[Patch] bsp/tms570/sci: fix bug in tms570_sci_read_received_chars()
Thu Feb 1 07:03:09 UTC 2024
Hello Adrien,
On 31.01.24 18:35, Adrien Chardon wrote:
> While testing the counterpart of my protocol on a Zynq, I found a
> similar issue
> where the UART is assumed to be used for printable text only. The second
> patch
> fixes it.
I am not sure about this patch. It changes the initialization. The code
you remove was added by:
commit 691d0edd34f25a883c5dd0a56051d087b88e4fa4
Author: Chris Johns <chrisj at rtems.org>
Date:   Tue Aug 17 17:57:41 2021 +1000
     arm/xilinx: Fix zynq-uart interrupt receive
     - Trigger on a single character entering the RX FIFO
     - Disable the RX timeout
     - Send up to a FIFO full of data
embedded brains GmbH & Co. KG
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
