          repo.clean(['-f', '-d'])
>>>          repo.reset('--hard')
>>> -        repo.checkout('master')
>>> +        default_branch = repo.default_branch()
>>> +        repo.checkout(default_branch)
>>>      for a in us[1:]:
>>>          _as = a.split('=')
>>>          if _as[0] == 'branch' or _as[0] == 'checkout':
>>> diff --git a/source-builder/sb/git.py b/source-builder/sb/git.py
>>> index 237e690..0aa4da9 100644
>>> --- a/source-builder/sb/git.py
>>> +++ b/source-builder/sb/git.py
>>> @@ -226,6 +226,18 @@ class repo:
>>>                  hash = l1[len('commit '):]
>>>          return hash
>>> +    def default_branch(self):
>>> +        ec, output = self._run(['remote', 'show'])
>>> +        if ec == 0:
>>> +            origin = output.split('\n')[0]
>>> +            ec, output = self._run(['remote', 'show', origin])
>>> +            if ec == 0:
>>> +                for l in output.split('\n'):
>>> +                    l = l.strip()
>>> +                    if l.startswith('HEAD branch: '):
>>> +                        return l[len('HEAD branch: '):]
>>> +        return None
>>>  if __name__ == '__main__':
>>>      import os.path
>>>      import sys
>>> diff --git a/source-builder/sb/rtemspkg.py
>>> b/source-builder/sb/rtemspkg.py
>>> new file mode 100644
>>> index 0000000..0b43d23
>>> --- /dev/null
>>> +++ b/source-builder/sb/rtemspkg.py
>>> @@ -0,0 +1,279 @@
>>> any
>>> WARRANTIES
>>> FOR
>>> OF
>>> +# This code builds a package compiler tool suite given a tool set. A
>>> tool
>>> +# set lists the various tools. These are specific tool configurations.
>>> +import argparse
>>> +import base64
>>> +import copy
>>> +import datetime
>>> +import hashlib
>>> +import os
>>> +import sys
>>> +try:
>>> +    from . import build
>>> +    from . import download
>>> +    from . import error
>>> +    from . import git
>>> +    from . import log
>>> +    from . import path
>>> +    from . import simhost
>>> +    from . import version
>>> +except KeyboardInterrupt:
>>> +    print('abort: user terminated', file=sys.stderr)
>>> +    sys.exit(1)
>>> +except:
>>> +    raise
>>> +# RTEMS Packages we maintian a git hash of in the RSB
>>> +rtems_pkg_cfgs = [
>>> +        'RTEMS Tools', 'tools/rtems-tools-%{rtems_version}.cfg',
>>> +        'rtems_tools_version', 'git://git.rtems.org/rtems-tools',
>>> +        'rtems-tools.git', 'master',
>>> https://git.rtems.org/rtems-tools/snapshot/rtems-tools-%{rtems_tools_version}.tar.bz2
>>> +        'rtems-tools-%{rtems_tools_version}.tar.bz2'
>>> +        'RTEMS Kernel', 'tools/rtems-kernel-%{rtems_version}.cfg',
>>> +        'rtems_kernel_version', 'git://git.rtems.org/rtems',
>>> 'rtems.git',
>>> +        'master',
>>> https://git.rtems.org/rtems/snapshot/rtems-%{rtems_kernel_version}.tar.bz2
>>> +        'rtems-kernel-%{rtems_kernel_version}.tar.bz2'
>>> +        'RTEMS LibBSD', 'tools/rtems-libbsd-%{rtems_version}.cfg',
>>> +        'rtems_libbsd_version', 'git://git.rtems.org/rtems-libbsd',
>>> +        'rtems-libbsd.git', '6-freebsd-12',
>>> https://git.rtems.org/rtems-libbsd/snapshot/rtems-libbsd-%{rtems_libbsd_version}.tar.%{rtems_libbsd_ext}
>>> +        'rtems-libbsd-%{rtems_libbsd_version}.tar.%{rtems_libbsd_ext}'
>>> +        'RTEMS Net Legacy',
>>> 'tools/rtems-net-legacy-%{rtems_version}.cfg',
>>> +        'rtems_net_version', 'git://git.rtems.org/rtems-net-legacy',
>>> +        'rtems-net-legacy.git', 'main',
>>> https://git.rtems.org/rtems-net-legacy/snapshot/rtems-net-legacy-%{rtems_net_version}.tar.%{rtems_net_ext}
>>> +        'rtems-net-legacy-%{rtems_net_version}.tar.%{rtems_net_ext}'
>>> +        'RTEMS Net Services', 'net/net-services-1.cfg',
>>> +        'rtems_net_services_version', 'git://
>>> git.rtems.org/rtems-net-services',
>>> +        'rtems-net-services.git', 'master',
>>> https://git.rtems.org/rtems-net-services/snapshot/rtems-net-services-%{rtems_net_services_version}.tar.%{rtems_net_services_ext}
>>> 'rtems-net-services-%{rtems_net_services_version}.tar.%{rtems_net_services_ext}'
>>> +def clean_line(line):
>>> +    line = line[0:-1]
>>> +    b = line.find('#')
>>> +    if b >= 0:
>>> +        line = line[1:b] + ('\\' if line[-1] == '\\' else '')
>>> +    return line.strip()
>>> +def clean_and_pack(line, last_line):
>>> +    leading_ws = ' ' if len(line) > 0 and line[0].isspace() else ''
>>> +    line = clean_line(line)
>>> +    if len(last_line) > 0:
>>> +        line = last_line + leading_ws + line
>>> +    return line
>>> +def config_patch(configdir, config, version_label, config_hash,
>>> repo_hash,
>>> +                 checksum):
>>> +    for cd in configdir.split(':'):
>>> +        cf = path.join(cd, config)
>>> +        if path.exists(cf):
>>> +            try:
>>> +                with open(cf) as f:
>>> +                    lines = f.readlines()
>>> +            except IOError as err:
>>> +                raise error.general('config: %s: read error: %s' %
>>> +                                    (config, str(err)))
>>> +            new_config = []
>>> +            new_lines = []
>>> +            last_line = ''
>>> +            for line in lines:
>>> +                new_lines += [line]
>>> +                line = clean_and_pack(line, last_line)
>>> +                if len(line) > 0:
>>> +                    if line[-1] == '\\':
>>> +                        last_line = line[:-1]
>>> +                        continue
>>> +                    last_line = ''
>>> +                    if version_label in line and not 'rsb_version' in
>>> line:
>>> +                        if line.startswith('%define ' + version_label):
>>> +                            new_lines = [
>>> +                                '%define ' + version_label + ' ' +
>>> repo_hash +
>>> +                                os.linesep
>>> +                        elif line.startswith('%hash '):
>>> +                            ls = line.split()
>>> +                            if len(ls) != 4:
>>> +                                raise error.general('invalid %hash: ' +
>>> line)
>>> +                            new_lines = [
>>> +                                ' '.join(ls[0:3]) + ' \\' + os.linesep,
>>> +                                '              ' + checksum + os.linesep
>>> +                new_config += new_lines
>>> +                new_lines = []
>>> +            try:
>>> +                with open(cf, 'w') as f:
>>> +                    f.writelines(new_config)
>>> +                raise error.general('config: %s: write error: %s' %
>>> +            return
>>> +    raise error.general('could not find: ' + config)
>>> +def checksum_shar512_base64(tarball):
>>> +    hasher = hashlib.new('sha512')
>>> +    try:
>>> +        with open(path.host(tarball), 'rb') as f:
>>> +            hasher.update(f.read())
>>> +        log.notice('hash: %s: read error: %s' % (file_, str(err)))
>>> +    except:
>>> +        raise
>>> +        raise error.general('cannot hash the tar file')
>>> +    hash_hex = hasher.hexdigest()
>>> +    hash_base64 = base64.b64encode(hasher.digest()).decode('utf-8')
>>> +    return hash_base64
>>> +def run(args=sys.argv):
>>> +    ec = 0
>>> +    output = []
>>> +    try:
>>> +        # The RSB options support cannot be used because it loads the
>>> defaults
>>> +        # for the host which we cannot do here.
>>> +        description = 'RTEMS Track Dependencies a build set has for all
>>> hosts.'
>>> +        argsp = argparse.ArgumentParser(prog='sb-rtems-pkg',
>>> +                                        description=description)
>>> +        argsp.add_argument('--rtems-version',
>>> +                           help='Set the RTEMS version.',
>>> +                           type=str,
>>> +                           default=version.version())
>>> +        argsp.add_argument('--output',
>>> +                           help='Output file.',
>>> +                           type=str,
>>> +                           default=None)
>>> +        argsp.add_argument('--log',
>>> +                           help='Log file.',
>>> +                           type=str,
>>> +                           default=simhost.log_default('rtems-pkg'))
>>> +        argsp.add_argument('--trace',
>>> +                           help='Enable trace logging for debugging.',
>>> +                           action='store_true')
>>> +        argsp.add_argument('--dry-run',
>>> +                           help='Dry run, do not update the
>>> configurations',
>>> +        argsp.add_argument('bsets', nargs='*', help='Build sets.')
>>> +        argopts = argsp.parse_args(args[1:])
>>> +        simhost.load_log(argopts.log)
>>> +        log.notice('RTEMS Source Builder - RTEMS Package Update, %s' %
>>> +                   (version.string()))
>>> +        log.tracing = argopts.trace
>>> +        opts = simhost.load_options(args, argopts,
>>> extras=['--with-download'])
>>> +        opts.defaults['_rsb_getting_source'] = '1'
>>> +        opts.defaults[
>>> +            'rtems_waf_build_root_suffix'] = '%{waf_build_root_suffix}'
>>> +        host = 'freebsd'
>>> +        for cfg in rtems_pkg_cfgs:
>>> +            b = None
>>> +            try:
>>> +                bopts = copy.copy(opts)
>>> +                bmacros = copy.copy(opts.defaults)
>>> +                b = build.build(cfg[1], False, bopts, bmacros)
>>> +                git_hash_key = b.macros.find(cfg[2])
>>> +                if len(git_hash_key) == 0:
>>> +                    raise error.general(cfg[0] + ': cannot find version
>>> macro')
>>> +                source_dir = b.macros.expand('%{_sourcedir}')
>>> +                config_hash = b.macros.expand('%{' + cfg[2] + '}')
>>> +                repo_path = path.join(source_dir, cfg[4])
>>> +                download.get_file(cfg[3] + '?fetch?checkout=' + cfg[5],
>>> +                                  repo_path, bopts, b)
>>> +                repo = git.repo(repo_path)
>>> +                repo_hash = repo.head()
>>> +                if config_hash != repo_hash:
>>> +                    update = True
>>> +                    update_str = 'UPDATE'
>>> +                else:
>>> +                    update = False
>>> +                    update_str = 'matching'
>>> +                print(cfg[0] + ': ' + update_str + ' config:' +
>>> config_hash +
>>> +                      ' repo:' + repo_hash)
>>> +                b.macros[cfg[2]] = repo_hash
>>> +                tarball = b.macros.expand(cfg[7])
>>> +                b.macros.set_write_map('hashes')
>>> +                b.macros[tarball] = 'NO-HASH NO-HASH'
>>> +                b.macros.unset_write_map()
>>> +                tarball_path = path.join(source_dir,
>>> b.macros.expand(cfg[7]))
>>> +                download.get_file(b.macros.expand(cfg[6]),
>>> tarball_path, bopts,
>>> +                                  b)
>>> +                tarball_hash = checksum_shar512_base64(tarball_path)
>>> +                if update:
>>> +                    config_patch(b.macros.expand('%{_configdir}'),
>>> +                                 b.macros.expand(cfg[1]), cfg[2],
>>> config_hash,
>>> +                                 repo_hash, tarball_hash)
>>> +                del b
>>> +            except error.general as gerr:
>>> +                log.stderr(str(gerr))
>>> +                log.stderr('Build FAILED')
>>> +                b = None
>>> +        ec = 1
>>> +    except error.internal as ierr:
>>> +        log.stderr(str(ierr))
>>> +        log.stderr('Internal Build FAILED')
>>> +        ec = 1
>>> +    except error.exit as eerr:
>>> +        pass
>>> +    except KeyboardInterrupt:
>>> +        log.notice('abort: user terminated')
>>> +        ec = 1
>>> +    except:
>>> +        raise
>>> +        log.notice('abort: unknown error')
>>> +        ec = 1
>>> +    sys.exit(ec)
>>> +if __name__ == "__main__":
>>> +    run()
>>> 2.42.0
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240403/694540ce/attachment-0001.htm>
